Wacom Pen on Windows lost click precision in 2.92
Operating system: Windows 10
Graphics card: Nvidia 1070 Gtx
Wacom Intuos Pro L (6.3.41-1 driver) , Wacom Pen is in Pen mode (not mouse)
Broken: 2.92.0 Alpha, branch: master, commit date: 2020-12-10 21:48, hash: caed4849d090, type: Release
Worked: 2.91 Release
It looks like some bugs introduced in 2.92 regarding the Wacom hardware. These issues revolve around left click and the pressure sensitiviy.
The click precision is out of whack when using Wintab API (non Windows Ink mode ) . It is really hard to click on anything especially in the outliner. It takes many clicks to select or activate an object in the 3d viewport when the driver is set to Wintab.
These issues are pretty much resolved when one changes the driver to Windows Ink in the Tablet settings under "input" However this time the pressure sensitity is gone in the Sculpt mode. A restart after this setting does not help.
Please bear in mind that none of these issues exists in 2.91 Release with the same hardware and the same operating system.
kursad k (kursadk) renamed this task from Wacom on Windows lost click precision in 2.92, Windows Ink mode has no pressure to Wacom Pen on Windows lost click precision in 2.92, Windows Ink mode has no pressure.Dec 13 2020, 3:38 AM
kursad k (kursadk) created this task.
kursad k (kursadk) updated the task description. (Show Details)
Nicholas Rishel (nicholas_rishel) renamed this task from Wacom Pen on Windows lost click precision in 2.92, Windows Ink mode has no pressure to Wacom Pen on Windows lost click precision in 2.92.Dec 17 2020, 3:18 AM
Nicholas Rishel (nicholas_rishel) changed the task status from Needs Triage to Needs Information from User.
Nicholas Rishel (nicholas_rishel) added a project: Restricted Project.
This may be resolved by rB3a1d1aaa86d0d7cc6aaf0e6633d557bbcdd0b514, could you check if the issue is present in nightly?
Windows Ink is another issue, I've subscribed you to the appropriate task to follow.
Nicholas Rishel (nicholas_rishel) moved this task from Restricted Project Column to Restricted Project Column on the Restricted Project board.Dec 17 2020, 3:20 AM
Thanks for the follow up. I will test it out and report back.
@Nicholas Rishel (nicholas_rishel)
Unfortunately the issue is still there in blender-2.92.0-23233fcf056e. I switch to a regular mouse, the click works like charm. My wacom pen works fine in 2.91 so it is definetely not a hardware issue.
Could you try this build?
There's currently a lot of churn in how Wintab is being handled, which is necessary to add high frequency tablet events. So it's not surprising that some things need to be fixed.
This build feels much better and improved both in the outliner and in the viewport.
I got these in the terminal, I say not frequently.
missed 1
missed 1
missed 0
Nicholas Rishel (nicholas_rishel) moved this task from Restricted Project Column to Restricted Project Column on the Restricted Project board.Dec 22 2020, 8:10 AM
