Graphics card: GeForce GTX 1650/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.79
Broken: version: 2.92.0 Alpha, branch: master, commit date: 2020-12-09 01:29, hash: rB9b11a7776f2a
Worked: 2.83.10
If 2 high poly (~100k faces per obj) objects in modifiers properties have after Displacement modifier (with animated texture) "Generate" type modifiers (I've tried Boolean and Decimate), Blender cant run Animation render (but still can run Image render).
Crash happens on 2.9 and higher. I've tested this on 2.83.10 LTS (from steam) and everything worked fine there.
Crashes with Decimate a little bit hard to recreate. So I will go with steps for "Boolean crash"
- create Cude, Empty and Icosphere
- Add Subdivision mod. to Cube: set it to "Simple" and 7 levels
- Add Displacement mod. to Cube and set texture (Clouds) coordinates to object - Empty
- Add Boolean mod. (difference) and select object Icosphere
- Select Cude with Icosphere and duplicate them
- Save and press Render Animation
==3883==ERROR: AddressSanitizer: heap-use-after-free on address 0x61500034ec08 at pc 0x000016fc795d bp 0x7fffc19dd6c0 sp 0x7fffc19dd6b0
READ of size 8 at 0x61500034ec08 thread T15
#0 0x16fc795c in blender::gpu::GLBatch::verts_(int) const /home/dev/01-data/01-git/blender-git/blender/source/blender/gpu/opengl/gl_batch.hh:112
#1 0x17013501 in blender::gpu::GLVertArray::update_bindings(unsigned int, GPUBatch const*, blender::gpu::ShaderInterface const*, int) /home/dev/01-data/01-git/blender-git/blender/source/blender/gpu/opengl/gl_vertex_array.cc:124
#2 0x16fa900b in blender::gpu::GLVaoCache::vao_get(GPUBatch*) /home/dev/01-data/01-git/blender-git/blender/source/blender/gpu/opengl/gl_batch.cc:273
#3 0x16fa84d8 in blender::gpu::GLVaoCache::base_instance_vao_get(GPUBatch*, int) /home/dev/01-data/01-git/blender-git/blender/source/blender/gpu/opengl/gl_batch.cc:234
#4 0x16fa9d3e in blender::gpu::GLBatch::bind(int) /home/dev/01-data/01-git/blender-git/blender/source/blender/gpu/opengl/gl_batch.cc:317
#5 0x16fa9f3f in blender::gpu::GLBatch::draw(int, int, int, int) /home/dev/01-data/01-git/blender-git/blender/source/blender/gpu/opengl/gl_batch.cc:328
#6 0x16eca2be in GPU_batch_draw_advanced /home/dev/01-data/01-git/blender-git/blender/source/blender/gpu/intern/gpu_batch.cc:282
#7 0x16fc1207 in blender::gpu::GLDrawList::append(GPUBatch*, int, int) /home/dev/01-data/01-git/blender-git/blender/source/blender/gpu/opengl/gl_drawlist.cc:122
#8 0x16efa9f5 in GPU_draw_list_append /home/dev/01-data/01-git/blender-git/blender/source/blender/gpu/intern/gpu_drawlist.cc:52
#9 0x5978acc in draw_indirect_call /home/dev/01-data/01-git/blender-git/blender/source/blender/draw/intern/draw_manager_exec.c:598
#10 0x5978acc in draw_call_batching_flush /home/dev/01-data/01-git/blender-git/blender/source/blender/draw/intern/draw_manager_exec.c:795
#11 0x597c5f0 in draw_call_batching_finish /home/dev/01-data/01-git/blender-git/blender/source/blender/draw/intern/draw_manager_exec.c:891
#12 0x597eae7 in draw_shgroup /home/dev/01-data/01-git/blender-git/blender/source/blender/draw/intern/draw_manager_exec.c:1056
#13 0x597f89f in drw_draw_pass_ex /home/dev/01-data/01-git/blender-git/blender/source/blender/draw/intern/draw_manager_exec.c:1113
#14 0x597fe50 in DRW_draw_pass /home/dev/01-data/01-git/blender-git/blender/source/blender/draw/intern/draw_manager_exec.c:1153
#15 0x5c51bc0 in EEVEE_velocity_resolve /home/dev/01-data/01-git/blender-git/blender/source/blender/draw/engines/eevee/eevee_effects.c:466
#16 0x5c5202b in EEVEE_draw_effects /home/dev/01-data/01-git/blender-git/blender/source/blender/draw/engines/eevee/eevee_effects.c:486
#17 0x5a21f42 in EEVEE_render_draw /home/dev/01-data/01-git/blender-git/blender/source/blender/draw/engines/eevee/eevee_render.c:671
#18 0x59b1dbc in eevee_render_to_image /home/dev/01-data/01-git/blender-git/blender/source/blender/draw/engines/eevee/eevee_engine.c:559
#19 0x5948820 in DRW_render_to_image /home/dev/01-data/01-git/blender-git/blender/source/blender/draw/intern/draw_manager.c:1909
#20 0x14ff1d77 in engine_render_view_layer /home/dev/01-data/01-git/blender-git/blender/source/blender/render/intern/engine.c:786
#21 0x14ff40a3 in RE_engine_render /home/dev/01-data/01-git/blender-git/blender/source/blender/render/intern/engine.c:914
#22 0x1501aafb in do_render_3d /home/dev/01-data/01-git/blender-git/blender/source/blender/render/intern/pipeline.c:1132
#23 0x1501c24a in do_render /home/dev/01-data/01-git/blender-git/blender/source/blender/render/intern/pipeline.c:1209
#24 0x1501e036 in do_render_composite /home/dev/01-data/01-git/blender-git/blender/source/blender/render/intern/pipeline.c:1349
#25 0x15022789 in do_render_all_options /home/dev/01-data/01-git/blender-git/blender/source/blender/render/intern/pipeline.c:1615
#26 0x15027839 in RE_RenderFrame /home/dev/01-data/01-git/blender-git/blender/source/blender/render/intern/pipeline.c:2015
#27 0xd7b42cf in render_startjob /home/dev/01-data/01-git/blender-git/blender/source/blender/editors/render/render_internal.c:630
#28 0x4fed4f1 in do_job_thread /home/dev/01-data/01-git/blender-git/blender/source/blender/windowmanager/intern/wm_jobs.c:389
#29 0x18de408d in tslot_thread_start /home/dev/01-data/01-git/blender-git/blender/source/blender/blenlib/intern/threads.cc:231
#30 0x7ffff7566608 in start_thread /build/glibc-ZN95T4/glibc-2.31/nptl/pthread_create.c:477
#31 0x7ffff6f46292 in __clone (/lib/x86_64-linux-gnu/libc.so.6+0x122292)
0x61500034ec08 is located 8 bytes inside of 512-byte region [0x61500034ec00,0x61500034ee00)
freed by thread T15 here:
#0 0x7ffff76927cf in __interceptor_free (/lib/x86_64-linux-gnu/libasan.so.5+0x10d7cf)
#1 0x18e0eab0 in MEM_lockfree_freeN /home/dev/01-data/01-git/blender-git/blender/intern/guardedalloc/intern/mallocn_lockfree_impl.c:129
#2 0x16ef56c6 in blender::gpu::GLVertBuf::operator delete(void*) /home/dev/01-data/01-git/blender-git/blender/source/blender/gpu/opengl/gl_vertex_buffer.hh:57
#3 0x17018021 in blender::gpu::GLVertBuf::~GLVertBuf() /home/dev/01-data/01-git/blender-git/blender/source/blender/gpu/opengl/gl_vertex_buffer.hh:35
#4 0x16f8bb19 in blender::gpu::VertBuf::reference_remove() /home/dev/01-data/01-git/blender-git/blender/source/blender/gpu/intern/gpu_vertex_buffer_private.hh:94
#5 0x16f877f5 in GPU_vertbuf_discard /home/dev/01-data/01-git/blender-git/blender/source/blender/gpu/intern/gpu_vertex_buffer.cc:161
#6 0x5a0eab8 in EEVEE_motion_blur_cache_finish /home/dev/01-data/01-git/blender-git/blender/source/blender/draw/engines/eevee/eevee_motion_blur.c:449
#7 0x59b1bef in eevee_render_to_image /home/dev/01-data/01-git/blender-git/blender/source/blender/draw/engines/eevee/eevee_engine.c:542
#8 0x5948820 in DRW_render_to_image /home/dev/01-data/01-git/blender-git/blender/source/blender/draw/intern/draw_manager.c:1909
#9 0x14ff1d77 in engine_render_view_layer /home/dev/01-data/01-git/blender-git/blender/source/blender/render/intern/engine.c:786
#10 0x14ff40a3 in RE_engine_render /home/dev/01-data/01-git/blender-git/blender/source/blender/render/intern/engine.c:914
#11 0x1501aafb in do_render_3d /home/dev/01-data/01-git/blender-git/blender/source/blender/render/intern/pipeline.c:1132
#12 0x1501c24a in do_render /home/dev/01-data/01-git/blender-git/blender/source/blender/render/intern/pipeline.c:1209
#13 0x1501e036 in do_render_composite /home/dev/01-data/01-git/blender-git/blender/source/blender/render/intern/pipeline.c:1349
#14 0x15022789 in do_render_all_options /home/dev/01-data/01-git/blender-git/blender/source/blender/render/intern/pipeline.c:1615
#15 0x15027839 in RE_RenderFrame /home/dev/01-data/01-git/blender-git/blender/source/blender/render/intern/pipeline.c:2015
#16 0xd7b42cf in render_startjob /home/dev/01-data/01-git/blender-git/blender/source/blender/editors/render/render_internal.c:630
#17 0x4fed4f1 in do_job_thread /home/dev/01-data/01-git/blender-git/blender/source/blender/windowmanager/intern/wm_jobs.c:389
#18 0x18de408d in tslot_thread_start /home/dev/01-data/01-git/blender-git/blender/source/blender/blenlib/intern/threads.cc:231
#19 0x7ffff7566608 in start_thread /build/glibc-ZN95T4/glibc-2.31/nptl/pthread_create.c:477
previously allocated by thread T15 here:
#0 0x7ffff7692bc8 in malloc (/lib/x86_64-linux-gnu/libasan.so.5+0x10dbc8)
#1 0x18e0f510 in MEM_lockfree_mallocN /home/dev/01-data/01-git/blender-git/blender/intern/guardedalloc/intern/mallocn_lockfree_impl.c:276
#2 0x16ef5676 in blender::gpu::GLVertBuf::operator new(unsigned long) /home/dev/01-data/01-git/blender-git/blender/source/blender/gpu/opengl/gl_vertex_buffer.hh:57
#3 0x16ef70a2 in blender::gpu::GLBackend::vertbuf_alloc() /home/dev/01-data/01-git/blender-git/blender/source/blender/gpu/opengl/gl_backend.hh:121
#4 0x16f85d10 in blender::gpu::VertBuf::duplicate() /home/dev/01-data/01-git/blender-git/blender/source/blender/gpu/intern/gpu_vertex_buffer.cc:77
#5 0x16f8750d in GPU_vertbuf_duplicate /home/dev/01-data/01-git/blender-git/blender/source/blender/gpu/intern/gpu_vertex_buffer.cc:149
#6 0x5a0ee06 in EEVEE_motion_blur_cache_finish /home/dev/01-data/01-git/blender-git/blender/source/blender/draw/engines/eevee/eevee_motion_blur.c:467
#7 0x59b1953 in eevee_render_to_image /home/dev/01-data/01-git/blender-git/blender/source/blender/draw/engines/eevee/eevee_engine.c:507
Thread T15 created by T0 here:
#0 0x7ffff75bf805 in pthread_create (/lib/x86_64-linux-gnu/libasan.so.5+0x3a805)
#1 0x18de42b9 in BLI_threadpool_insert /home/dev/01-data/01-git/blender-git/blender/source/blender/blenlib/intern/threads.cc:245
#2 0x4fee516 in WM_jobs_start /home/dev/01-data/01-git/blender-git/blender/source/blender/windowmanager/intern/wm_jobs.c:484
#3 0xd7b88bd in screen_render_invoke /home/dev/01-data/01-git/blender-git/blender/source/blender/editors/render/render_internal.c:1041
#4 0x4f8f3ba in wm_operator_invoke /home/dev/01-data/01-git/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:1293
#5 0x4f912f2 in wm_operator_call_internal /home/dev/01-data/01-git/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:1500
#6 0x4f91551 in WM_operator_name_call_ptr /home/dev/01-data/01-git/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:1548
#7 0x90f1c95 in ui_apply_but_funcs_after /home/dev/01-data/01-git/blender-git/blender/source/blender/editors/interface/interface_handlers.c:932
#8 0x917b8d0 in ui_handler_region_menu /home/dev/01-data/01-git/blender-git/blender/source/blender/editors/interface/interface_handlers.c:10809
#9 0x4f88a9b in wm_handler_ui_call /home/dev/01-data/01-git/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:636
#10 0x4f9ec36 in wm_handlers_do_intern /home/dev/01-data/01-git/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:2757
#11 0x4f9fc78 in wm_handlers_do /home/dev/01-data/01-git/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:2865
#12 0x4fa537f in wm_event_do_handlers /home/dev/01-data/01-git/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:3288
#13 0x4f732cf in WM_main /home/dev/01-data/01-git/blender-git/blender/source/blender/windowmanager/intern/wm.c:635
#14 0x34f58fa in main /home/dev/01-data/01-git/blender-git/blender/source/creator/creator.c:522
#15 0x7ffff6e4b0b2 in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x270b2)
SUMMARY: AddressSanitizer: heap-use-after-free /home/dev/01-data/01-git/blender-git/blender/source/blender/gpu/opengl/gl_batch.hh:112 in blender::gpu::GLBatch::verts_(int) const
Shadow bytes around the buggy address:
0x0c2a80061d30: fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd
0x0c2a80061d40: fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd
0x0c2a80061d50: fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd
0x0c2a80061d60: fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd fa
0x0c2a80061d70: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
=>0x0c2a80061d80: fd[fd]fd fd fd fd fd fd fd fd fd fd fd fd fd fd
0x0c2a80061d90: fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd
0x0c2a80061da0: fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd
0x0c2a80061db0: fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd
0x0c2a80061dc0: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
0x0c2a80061dd0: fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd
Shadow byte legend (one shadow byte represents 8 application bytes):
Addressable: 00
Partially addressable: 01 02 03 04 05 06 07
Heap left redzone: fa
Freed heap region: fd
Stack left redzone: f1
Stack mid redzone: f2
Stack right redzone: f3
Stack after return: f5
Stack use after scope: f8
Global redzone: f9
Global init order: f6
Poisoned by user: f7
Container overflow: fc
Array cookie: ac
Intra object redzone: bb
ASan internal: fe
Left alloca redzone: ca
Right alloca redzone: cb
Shadow gap: cc
