Change Brush size does not show Falloff gradient anymore
Operating system: Darwin-20.2.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 575 OpenGL Engine ATI Technologies Inc. 4.1 ATI-4.2.11
Broken: version: 2.92.0 Alpha, branch: master, commit date: 2020-12-07 22:51, hash: rBab9952e55fe1
Broken: 2.81
Worked: 2.80
Caused by rBbe985bdde27f: Sculpt: Sculpt cursor UX improvements
  • Enter Texture Paint mode (or sculpt mode, vertexpaint mode, ...)
  • use F to change brush size: no falloff shown
  • use +F to change brush strength: falloff shown
This was not the case in 2.79 or 2.80
Turns out whenever radial control is used for something other than PROP_NONE, PROP_PIXEL, PROP_DISTANCE, it draws with the (falloff) gradient, in our case [brush size], it draws without. Think this is useful information which does not really distract?
I also can't see the black Falloff circle here.
It must be by design.
I'm not sure if it's really a bug.
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Dec 22 2020, 4:12 PM
It does display when a texture mask texture https://docs.blender.org/manual/en/dev/sculpt_paint/brush/texture.html#texture-mask is specified.
You can set one to pure white to get the desired effect, but maybe this could be done by default yes.
In Fact, 2.79 and 2.80 still did that, so I would confirm this.
Will also check on this.
Push the 'F' key doesn't appear falloff black circle show display.
Push the 'Shift+F' yes show number and falloff black circle show display.
Push the 'Command+F' yes show number and fall black circle show display.
That is not TEXTURE PAINT.
Seems like this was a somewhat intentional change in rBbe985bdde27f: Sculpt: Sculpt cursor UX improvements
Also see this comment in D5889
  • Hide gradient when resizing
So whenever radial control is used for something other than PROP_NONE, PROP_PIXEL, PROP_DISTANCE, it draws with the (falloff) gradient, in our case [brush size], it draws without.
Not sure I can follow that logic (think this is useful information which does not really distract), but will let module members decide...
Use this to always show it:
1
2
3diff --git a/source/blender/windowmanager/intern/wm_operators.c b/source/blender/windowmanager/intern/wm_operators.c
4index a5b5f082c41..07a0690a3f2 100644
5--- a/source/blender/windowmanager/intern/wm_operators.c
6+++ b/source/blender/windowmanager/intern/wm_operators.c
7@@ -2187,7 +2187,7 @@ static void radial_control_set_tex(RadialControl *rc)
8 if ((ibuf = BKE_brush_gen_radial_control_imbuf(
9 rc->image_id_ptr.data,
10 rc->use_secondary_tex,
11- !ELEM(rc->subtype, PROP_NONE, PROP_PIXEL, PROP_DISTANCE)))) {
12+ true))) {
13
14 rc->texture = GPU_texture_create_2d(
15 "radial_control", ibuf->x, ibuf->y, 1, GPU_R8, ibuf->rect_float);
CC @Pablo Dobarro (pablodp606)
CC @Julien Kaspar (JulienKaspar)
CC @Pablo Vazquez (pablovazquez)
CC @Jeroen Bakker (jbakker)
CC @Campbell Barton (campbellbarton)
Philipp Oeser (lichtwerk) renamed this task from Falloff (black middle circle) [F] key not appear show display to Change Brush size does not show Falloff gradient anymore.Dec 22 2020, 5:46 PM
Philipp Oeser (lichtwerk) updated the task description. (Show Details)
Using gradients to define a curve in the UI is rarely useful (you can't differentiate gray scale values with enough precision to determine the shape of the curve). This is why the curve preview with the line was added when changing the strength.
I consider this an UI design discussion, but in my opinion, the gradient falloff should be always hidden (maybe only show it multiplied on top of an alpha texture when it is being used).
@Philipp Oeser (lichtwerk) Thank you for your support to change rename correct. I am not good english to explain but why @Pablo Dobarro (pablodp606) put invalid without communication to me.
I ask him do they already inspect for Macintosh.
@Kent Davis (mac4kent), apparently the "Brush size gradient falloff" no longer showing was a design choice and not a bug.
The same is seen in other systems (not only Macintosh).
Since it is not really a bug (but something that was decided), the report has been closed.
