Bevel modifier with vertex group limit method is not working
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 2.71 - 2.92.0
Worked: version: 2.70 before rB2a8f6e2f
In the 2.79 Release you can change the weight of the vertex group getting diferent bevel´s results.
Thanks and Kind Regards.
I left this easy example when you can check that since 2.8xx release this parameter is broken.
Only I can get to have activated or no the bevel.
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Needs Information from User.Dec 10 2020, 7:58 PM
I imported the file into blender 2.79 and the result is the same. So I can't reproduce the problem.
Please use the submission guide and provide the "Exact steps for others to reproduce the error".
A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
Yes, I tested this in 2.79 too. Even though I agree that it should be possible to do this, the fact that you can't is more of a feature request than a bug report.
Anyway, you can vary the offset of the bevel by using bevel weights. More flexible ways to control this should come with geometry nodes in the not-too-distant future.
Thanks for the report, but the issue reported here is not a regression but a request for modified/improved behavior. Closing as this bug tracker is only for bugs and errors.
For user requests and feedback, please use other channels: https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests
For more information on why this isn't considered a bug, visit: https://wiki.blender.org/wiki/Reference/Not_a_bug
