Operating system: Debian
Graphics card:
Broken: 2.91.0
Loop cut (CTRL-R) does not snap as expected if the custom grid subdivisions is changed by user.
- Start blender.
- Hit Shift-Tab to enable snapping, and in the "Snap To" drop-down, select "Increment".
- In the "Scene Properties" tab of the "Properties" panel, expand the "Units" section and set "Unit System" to "None". (otherwise step 4 is impossible)
- In the upper right corner of the 3D viewport, in the "Overlays" menu, change "Subdivisions" from 10 to 16.
- hit numpad-7 to go to top orthographic view.
- In the floor grid, you can see that the default cube occupies 2x2 grid elements.
- Use the mouse wheel to zoom so that you can see the 16x16 smaller grid within each of the floor's grid elements. You must be able to see them in order to reproduce the bug.
- While the 16x16 grid is visible, Tab into "Edit Mode"
- Hover the mouse cursor over the bottom edge of the cube, and hit Ctrl-R to invoke "Loop Cut".
- left-click to accept a single loop. It appears as a vertical yellow/orange line.
- Drag the mouse to the left, causing the loop cut to snap in increments. >>> THIS IS THE BUG <<<
- Notice that in spite of setting "Snap To" to "Increment in step 2, the loop cut does not snap to the 16 grid elements. Instead it snaps unevenly between them.
- I believe this is a bug because increment snapping should cause the loop cut to snap to each of the 16 grid elements in turn. Instead, "loop cut" snaps 10 times, corresponding to the original value of 10 in the grid "Subdivisions". I suspect "loop cut" is not taking account of the value of the the floor grid subdivisions when calculating where to snap.
Thanks,
Zack
