Blender doesn't recognize tablet presure
Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.30
Broken: version: 2.92.0 Alpha, branch: master, commit date: 2020-12-07 22:51, hash: rBab9952e55fe1
I have a Huion kamvas pro 13, when I tried to sculpt or use any brush I don't be able use the presure, I installed Blender 2.91 and the error wasn't there
Did you try to start Blender 2.92 alpha with the factory preferences (blender_factory_startup.cmd)?
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from Developers.Dec 11 2020, 5:56 PM
Philipp Oeser (lichtwerk) added a project: Restricted Project.
Nicholas Rishel (nicholas_rishel) changed the task status from Needs Information from Developers to Needs Information from User.Dec 17 2020, 3:11 AM
This may be resolved by rB3a1d1aaa86d0d7cc6aaf0e6633d557bbcdd0b514, could you check if the issue is present in nightly?
Nicholas Rishel (nicholas_rishel) moved this task from Restricted Project Column to Restricted Project Column on the Restricted Project board.Dec 17 2020, 3:15 AM
The pressure doesn't work yet, I just update Blender and the tablet drivers
Another attempt, could you try this build? It involves a significant rewrite of Wintab.
@Nicholas Rishel (nicholas_rishel) That build fixed the pen pressure and viewport navigation bugs for me. Thanks!
Now I can navigate across the viewport, but I still without pressure, with the build of 12/13/2020
Navigation and pressure work fine for me.
Quick Update: Pen tip drag is issued in a new windows Edit ->Preferences. However preferences inside main window works fine
Do you mean the 12/23 daily build? The build I linked is a custom build uploaded to graphicall, not daily.
@Richard Jack Cuéllar Jiménez (R_Jack) The changes are now in Blender daily builds. Since there's a bit of confusion on what you tested could you retest the current daily build?
Nicholas Rishel (nicholas_rishel) moved this task from Restricted Project Column to Restricted Project Column on the Restricted Project board.Dec 27 2020, 9:31 PM
Hi again!, I downloaded the daily build of today 27th, and still not working... and the buttons of the stylus either, I forgot that before
Edit: I also downloaded the 2.83 LTS and over there all is working, if that can be useful
@Richard Jack Cuéllar Jiménez (R_Jack) could you repeat the bug in this build, copy the system console to this link, and link the paste in a reply to this report?
Nicholas Rishel (nicholas_rishel) moved this task from Restricted Project Column to Restricted Project Column on the Restricted Project board.Dec 29 2020, 2:23 AM
