So I looked at the camera view with EEVEE and was ready for a "really good render" so I switched to Radeon ProRender. I immediately sent the picture to a friend to show how amazing I am at using Blender. About an hour later I looked again at the bricks and it looks like what a novice might accept! I switched back to EEVEE and rendered again. Attached are the results. The bricks that look like you don't have COVID are the EEVEE render. I can't even imagine how I can reset to get the bricks to show properly using Radeon.
Comment Actions
If the model renders properly in both Eevee and Cycles then the issue is most likely a bug in Radeon's ProRender. Please report the issue to them.
In case you believe that you've found a in Blender bug, please create a new bug report through Help > Report a Bug in Blender. We expect all bug reports to follow the submission template. This guide, it may help you write a bug report that allows us to fix your problem. Please provide system information (operating system, GPU, driver version), affected Blender version, previous Blender version that worked properly, a short and precise description of the issue, step by step instructions to reproduce it and, if relevant, a minimal .blend file that showcases the problem.
