Drawing with pen is broken.
The same problem that I had with 2.91 release, this bug had the fix very quick..
The problem is: When I draw with the tablet I can draw points only.
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 2.92.0 Alpha, branch: master, commit date: 2020-10-31 21:21, hash: rBc249eb7a8d61
This may be resolved by rB3a1d1aaa86d0d7cc6aaf0e6633d557bbcdd0b514, could you check if the issue is present in nightly?
Nicholas Rishel (nicholas_rishel) changed the task status from Needs Triage to Needs Information from User.Dec 17 2020, 3:14 AM
Nicholas Rishel (nicholas_rishel) moved this task from Restricted Project Column to Restricted Project Column on the Restricted Project board.
