Knife Tool not working
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.79
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash: rB0f45cab862b8
While trying to draw lines with the knife tool, it doesnt work in perspective mode. at times it works normally but most of the times it's stuck in an area, or works superweirdly a problem I didn't encounter on previous versions. I might provide necessary data when needed. thanks in advance.
[[ [[ [[ [[ [[ URL | URL ]] | URL ]] | URL ]] | URL ]] | name ]]
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Dec 16 2020, 3:51 PM
Yes, if this is not reproduceable in the default startup file, please provide the example .blend file.
Then, exact reproduction steps are needed (which part of the geometry to cut, etc.)
A screencast showing the issue in action might also help here.
