Operating system: Mac OS 11.1
Graphics card: Radeon Pro 580X 8 GB
Broken:
- 2.92
- 2.91.0 (2.91.0 2020-11-25)
Worked: ?
Instructions by @Yevgeny Makarov (jenkm):
- Switch to the Weight Paint mode.
- Enable the Paint Mask option next to the object interaction mode in the UI.
- Switch from the Tweak tool to the Select Circle tool.
- Attempt to select faces with the Select Circle tool, which results in a crash.
Sometimes it crashes on the first click, sometimes you need to quickly "paint" several times for the crash.
Asan report:
Original description:
- In the menu item - weight Paint
- Circle selection and select an area
Process: Blender [1126]
Path: /Applications/Blender/Blender Kopie.app/Contents/MacOS/Blender
Identifier: org.blenderfoundation.blender
Version: 2.91.0 (2.91.0 2020-11-25)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Blender [1126]
User ID: 501
Date/Time: 2020-12-30 11:17:27.732 +0100
OS Version: macOS 11.1 (20C69)
Report Version: 12
Anonymous UUID: E324659E-D4E7-C95B-4226-24A1FAB0D031
Time Awake Since Boot: 3900 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000003
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [1126]
VM Regions Near 0x3:
__TEXT 1031e3000-10d9b7000 [167.8M] r-x/r-x SM=COW /Applications/Blender/Blender Kopie.app/Contents/MacOS/Blender
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_platform.dylib 0x00007fff203990a9 _platform_memmove$VARIANT$Haswell + 41
1 com.apple.AMDRadeonX4000GLDriver 0x000000011b1b4cd6 glrWriteBufferData + 186
2 GLEngine 0x00007fff6caa1812 glBufferSubData_Exec + 608
3 org.blenderfoundation.blender 0x000000010975db6b blender::gpu::GLVertBuf::bind() + 171
4 org.blenderfoundation.blender 0x000000010975d2e4 blender::gpu::GLVertArray::update_bindings(unsigned int, GPUBatch const*, blender::gpu::ShaderInterface const*, int) + 308
5 org.blenderfoundation.blender 0x0000000109751226 blender::gpu::GLVaoCache::base_instance_vao_get(GPUBatch*, int) + 182
6 org.blenderfoundation.blender 0x0000000109751555 blender::gpu::GLBatch::bind(int) + 149
7 org.blenderfoundation.blender 0x0000000109751597 blender::gpu::GLBatch::draw(int, int, int, int) + 39
8 org.blenderfoundation.blender 0x0000000103871775 draw_call_single_do + 469
9 org.blenderfoundation.blender 0x0000000103870f1a drw_draw_pass_ex + 1626
10 org.blenderfoundation.blender 0x00000001038708af DRW_draw_pass + 31
11 org.blenderfoundation.blender 0x00000001038bbc5a OVERLAY_paint_draw + 122
12 org.blenderfoundation.blender 0x00000001038b2042 OVERLAY_draw_scene + 610
13 org.blenderfoundation.blender 0x0000000103867d8a drw_engines_draw_scene + 186
14 org.blenderfoundation.blender 0x000000010386698d DRW_draw_render_loop_ex + 1565
15 org.blenderfoundation.blender 0x00000001040f8778 view3d_main_region_draw + 136
16 org.blenderfoundation.blender 0x0000000103ca6e70 ED_region_do_draw + 336
17 org.blenderfoundation.blender 0x000000010372d49d wm_draw_update + 1757
18 org.blenderfoundation.blender 0x000000010372b110 WM_main + 48
19 org.blenderfoundation.blender 0x000000010332797a main + 890
20 libdyld.dylib 0x00007fff20372621 start + 1
Thread 1:
0 libsystem_kernel.dylib 0x00007fff20322eba semaphore_wait_trap + 10
1 libdispatch.dylib 0x00007fff201acc5c _dispatch_sema4_wait + 16
2 libdispatch.dylib 0x00007fff201ad12e _dispatch_semaphore_wait_slow + 98
3 org.blenderfoundation.blender 0x0000000109282c32 IlmThread_2_4::(anonymous namespace)::DefaultWorkerThread::run() + 50
4 org.blenderfoundation.blender 0x000000010928179e void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_4::Thread::*)(), IlmThread_2_4::Thread*> >(void*) + 62
5 libsystem_pthread.dylib 0x00007fff20357950 _pthread_start + 224
6 libsystem_pthread.dylib 0x00007fff2035347b thread_start + 15
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:: AMCP Logging Spool
1 com.apple.audio.caulk 0x00007fff2845292a caulk::mach::semaphore::wait_or_error() + 16
2 com.apple.audio.caulk 0x00007fff2843f6e6 caulk::semaphore::timed_wait(double) + 110
3 com.apple.audio.caulk 0x00007fff2843f634 caulk::concurrent::details::worker_thread::run() + 30
4 com.apple.audio.caulk 0x00007fff2843f3c0 void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 45
Thread 18:: com.apple.audio.IOThread.client
0 libsystem_kernel.dylib 0x00007fff20322e7e mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff203231f0 mach_msg + 60
2 com.apple.audio.CoreAudio 0x00007fff21e45de5 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 111
3 com.apple.audio.CoreAudio 0x00007fff21ce1477 invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int) + 3435
4 com.apple.audio.CoreAudio 0x00007fff21e84f3a HALB_IOThread::Entry(void*) + 72
Thread 19:
1 org.blenderfoundation.blender 0x0000000103721c68 tbb::internal::rml::private_worker::run() + 104
2 org.blenderfoundation.blender 0x0000000103721bf9 tbb::internal::rml::private_worker::thread_routine(void*) + 9
3 libsystem_pthread.dylib 0x00007fff20357950 _pthread_start + 224
4 libsystem_pthread.dylib 0x00007fff2035347b thread_start + 15
Thread 20:
Thread 21:
Thread 22:
Thread 23:
Thread 24:
Thread 25:
Thread 26:
Thread 27:
Thread 28:
Thread 29:
Thread 30:
Thread 31:
Thread 32:
Thread 33:
Thread 34:: com.apple.NSEventThread
2 com.apple.CoreFoundation 0x00007fff2044fbf7 __CFRunLoopServiceMachPort + 316
3 com.apple.CoreFoundation 0x00007fff2044e2ca __CFRunLoopRun + 1315
4 com.apple.CoreFoundation 0x00007fff2044d6ce CFRunLoopRunSpecific + 563
5 com.apple.AppKit 0x00007fff22df0c16 _NSEventThread + 124
6 libsystem_pthread.dylib 0x00007fff20357950 _pthread_start + 224
7 libsystem_pthread.dylib 0x00007fff2035347b thread_start + 15
Thread 35:
0 libsystem_pthread.dylib 0x00007fff20353458 start_wqthread + 0
Thread 36:
Thread 37:
Thread 38:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x000000017a4c4000 rbx: 0x0000600000c11e00 rcx: 0x000000000036dda0 rdx: 0x000000000036dda0
rdi: 0x000000017a4c4000 rsi: 0x0000000000000003 rbp: 0x00007ffeeca1be10 rsp: 0x00007ffeeca1be10
r8: 0x0000000000000003 r9: 0x0000000000000000 r10: 0x00000000000010bc r11: 0x000000017a4c3ffd
r12: 0x00007fb715121a00 r13: 0x000000000036dda0 r14: 0x0000000131eb1800 r15: 0x0000000000000000
rip: 0x00007fff203990a9 rfl: 0x0000000000010206 cr2: 0x0000000000000003
Logical CPU: 0
Error Code: 0x00000004 (no mapping for user data read)
Trap Number: 14
Thread 0 instruction stream:
c1 48 83 c1 10 3d ff ff-00 00 74 db f7 d0 0f bc .H...=....t.....
c0 48 01 c1 48 0f b6 44-0f f0 4c 0f b6 44 0e f0 .H..H..D..L..D..
4c 29 c0 5d c3 90 90 90-90 90 90 90 90 90 90 90 L).]............
90 90 90 90 90 90 90 55-48 89 e5 49 89 fb 49 29 .......UH..I..I)
f3 48 89 f8 49 39 d3 72-1b 48 83 fa 60 76 2f 48 .H..I9.r.H..`v/H
81 fa 00 40 00 00 0f 82-cb 00 00 00 48 89 d1 fc ...@........H...
[f3]a4 5d c3 48 39 fe 74-f9 48 01 d6 48 01 d7 48 ..].H9.t.H..H..H <==
83 fa 60 0f 82 8c 01 00-00 e9 a9 01 00 00 48 83 ..`...........H.
fa 10 76 56 c5 f8 10 4c-16 f0 48 83 ea 20 76 2a ..vV...L..H.. v*
c5 fc 10 06 c5 fc 11 07-48 83 c6 20 48 83 c7 20 ........H.. H..
48 83 ea 20 72 14 c5 fc-10 06 c5 fc 11 07 48 83 H.. r.........H.
c6 20 48 83 c7 20 48 83-ea 20 48 83 c2 10 7e 0c . H.. H.. H...~.
Thread 0 last branch register state not available.
Binary Images:
0x1031e3000 - 0x10d9b6fff +org.blenderfoundation.blender (2.91.0 - 2.91.0 2020-11-25) <A18D3102-5B87-3997-9B07-0AAF11241DA7> /Applications/Blender/Blender Kopie.app/Contents/MacOS/Blender
0x114669000 - 0x1146d5fff +libomp.dylib (0) <535E76BC-1650-3651-9C62-97A995647107> /Applications/Blender/Blender Kopie.app/Contents/Resources/lib/libomp.dylib
0x116462000 - 0x116469fff com.apple.audio.AppleHDAHALPlugIn (283.15 - 283.15) <6756F98D-A178-326C-AE42-0794B528C2FB> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x11a572000 - 0x11a6d5fff com.apple.audio.units.Components (1.14 - 1.14) <79BEEEC4-3C3B-3C49-AF25-792C6CE5BF68> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x11a70e000 - 0x11acbdfff com.apple.audio.AudioDSPComponents (1.0 - 1) <6F81B244-A378-3A25-BFBB-5C3EFCF560B6> /System/Library/Components/AudioDSP.component/Contents/MacOS/AudioDSP
0x11b10f000 - 0x11b11efff libobjc-trampolines.dylib (818.2) <12B587A2-8631-3B7A-B862-5091C411AC2C> /usr/lib/libobjc-trampolines.dylib
0x11b1b1000 - 0x11b2b4fff com.apple.AMDRadeonX4000GLDriver (4.2.13 - 4.0.2) <D8B24B53-24A7-3E05-A134-F866E0ADE530> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver
0x11ec14000 - 0x11ec15fff +_heapq.cpython-37m-darwin.so (0) <20086BF0-0130-3463-B824-F98C6D51BE39> /Applications/Blender/Blender Kopie.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_heapq.cpython-37m-darwin.so
0x11ec1e000 - 0x11ec23fff +math.cpython-37m-darwin.so (0) <F76ADA60-2AAA-34A7-BB31-26405F501673> /Applications/Blender/Blender Kopie.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/math.cpython-37m-darwin.so
0x11ec30000 - 0x11ec35fff +_blake2.cpython-37m-darwin.so (0) <7FD886EF-36D2-329A-B8CE-AAF09D7269E8> /Applications/Blender/Blender Kopie.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_blake2.cpython-37m-darwin.so
0x11ec43000 - 0x11ecdefff dyld (832.7.1) <DEA51514-B4E8-3368-979B-89D0F8397ABC> /usr/lib/dyld
0x12484f000 - 0x124a68fff +_hashlib.cpython-37m-darwin.so (0) <C9C14775-5B8E-3512-98E0-537BF4984A54> /Applications/Blender/Blender Kopie.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_hashlib.cpython-37m-darwin.so
0x124b01000 - 0x124b11fff +_sha3.cpython-37m-darwin.so (0) <D7698BDC-8C9A-3198-81AD-6044B3FFB378> /Applications/Blender/Blender Kopie.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_sha3.cpython-37m-darwin.so
0x124b1c000 - 0x124b1cfff +_bisect.cpython-37m-darwin.so (0) <1F871C75-B7E3-3531-B4FD-9127E49825DD> /Applications/Blender/Blender Kopie.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_bisect.cpython-37m-darwin.so
0x124b24000 - 0x124b25fff +_random.cpython-37m-darwin.so (0) <6EA0F0A9-EB67-39B1-8BC9-CD20C494E8F6> /Applications/Blender/Blender Kopie.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_random.cpython-37m-darwin.so
0x124b6d000 - 0x124b73fff +_json.cpython-37m-darwin.so (0) <6C52949D-6062-3DBB-8601-8FC34D195603> /Applications/Blender/Blender Kopie.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_json.cpython-37m-darwin.so
0x124bfc000 - 0x124c0efff +zlib.cpython-37m-darwin.so (0) <8EF3CAAD-13A3-3C17-B25F-8F3D16F65850> /Applications/Blender/Blender Kopie.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/zlib.cpython-37m-darwin.so
0x124c19000 - 0x124c2ffff +_bz2.cpython-37m-darwin.so (0) <E0F8E75D-B92D-3624-ABAE-FAC3B29181F2> /Applications/Blender/Blender Kopie.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_bz2.cpython-37m-darwin.so
0x124c3a000 - 0x124c68fff +_lzma.cpython-37m-darwin.so (0) <B82293C1-035E-3C19-B6E1-E93BEB44DA1B> /Applications/Blender/Blender Kopie.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_lzma.cpython-37m-darwin.so
0x124c77000 - 0x124c77fff +grp.cpython-37m-darwin.so (0) <DEEAC15B-D065-3D28-9F79-32426A8C67B7> /Applications/Blender/Blender Kopie.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/grp.cpython-37m-darwin.so
0x124c7f000 - 0x124c83fff +_struct.cpython-37m-darwin.so (0) <AFC22996-5DC5-3B8F-B881-06BF3CE37AA9> /Applications/Blender/Blender Kopie.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_struct.cpython-37m-darwin.so
0x124c91000 - 0x124c97fff +binascii.cpython-37m-darwin.so (0) <03796BF6-3DC5-3C9B-9D69-32549A2602EB> /Applications/Blender/Blender Kopie.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/binascii.cpython-37m-darwin.so
0x125570000 - 0x125573fff com.apple.CloudDocsFileProvider (1.0 - 726) <89C091B1-BB9C-3919-8051-B8A86E94FC57> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/CloudDocsFileProvider.bundle/Contents/MacOS/CloudDocsFileProvider
0x12577a000 - 0x12577dfff com.apple.FileProviderOverride (326 - 326) <30A4FABB-09A9-3847-9097-C47264FE43CC> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FileProviderOverride.bundle/Contents/MacOS/FileProviderOverride
0x12580e000 - 0x125829fff com.apple.findersync.fileprovideroverride.FinderSyncCollaborationFileProviderOverride (1.0 - 1350.2.10) <13CEAF66-0099-3F21-B489-6DA4F088AB43> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FinderSyncCollaborationFileProviderOverride.bundle/Contents/MacOS/FinderSyncCollaborationFileProviderOverride
0x7fff2008d000 - 0x7fff2008efff libsystem_blocks.dylib (78) <9CF131C6-16FB-3DD0-B046-9E0B6AB99935> /usr/lib/system/libsystem_blocks.dylib
0x7fff2008f000 - 0x7fff200c4fff libxpc.dylib (2038.40.38) <003A027D-9CE3-3794-A319-88495844662D> /usr/lib/system/libxpc.dylib
0x7fff200c5000 - 0x7fff200dcfff libsystem_trace.dylib (1277.50.1) <48C14376-626E-3C81-B0F5-7416E64580C7> /usr/lib/system/libsystem_trace.dylib
0x7fff200dd000 - 0x7fff2017bfff libcorecrypto.dylib (1000.60.19) <92F0211E-506E-3760-A3C2-808BF3905C07> /usr/lib/system/libcorecrypto.dylib
0x7fff2017c000 - 0x7fff201a8fff libsystem_malloc.dylib (317.40.8) <2EF43B96-90FB-3C50-B73E-035238504E33> /usr/lib/system/libsystem_malloc.dylib
0x7fff201a9000 - 0x7fff201edfff libdispatch.dylib (1271.40.12) <CEF1460B-1362-381A-AE69-6BCE2D8C215B> /usr/lib/system/libdispatch.dylib
0x7fff201ee000 - 0x7fff20226fff libobjc.A.dylib (818.2) <45EA2DE2-B612-3486-B156-2359CE279159> /usr/lib/libobjc.A.dylib
0x7fff20227000 - 0x7fff20229fff libsystem_featureflags.dylib (28.60.1) <7B4EBDDB-244E-3F78-8895-566FE22288F3> /usr/lib/system/libsystem_featureflags.dylib
0x7fff2022a000 - 0x7fff202b2fff libsystem_c.dylib (1439.40.11) <06D9F593-C815-385D-957F-2B5BCC223A8A> /usr/lib/system/libsystem_c.dylib
0x7fff202b3000 - 0x7fff20308fff libc++.1.dylib (904.4) <AE3A940A-7A9C-3F99-B175-3511528D8DFE> /usr/lib/libc++.1.dylib
0x7fff20309000 - 0x7fff20321fff libc++abi.dylib (904.4) <DDFCBF9C-432D-3B8A-8641-578D2EDDCAD8> /usr/lib/libc++abi.dylib
0x7fff20322000 - 0x7fff20350fff libsystem_kernel.dylib (7195.60.75) <4BD61365-29AF-3234-8002-D989D295FDBB> /usr/lib/system/libsystem_kernel.dylib
0x7fff20351000 - 0x7fff2035cfff libsystem_pthread.dylib (454.60.1) <8DD3A0BC-2C92-31E3-BBAB-CE923A4342E4> /usr/lib/system/libsystem_pthread.dylib
0x7fff2035d000 - 0x7fff20397fff libdyld.dylib (832.7.1) <2F8A14F5-7CB8-3EDD-85EA-7FA960BBC04E> /usr/lib/system/libdyld.dylib
0x7fff20398000 - 0x7fff203a1fff libsystem_platform.dylib (254.60.1) <3F7F6461-7B5C-3197-ACD7-C8A0CFCC6F55> /usr/lib/system/libsystem_platform.dylib
0x7fff203a2000 - 0x7fff203cdfff libsystem_info.dylib (542.40.3) <0979757C-5F0D-3F5A-9E0E-EBF234B310AF> /usr/lib/system/libsystem_info.dylib
0x7fff203ce000 - 0x7fff20869fff com.apple.CoreFoundation (6.9 - 1770.300) <EAC298C4-CE3E-3551-A832-42ED9A13EF74> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff2086a000 - 0x7fff20a99fff com.apple.LaunchServices (1122.11 - 1122.11) <CAEEC254-68AE-39B5-8452-EC3E1EE8577B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff20a9a000 - 0x7fff20b6dfff com.apple.gpusw.MetalTools (1.0 - 1) <C235D5FA-0B9D-3E72-A8CE-67174E1B9E7C> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff20b6e000 - 0x7fff20dd1fff libBLAS.dylib (1336.40.1) <AD2D155C-1294-3D10-817A-F6A581E6ACF1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff20dd2000 - 0x7fff20e1ffff com.apple.Lexicon-framework (1.0 - 86.1) <D54364A6-1C4C-33D7-8B24-C753777B3654> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff20e20000 - 0x7fff20e8efff libSparse.dylib (106) <60559226-6E4B-3601-B6CA-E3B85B5EB27B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff20e8f000 - 0x7fff20f0cfff com.apple.SystemConfiguration (1.20 - 1.20) <8524EE4C-628F-315A-9531-44DD83CE275E> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff20f0d000 - 0x7fff20f42fff libCRFSuite.dylib (50) <6CA29EAA-0585-3682-9AD2-DFD3D87A74D4> /usr/lib/libCRFSuite.dylib
0x7fff20f43000 - 0x7fff2117afff libmecabra.dylib (929.1.1) <39F5AD50-3AF2-3CFB-BD21-2DC45AA92A91> /usr/lib/libmecabra.dylib
0x7fff2117b000 - 0x7fff214defff com.apple.Foundation (6.9 - 1770.300) <44A7115B-7FF0-3300-B61B-0FA71B63C715> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff214df000 - 0x7fff215cbfff com.apple.LanguageModeling (1.0 - 247.1) <BCB1F8A7-54B9-36D1-B742-70DF7657BF0B> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff215cc000 - 0x7fff21702fff com.apple.CoreDisplay (231.3 - 231.3) <229BF97A-1D56-3CB4-8338-E0D464F73A33> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff21703000 - 0x7fff21978fff com.apple.audio.AudioToolboxCore (1.0 - 1180.23) <56821802-07B9-3FA9-AF73-D943BAE0DE57> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
0x7fff21979000 - 0x7fff21b61fff com.apple.CoreText (677.2.0.5 - 677.2.0.5) <B0B2A8DD-A6F1-3EF7-9351-1BA604353A11> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff21b62000 - 0x7fff22205fff com.apple.audio.CoreAudio (5.0 - 5.0) <DF623EC9-FC55-3B3C-94FF-6A5C50A981B3> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff22206000 - 0x7fff22557fff com.apple.security (7.0 - 59754.60.13) <A20AB68D-51DA-340B-B813-F2AFC81F7143> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff22558000 - 0x7fff227b9fff libicucore.A.dylib (66109) <6C0A0196-2778-3035-81CE-7CA48D6C0628> /usr/lib/libicucore.A.dylib
0x7fff227ba000 - 0x7fff227c3fff libsystem_darwin.dylib (1439.40.11) <BD269412-C9D0-32EE-B42B-B09A187A9B95> /usr/lib/system/libsystem_darwin.dylib
0x7fff227c4000 - 0x7fff22aabfff com.apple.CoreServices.CarbonCore (1307 - 1307) <9C615967-6D8E-307F-B028-6278A4FA7C8C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff22aac000 - 0x7fff22aeafff com.apple.CoreServicesInternal (476 - 476) <FD1692F7-A4B4-3FE5-B9C8-E0840D53C7D0> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff22aeb000 - 0x7fff22b25fff com.apple.CSStore (1122.11 - 1122.11) <088D0108-AA14-3610-86A0-89D0C605384F> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
0x7fff22b26000 - 0x7fff22bd3fff com.apple.framework.IOKit (2.0.2 - 1845.60.2) <F2299682-5884-363F-9069-AA804E712C74> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff22bd4000 - 0x7fff22bdffff libsystem_notify.dylib (279.40.4) <98D74EEF-60D9-3665-B877-7BE1558BA83E> /usr/lib/system/libsystem_notify.dylib
0x7fff22be0000 - 0x7fff22c2bfff libsandbox.1.dylib (1441.60.4) <243C983D-0AEF-3A09-9489-CF1FC75925CC> /usr/lib/libsandbox.1.dylib
0x7fff22c2c000 - 0x7fff2398efff com.apple.AppKit (6.9 - 2022.20.119) <4CB42914-672D-3AF0-A0A5-2209088A3DA0> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff2398f000 - 0x7fff23be2fff com.apple.UIFoundation (1.0 - 726.11) <71C63CE5-094D-34AF-B538-8DCAB3B66DE9> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff23be3000 - 0x7fff23bf5fff com.apple.UniformTypeIdentifiers (633.0.2 - 633.0.2) <7BEC7DDC-2B7A-3B5D-B994-5FA352FC485A> /System/Library/Frameworks/UniformTypeIdentifiers.framework/Versions/A/UniformTypeIdentifiers
0x7fff23bf6000 - 0x7fff23d80fff com.apple.desktopservices (1.17 - 1346.2.1) <732C8A0C-E7F8-372D-AE5B-84497067135E> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff23d81000 - 0x7fff23d93fff com.apple.metadata.SpotlightLinguistics (1.0 - 1) <C49ACE74-8DBC-300C-8A31-FD95FE8BC03A> /System/Library/PrivateFrameworks/SpotlightLinguistics.framework/Versions/A/SpotlightLinguistics
0x7fff23d94000 - 0x7fff23f91fff com.apple.CoreDuet (1.0 - 1) <A8010564-458F-310D-A165-0CA0C734CBBF> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
0x7fff2404d000 - 0x7fff24690fff libnetwork.dylib (2288.60.5) <180FE916-8DD6-3385-B231-0C423B7D2BD3> /usr/lib/libnetwork.dylib
0x7fff24691000 - 0x7fff24b2efff com.apple.CFNetwork (1209.1 - 1209.1) <60DE4CD6-B5AF-3E0E-8AF1-39ECFC1B8C98> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff24b2f000 - 0x7fff24b3dfff libsystem_networkextension.dylib (1295.60.5) <F476B1CB-3561-30C5-A78E-44E99B1720A3> /usr/lib/system/libsystem_networkextension.dylib
0x7fff24b3e000 - 0x7fff24b3efff libenergytrace.dylib (22) <9BE5E51A-F531-3D59-BBBC-486FFF97BD30> /usr/lib/libenergytrace.dylib
0x7fff24b3f000 - 0x7fff24b9afff libMobileGestalt.dylib (978.60.2) <F721B185-0E6A-396B-A50F-0F55810D9A67> /usr/lib/libMobileGestalt.dylib
0x7fff24b9b000 - 0x7fff24bb1fff libsystem_asl.dylib (385) <940C5BB9-4928-3A63-97F2-132797C8B7E5> /usr/lib/system/libsystem_asl.dylib
0x7fff24bb2000 - 0x7fff24bc9fff com.apple.TCC (1.0 - 1) <457D5F24-A346-38FC-8FA1-43B0C835E035> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff24bca000 - 0x7fff24f2ffff com.apple.SkyLight (1.600.0 - 569.6) <35876384-45F9-3C62-995B-38EC31BE75D7> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff24f30000 - 0x7fff255c3fff com.apple.CoreGraphics (2.0 - 1463.2.2) <323F725F-CB03-3AAD-AFBC-37B430B3FD4E> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff255c4000 - 0x7fff256bafff com.apple.ColorSync (4.13.0 - 3472) <7387EBC7-CBD9-34FE-B4A3-345E4750FD81> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff256bb000 - 0x7fff25716fff com.apple.HIServices (1.22 - 713) <9AF2CDD9-8B68-3606-8C9E-1842420ACDA7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff25809000 - 0x7fff259cdfff com.apple.Montreal (1.0 - 142) <63CE0363-8DDC-3D97-A063-7840B02F3F58> /System/Library/PrivateFrameworks/Montreal.framework/Versions/A/Montreal
0x7fff25ac2000 - 0x7fff25ee0fff com.apple.CoreData (120 - 1044.3) <76179A55-CA89-3967-A0A7-C419DB735983> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff25ee1000 - 0x7fff25ef7fff com.apple.ProtocolBuffer (1 - 285.20.8.8.1) <8EE538E7-2BB1-3E29-8FC3-938335998B22> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff25ef8000 - 0x7fff260b7fff libsqlite3.dylib (321.1) <D7017429-8D46-3ECB-8B70-4625C74918F3> /usr/lib/libsqlite3.dylib
0x7fff260b8000 - 0x7fff26134fff com.apple.Accounts (113 - 113) <99421243-019F-3A2F-A671-092026FA2F74> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fff26135000 - 0x7fff2614dfff com.apple.commonutilities (8.0 - 900) <76711775-FF46-38CA-88F3-B4201C285C7F> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
0x7fff2614e000 - 0x7fff261cffff com.apple.BaseBoard (526 - 526) <38C24B3A-8226-3FD5-8C28-B11D02747B56> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
0x7fff261d0000 - 0x7fff2621bfff com.apple.RunningBoardServices (1.0 - 505.60.2) <F99A0D0C-D063-3E3F-8D1F-0E0B35E7CE2C> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
0x7fff2621c000 - 0x7fff26291fff com.apple.AE (918.0.1 - 918.0.1) <3A298716-A130-345E-B8FF-74194849015E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff26292000 - 0x7fff26298fff libdns_services.dylib (1310.60.4) <61EB26AD-C09E-3140-955E-16BF7DD2D6E3> /usr/lib/libdns_services.dylib
0x7fff26299000 - 0x7fff262a0fff libsystem_symptoms.dylib (1431.60.1) <88F35AAC-746F-3176-81DF-49CE3D285636> /usr/lib/system/libsystem_symptoms.dylib
0x7fff262a1000 - 0x7fff26425fff com.apple.Network (1.0 - 1) <EED4099E-B17C-3E0B-AA8F-78A2D4F26CBF> /System/Library/Frameworks/Network.framework/Versions/A/Network
0x7fff26426000 - 0x7fff2644afff com.apple.analyticsd (1.0 - 1) <99FE0234-454F-36FF-9DE9-36B94D8753F9> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
0x7fff2644b000 - 0x7fff2644dfff libDiagnosticMessagesClient.dylib (112) <1014A32B-89EE-3ADD-971F-9CB973172F69> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff2644e000 - 0x7fff2649afff com.apple.spotlight.metadata.utilities (1.0 - 2150.7.2) <37A1E760-2006-366C-9FAC-FB70227393FB> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0x7fff2649b000 - 0x7fff26535fff com.apple.Metadata (10.7.0 - 2150.7.2) <509C6597-ABB2-3B81-8E09-C51A755CCDA2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff26536000 - 0x7fff2653cfff com.apple.DiskArbitration (2.7 - 2.7) <83DED679-BE65-3475-8AFF-D664BBAFA60A> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff2653d000 - 0x7fff26be3fff com.apple.vImage (8.1 - 544) <305D97CC-B47C-32FD-9EC5-43259A469A14> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff26be4000 - 0x7fff26eb1fff com.apple.QuartzCore (1.11 - 925.5) <D59138DC-10CD-3DF8-9F04-CCDB6102C370> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff26eb2000 - 0x7fff26ef3fff libFontRegistry.dylib (309) <790676A3-2B74-3239-A60D-429069933542> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff26ef4000 - 0x7fff27035fff com.apple.coreui (2.1 - 689.4) <0DA8F4E0-9473-374E-8B48-F0A40AEC63CE> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff27036000 - 0x7fff27121fff com.apple.ViewBridge (551.3 - 551.3) <36D0DCA7-CAAE-33C1-90F6-98876CB8BCF3> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff27122000 - 0x7fff2712dfff com.apple.PerformanceAnalysis (1.275 - 275) <2F811EE6-D4D4-347E-B4A0-961F0DF050E5> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff2712e000 - 0x7fff2713dfff com.apple.OpenDirectory (11.1 - 230.40.1) <7710743E-6F55-342E-88FA-18796CF83700> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff2713e000 - 0x7fff2715dfff com.apple.CFOpenDirectory (11.1 - 230.40.1) <32ECCB06-56D8-3704-935B-7D5363B2988E> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff2715e000 - 0x7fff27166fff com.apple.CoreServices.FSEvents (1290.40.2 - 1290.40.2) <FB18B8D7-C7F5-3CAB-B538-3F4B4E85D1F1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff27167000 - 0x7fff2718bfff com.apple.coreservices.SharedFileList (144 - 144) <93D2192D-7A27-3FD4-B3AB-A4DCBF8419B7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff2718c000 - 0x7fff2718efff libapp_launch_measurement.dylib (14.1) <9E2700C3-E993-3695-988E-FEF798B75E34> /usr/lib/libapp_launch_measurement.dylib
0x7fff2718f000 - 0x7fff271d7fff com.apple.CoreAutoLayout (1.0 - 21.10.1) <998BC461-F4F5-396E-9798-1C8126AD61DA> /System/Library/PrivateFrameworks/CoreAutoLayout.framework/Versions/A/CoreAutoLayout
0x7fff271d8000 - 0x7fff272bafff libxml2.2.dylib (34.8) <68396181-8100-390C-8886-EFB79F5B484C> /usr/lib/libxml2.2.dylib
0x7fff272bb000 - 0x7fff27307fff com.apple.CoreVideo (1.8 - 408.4) <0D5AD16E-A871-3ACB-B910-39B87928E937> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff27308000 - 0x7fff2730afff com.apple.loginsupport (1.0 - 1) <4F860927-F6F5-3A99-A103-744CF365634F> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff2730b000 - 0x7fff27333fff com.apple.aps.framework (4.0 - 4.0) <F8FAEB30-AFCF-36A1-9E72-25681E6C5BF7> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff27334000 - 0x7fff27351fff com.apple.UserManagement (1.0 - 1) <B5CEAA26-4C5F-3AF4-BDFE-35DE7C8DE1BE> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
0x7fff27352000 - 0x7fff274f1fff com.apple.cloudkit.CloudKit (962 - 962) <2D82071D-495C-3E80-BF3C-CB181FECB500> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff274f2000 - 0x7fff27574fff com.apple.CloudDocs (1.0 - 726) <C6CB66A3-64B6-31C5-BA53-8F564D4D5719> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff27575000 - 0x7fff2791afff com.apple.CoreML (1.0 - 1) <5D76FA8E-9335-3ED8-B301-E0313128307E> /System/Library/Frameworks/CoreML.framework/Versions/A/CoreML
0x7fff2826e000 - 0x7fff282eafff com.apple.corelocation (2420.12.12 - 2420.12.12) <F4C3D15D-BEFE-37A9-A55F-2BFB16842FBE> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff282eb000 - 0x7fff282fbfff libsystem_containermanager.dylib (318.60.1) <4ED09A19-04CC-3464-9EFB-F674932020B5> /usr/lib/system/libsystem_containermanager.dylib
0x7fff282fc000 - 0x7fff2830dfff com.apple.IOSurface (289.3 - 289.3) <A3B10665-5909-30EE-BE34-F3284D6D5975> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff2830e000 - 0x7fff28316fff com.apple.IOAccelerator (439.52 - 439.52) <3944C92D-7838-3D2F-A453-9DB15C815D7B> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff28317000 - 0x7fff2843cfff com.apple.Metal (244.32.7 - 244.32.7) <413B81AE-653F-3CF7-B5A4-A4391436E6D1> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff2843d000 - 0x7fff28459fff com.apple.audio.caulk (1.0 - 70) <952BA9D4-BAD3-3319-8C17-F7BB2655F80C> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
0x7fff2845a000 - 0x7fff28543fff com.apple.CoreMedia (1.0 - 2760.6.4.6) <CBCD783B-B3C9-37B8-835C-A3BACEC35BB5> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff28544000 - 0x7fff286a0fff libFontParser.dylib (305.2.0.6) <76C6C92A-1B16-3FB7-9EA2-7227D379C20F> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
0x7fff286a1000 - 0x7fff289a0fff com.apple.HIToolbox (2.1.1 - 1060.4) <93518490-429F-3E31-8344-15D479C2F4CE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff289a1000 - 0x7fff289b4fff com.apple.framework.DFRFoundation (1.0 - 265) <FB85651D-6221-38AF-BD6D-29BFF5830D36> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff289b5000 - 0x7fff289b8fff com.apple.dt.XCTTargetBootstrap (1.0 - 17500) <13ADD312-F6F5-3C03-BD3B-9331B3851285> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
0x7fff289b9000 - 0x7fff289e2fff com.apple.CoreSVG (1.0 - 149) <A0DAE6AE-9DDA-37B4-A087-545A242CF982> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
0x7fff289e3000 - 0x7fff28c1cfff com.apple.ImageIO (3.3.0 - 2130.2.7) <0FE3D51B-EC76-3558-BD56-7BFF61A6793D> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff28c1d000 - 0x7fff28f9afff com.apple.CoreImage (16.1.0 - 1120.10) <46F1E4F5-DF8F-32D4-8D0C-6FCF2C27A5CD> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff28f9b000 - 0x7fff28ff6fff com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <E2377275-53D7-31A0-AEAF-0A0273B99B92> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff28ff7000 - 0x7fff28ffafff libsystem_configuration.dylib (1109.60.2) <C57B346B-0A03-3F87-BCAC-87B702FA0719> /usr/lib/system/libsystem_configuration.dylib
0x7fff28ffb000 - 0x7fff28ffffff libsystem_sandbox.dylib (1441.60.4) <8CE27199-D633-31D2-AB08-56380A1DA9FB> /usr/lib/system/libsystem_sandbox.dylib
0x7fff29000000 - 0x7fff29001fff com.apple.AggregateDictionary (1.0 - 1) <7F2AFEBB-FF06-3194-B691-B411F3456962> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
0x7fff29002000 - 0x7fff29005fff com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <250CD2CA-E796-3CB0-9ADD-054998903B1D> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff29006000 - 0x7fff29007fff liblangid.dylib (136) <224DC045-2B60-39AF-B89E-E524175667F5> /usr/lib/liblangid.dylib
0x7fff29008000 - 0x7fff290a8fff com.apple.CoreNLP (1.0 - 245) <F876FD71-F077-3CF7-B94D-9E05A17E03D7> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff290a9000 - 0x7fff290affff com.apple.LinguisticData (1.0 - 399) <D1B7F1D5-EB9E-3555-BA57-3611FA153C44> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff290b0000 - 0x7fff2976cfff libBNNS.dylib (288.60.2) <E3FF47D5-7DD9-3A9E-A819-C79B0CC17C03> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff2976d000 - 0x7fff29940fff libvDSP.dylib (760.40.6) <9434101D-E001-357F-9503-9896C6011F52> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff29941000 - 0x7fff29953fff com.apple.CoreEmoji (1.0 - 128) <7CCFC59A-8746-3E52-AF1D-1B67798E940C> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff29954000 - 0x7fff2995efff com.apple.IOMobileFramebuffer (343.0.0 - 343.0.0) <9A6F913C-EC79-3FC1-A92C-3A1BA96D8DFB> /System/Library/PrivateFrameworks/IOMobileFramebuffer.framework/Versions/A/IOMobileFramebuffer
0x7fff2995f000 - 0x7fff29a31fff com.apple.framework.CoreWLAN (16.0 - 1657) <AB3F880B-52C5-3006-82FE-9E6857C09DE7> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff29a32000 - 0x7fff29c31fff com.apple.CoreUtils (6.5 - 650.5) <198A4273-5B92-3A05-A99D-7FD4914A959A> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff29c32000 - 0x7fff29c54fff com.apple.MobileKeyBag (2.0 - 1.0) <2B6BF51A-68B0-3108-9597-8B618E6B457B> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff29c55000 - 0x7fff29c65fff com.apple.AssertionServices (1.0 - 505.60.2) <9F8620BD-A58D-3A42-9B9E-DEC21517EF1A> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
0x7fff29c66000 - 0x7fff29cf2fff com.apple.securityfoundation (6.0 - 55240.40.4) <5F06D141-62F4-3405-BA72-24673B170A16> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff29cf3000 - 0x7fff29cfcfff com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <C5E4B35C-FFDA-3423-890F-06DAD1F684F5> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff29cfd000 - 0x7fff29d01fff com.apple.xpc.ServiceManagement (1.0 - 1) <2C03BEB7-915C-3A3A-A44F-A77775E1BFD5> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff29d02000 - 0x7fff29d04fff libquarantine.dylib (119.40.2) <19D42B9D-3336-3543-AF75-6E605EA31599> /usr/lib/system/libquarantine.dylib
0x7fff29d05000 - 0x7fff29d10fff libCheckFix.dylib (31) <3381FC93-F188-348C-9345-5567A7116CEF> /usr/lib/libCheckFix.dylib
0x7fff29d11000 - 0x7fff29d28fff libcoretls.dylib (169) <9C244029-6B45-3583-B27F-BB7BBF84D814> /usr/lib/libcoretls.dylib
0x7fff29d29000 - 0x7fff29d39fff libbsm.0.dylib (68.40.1) <DC652D50-FA69-3801-9361-004D4D6832D0> /usr/lib/libbsm.0.dylib
0x7fff29d3a000 - 0x7fff29d83fff libmecab.dylib (929.1.1) <B5D8C96C-D3B8-32F8-84F9-A432CEAD4E5C> /usr/lib/libmecab.dylib
0x7fff29d84000 - 0x7fff29d89fff libgermantok.dylib (24) <F9772A76-7AFA-3E0B-A02C-A61FC6CA8D8B> /usr/lib/libgermantok.dylib
0x7fff29d8a000 - 0x7fff29d9ffff libLinearAlgebra.dylib (1336.40.1) <D2826FAB-174C-3CD6-A765-06D83A9A0EDB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff29da0000 - 0x7fff29fc7fff com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <231CF580-952A-32BC-A423-9B9756AC9744> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff29fc8000 - 0x7fff2a017fff com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <65A993E4-3DC2-3152-98D5-A1DF3DB4573F> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
0x7fff2a018000 - 0x7fff2a15efff com.apple.MLCompute (1.0 - 1) <BCEA1149-197E-398F-9424-E29B0AD0829F> /System/Library/Frameworks/MLCompute.framework/Versions/A/MLCompute
0x7fff2a15f000 - 0x7fff2a195fff com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <F719DA57-EAAA-3527-B859-21025722932F> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff2a196000 - 0x7fff2a1d3fff com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <FCCC0D3F-74D2-3107-82B3-E2B500E36AAE> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
0x7fff2a1d4000 - 0x7fff2a264fff com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <21527A17-2D6F-3BDF-9A74-F90FA6E26BB3> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff2a265000 - 0x7fff2a274fff com.apple.AppleFSCompression (125 - 1.0) <D1E7DC71-1929-30A8-B73E-268387110608> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff2a275000 - 0x7fff2a282fff libbz2.1.0.dylib (44) <0575C0D0-B107-3E53-857F-DEC55998197B> /usr/lib/libbz2.1.0.dylib
0x7fff2a283000 - 0x7fff2a287fff libsystem_coreservices.dylib (127) <A2D875B9-8BA8-33AD-BE92-ADAB915A8D5B> /usr/lib/system/libsystem_coreservices.dylib
0x7fff2a288000 - 0x7fff2a2b5fff com.apple.CoreServices.OSServices (1122.11 - 1122.11) <870F34BE-C0ED-318B-858D-5F1E4757D552> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff2a2b6000 - 0x7fff2a3e7fff com.apple.AuthKit (1.0 - 1) <8239C235-54DE-39F3-98DC-920AF2BE6187> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff2a48b000 - 0x7fff2a49dfff libz.1.dylib (76) <9F89FD60-03F7-3175-AB34-5112B99E2B8A> /usr/lib/libz.1.dylib
0x7fff2a49e000 - 0x7fff2a4e5fff libsystem_m.dylib (3186.40.2) <79820D9E-0FF1-3F20-AF4F-F87EE20CE8C9> /usr/lib/system/libsystem_m.dylib
0x7fff2a4e6000 - 0x7fff2a4e6fff libcharset.1.dylib (59) <414F6A1C-1EBC-3956-AC2D-CCB0458F31AF> /usr/lib/libcharset.1.dylib
0x7fff2a4e7000 - 0x7fff2a4ecfff libmacho.dylib (973.4) <28AE1649-22ED-3C4D-A232-29D37F821C39> /usr/lib/system/libmacho.dylib
0x7fff2a4ed000 - 0x7fff2a508fff libkxld.dylib (7195.60.75) <3600A314-332A-343D-B45D-D9D8B302545D> /usr/lib/system/libkxld.dylib
0x7fff2a509000 - 0x7fff2a514fff libcommonCrypto.dylib (60178.40.2) <1D0A75A5-DEC5-39C6-AB3D-E789B8866712> /usr/lib/system/libcommonCrypto.dylib
0x7fff2a515000 - 0x7fff2a51ffff libunwind.dylib (200.10) <C5792A9C-DF0F-3821-BC14-238A78462E8A> /usr/lib/system/libunwind.dylib
0x7fff2a520000 - 0x7fff2a527fff liboah.dylib (203.13.2) <FF72E19B-3B02-34D4-A821-3397BB28AC02> /usr/lib/liboah.dylib
0x7fff2a528000 - 0x7fff2a532fff libcopyfile.dylib (173.40.2) <89483CD4-DA46-3AF2-AE78-FC37CED05ACC> /usr/lib/system/libcopyfile.dylib
0x7fff2a533000 - 0x7fff2a53afff libcompiler_rt.dylib (102.2) <0DB26EC8-B4CD-3268-B865-C2FC07E4D2AA> /usr/lib/system/libcompiler_rt.dylib
0x7fff2a53b000 - 0x7fff2a53dfff libsystem_collections.dylib (1439.40.11) <D40D8097-0ABF-3645-B065-168F43ACFF4C> /usr/lib/system/libsystem_collections.dylib
0x7fff2a53e000 - 0x7fff2a540fff libsystem_secinit.dylib (87.60.1) <99B5FD99-1A8B-37C1-BD70-04990FA33B1C> /usr/lib/system/libsystem_secinit.dylib
0x7fff2a541000 - 0x7fff2a543fff libremovefile.dylib (49.40.3) <750012C2-7097-33C3-B796-2766E6CDE8C1> /usr/lib/system/libremovefile.dylib
0x7fff2a544000 - 0x7fff2a544fff libkeymgr.dylib (31) <2C7B58B0-BE54-3A50-B399-AA49C19083A9> /usr/lib/system/libkeymgr.dylib
0x7fff2a545000 - 0x7fff2a54cfff libsystem_dnssd.dylib (1310.60.4) <81EFC44D-450E-3AA3-AC8F-D7EF68F464B4> /usr/lib/system/libsystem_dnssd.dylib
0x7fff2a54d000 - 0x7fff2a552fff libcache.dylib (83) <2F7F7303-DB23-359E-85CD-8B2F93223E2A> /usr/lib/system/libcache.dylib
0x7fff2a553000 - 0x7fff2a554fff libSystem.B.dylib (1292.60.1) <A7FB4899-9E04-37ED-9DD8-8FFF0400879C> /usr/lib/libSystem.B.dylib
0x7fff2a555000 - 0x7fff2a558fff libfakelink.dylib (3) <34B6DC95-E19A-37C0-B9D0-558F692D85F5> /usr/lib/libfakelink.dylib
0x7fff2a559000 - 0x7fff2a559fff com.apple.SoftLinking (1.0 - 1) <90D679B3-DFFD-3604-B89F-1BCF70B3EBA4> /System/Library/PrivateFrameworks/SoftLinking.framework/Versions/A/SoftLinking
0x7fff2a55a000 - 0x7fff2a591fff libpcap.A.dylib (98.40.1) <E1995A1C-7EEB-3340-B1E1-DD45FA625C12> /usr/lib/libpcap.A.dylib
0x7fff2a592000 - 0x7fff2a682fff libiconv.2.dylib (59) <3E53F735-1D7E-3ABB-BC45-AAA37F535830> /usr/lib/libiconv.2.dylib
0x7fff2a683000 - 0x7fff2a694fff libcmph.dylib (8) <865FA425-831D-3E49-BD1B-14188D2A98AA> /usr/lib/libcmph.dylib
0x7fff2a695000 - 0x7fff2a706fff libarchive.2.dylib (83.40.4) <76B2F421-5335-37FB-9CD5-1018878B9E74> /usr/lib/libarchive.2.dylib
0x7fff2a707000 - 0x7fff2a76efff com.apple.SearchKit (1.4.1 - 1.4.1) <7BDD2800-BDDC-3DE0-A4A8-B1E855130E3B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff2a76f000 - 0x7fff2a770fff libThaiTokenizer.dylib (3) <513547CD-5C7F-37BE-A2AD-55A22F279588> /usr/lib/libThaiTokenizer.dylib
0x7fff2a771000 - 0x7fff2a798fff com.apple.applesauce (1.0 - 16.26) <AE525243-2CE7-373E-994E-C2457611EB3C> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff2a799000 - 0x7fff2a7b0fff libapple_nghttp2.dylib (1.41) <CC004768-6E3B-3D80-9431-61149EBE2E10> /usr/lib/libapple_nghttp2.dylib
0x7fff2a7b1000 - 0x7fff2a7c3fff libSparseBLAS.dylib (1336.40.1) <CEBD7B0F-A54D-3A43-BD7E-E8BC2C7B7F0C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff2a7c4000 - 0x7fff2a7c5fff com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <1BFEB124-CF05-342F-BC65-B233EAB661D9> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff2a7c6000 - 0x7fff2a7cafff libpam.2.dylib (28.40.1) <AE84F5FA-DDB0-3028-AF25-D6B6A12DBA6A> /usr/lib/libpam.2.dylib
0x7fff2a7cb000 - 0x7fff2a7e3fff libcompression.dylib (96.40.6) <45B8B821-8EB6-34FE-92E9-5CBA474499E2> /usr/lib/libcompression.dylib
0x7fff2a7e4000 - 0x7fff2a7e9fff libQuadrature.dylib (7) <FB21F53D-4A40-327F-BD3B-C7C8D08C6A86> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff2a7ea000 - 0x7fff2ab86fff libLAPACK.dylib (1336.40.1) <509FBCC6-4ECB-3192-98A6-D0C030E4E9D8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff2ab87000 - 0x7fff2abd5fff com.apple.DictionaryServices (1.2 - 341) <83CDCE83-6B48-35F1-BACF-83240D940777> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff2abd6000 - 0x7fff2abeefff liblzma.5.dylib (16) <A45348BC-AA9C-39D6-A7C3-2246A3EFA34C> /usr/lib/liblzma.5.dylib
0x7fff2abef000 - 0x7fff2abf0fff libcoretls_cfhelpers.dylib (169) <C0F19E92-DACB-3100-8610-62DEC5E5FB81> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff2abf1000 - 0x7fff2aceafff com.apple.APFS (1677.60.23 - 1677.60.23) <8271EE40-CDF5-3E0B-9F42-B49DC7C46C98> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff2aceb000 - 0x7fff2acf8fff libxar.1.dylib (452) <3F3DA942-DC7B-31EF-BCF1-38F99F59A660> /usr/lib/libxar.1.dylib
0x7fff2acf9000 - 0x7fff2acfcfff libutil.dylib (58.40.2) <85CF2B3B-6BEB-381D-8683-1DE2B0167ECC> /usr/lib/libutil.dylib
0x7fff2acfd000 - 0x7fff2ad25fff libxslt.1.dylib (17.2) <2C881E82-6E2C-3E92-8DC5-3C2D05FE7C95> /usr/lib/libxslt.1.dylib
0x7fff2ad26000 - 0x7fff2ad30fff libChineseTokenizer.dylib (37) <36891BB5-4A83-33A3-9995-CC5DB2AB53CE> /usr/lib/libChineseTokenizer.dylib
0x7fff2ad31000 - 0x7fff2adeffff libvMisc.dylib (760.40.6) <219319E1-BDBD-34D1-97B7-E46256785D3C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff2adf0000 - 0x7fff2ae88fff libate.dylib (3.0.4) <51D50D08-F614-3929-AFB1-BF4ED9BE4751> /usr/lib/libate.dylib
0x7fff2ae89000 - 0x7fff2ae90fff libIOReport.dylib (64) <3C26FBDC-931E-3318-8225-C10849CF1D60> /usr/lib/libIOReport.dylib
0x7fff2ae91000 - 0x7fff2aebffff com.apple.CrashReporterSupport (10.13 - 15047) <5377E0C9-5D89-38C0-B129-1A086716F3E9> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff2aed7000 - 0x7fff2af57fff com.apple.CVNLP (1.0 - 119) <61007388-7D6A-3B8A-B418-8F7FC07D874F> /System/Library/PrivateFrameworks/CVNLP.framework/Versions/A/CVNLP
0x7fff2af76000 - 0x7fff2afabfff com.apple.pluginkit.framework (1.0 - 1) <68A4C478-DE41-3693-BD64-5A8D0F4F316E> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
0x7fff2afac000 - 0x7fff2afb3fff libMatch.1.dylib (38) <DC1E67E0-2690-3EE0-840D-461DA2980D9D> /usr/lib/libMatch.1.dylib
0x7fff2afb4000 - 0x7fff2b03ffff libCoreStorage.dylib (554) <8EEB1047-EFC1-3C1B-8E33-A446EB043AD5> /usr/lib/libCoreStorage.dylib
0x7fff2b040000 - 0x7fff2b093fff com.apple.AppleVAFramework (6.1.3 - 6.1.3) <8A5B1C42-DD83-303B-85DE-754FB6C10E1A> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff2b094000 - 0x7fff2b0adfff libexpat.1.dylib (26) <4408FC72-BDAA-33AE-BE14-4008642794ED> /usr/lib/libexpat.1.dylib
0x7fff2b0ae000 - 0x7fff2b0b7fff libheimdal-asn1.dylib (597.40.10) <032931C8-B042-3B3D-93D3-5B3E27431FEA> /usr/lib/libheimdal-asn1.dylib
0x7fff2b0b8000 - 0x7fff2b0ccfff com.apple.IconFoundation (479.3 - 479.3) <650C91C9-D6A1-3FF7-964B-DE1065F2243C> /System/Library/PrivateFrameworks/IconFoundation.framework/Versions/A/IconFoundation
0x7fff2b0cd000 - 0x7fff2b13afff com.apple.IconServices (479.3 - 479.3) <63CAB1AB-C485-382A-9088-F6E3937BB8E9> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff2b13b000 - 0x7fff2b1d8fff com.apple.MediaExperience (1.0 - 1) <A7A754CE-61AB-39B8-AA31-3AEB14695F55> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
0x7fff2b1d9000 - 0x7fff2b202fff com.apple.persistentconnection (1.0 - 1.0) <C3F975D3-A87C-353C-BA1F-072825E60E8C> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
0x7fff2b203000 - 0x7fff2b211fff com.apple.GraphVisualizer (1.0 - 100.1) <7035CCDF-5B9D-365C-A1FA-1D961EBEE44D> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff2b212000 - 0x7fff2b62dfff com.apple.vision.FaceCore (4.3.2 - 4.3.2) <E0518821-B65D-31A4-8C37-DF3569CF8867> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff2b62e000 - 0x7fff2b678fff com.apple.OTSVG (1.0 - 677.2.0.5) <D2722431-6C71-3144-A024-6ED06334AEE0> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
0x7fff2b679000 - 0x7fff2b67ffff com.apple.xpc.AppServerSupport (1.0 - 2038.40.38) <27B96AA0-421E-3E5A-B9D8-9BA3F0D133E9> /System/Library/PrivateFrameworks/AppServerSupport.framework/Versions/A/AppServerSupport
0x7fff2b680000 - 0x7fff2b691fff libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <CAD78803-0F56-316E-A7F1-D2BF26CA2DD6> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
0x7fff2b692000 - 0x7fff2b694fff libspindump.dylib (295) <C6F804A3-5682-3766-A324-76667364873D> /usr/lib/libspindump.dylib
0x7fff2b695000 - 0x7fff2b755fff com.apple.Heimdal (4.0 - 2.0) <8BB18335-5DD3-3154-85C8-0145C64556A2> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff2b756000 - 0x7fff2b770fff com.apple.login (3.0 - 3.0) <343A182A-F6C9-366E-BF0C-2124E5367F19> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
0x7fff2b771000 - 0x7fff2b843fff com.apple.corebrightness (1.0 - 1) <3B80FA12-C9F6-3171-86AC-1054F435F7E3> /System/Library/PrivateFrameworks/CoreBrightness.framework/Versions/A/CoreBrightness
0x7fff2b8f0000 - 0x7fff2b8f3fff libodfde.dylib (26) <E653BDF5-2C86-3FFB-928A-2D86B3D661E5> /usr/lib/libodfde.dylib
0x7fff2b8f4000 - 0x7fff2b95efff com.apple.bom (14.0 - 233) <A62EEEE5-3027-3F25-BCD9-32D36922106E> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff2b95f000 - 0x7fff2b9a9fff com.apple.AppleJPEG (1.0 - 1) <A2E9E2A4-AEDC-3481-BDC9-05D9AD84FC25> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff2b9aa000 - 0x7fff2ba88fff libJP2.dylib (2130.2.7) <9D837C01-3D6C-3D71-8E92-3673CE06A21F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff2ba89000 - 0x7fff2ba8cfff com.apple.WatchdogClient.framework (1.0 - 98.60.1) <8374BBBB-65CB-3D46-9AD6-0DD1FB99AD88> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
0x7fff2ba8d000 - 0x7fff2bac0fff com.apple.MultitouchSupport.framework (4400.28 - 4400.28) <E9A95272-5E84-3B64-8263-8C7F84456269> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff2bac1000 - 0x7fff2bc13fff com.apple.VideoToolbox (1.0 - 2760.6.4.6) <35098775-A188-3BE0-B0B1-7CE0027BA295> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff2bc14000 - 0x7fff2bc46fff libAudioToolboxUtility.dylib (1180.23) <58B4505B-F0EA-37FC-9F5A-6F9F05B0F2A5> /usr/lib/libAudioToolboxUtility.dylib
0x7fff2bc47000 - 0x7fff2bc6dfff libPng.dylib (2130.2.7) <1F3FED3B-FB07-3F43-8EAD-6100017FBAB5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff2bc6e000 - 0x7fff2bccbfff libTIFF.dylib (2130.2.7) <27E9A2D3-003D-3D97-AD85-BE595EA0516F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff2bccc000 - 0x7fff2bce6fff com.apple.IOPresentment (53 - 37) <070919DC-978E-3DB3-80FD-FB0C1BAAE80A> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff2bce7000 - 0x7fff2bcedfff com.apple.GPUWrangler (6.2.2 - 6.2.2) <F4B3905F-C024-33C1-82C8-F1744AF8516E> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff2bcee000 - 0x7fff2bcf1fff libRadiance.dylib (2130.2.7) <7ABF94D2-5281-363F-A613-9C945D77AAE8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff2bcf2000 - 0x7fff2bcf7fff com.apple.DSExternalDisplay (3.1 - 380) <BA802582-F1EB-35B8-902F-3D0F426124E0> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff2bcf8000 - 0x7fff2bd1cfff libJPEG.dylib (2130.2.7) <FDD55379-6673-31E4-B916-7949459B60AE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff2bd1d000 - 0x7fff2bd4cfff com.apple.ATSUI (1.0 - 1) <B82D099B-4F53-3B60-8BAA-975C41EFD356> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
0x7fff2bd4d000 - 0x7fff2bd51fff libGIF.dylib (2130.2.7) <C51FB0BA-E5C0-335B-9C64-185B1DDC9166> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff2bd52000 - 0x7fff2bd5bfff com.apple.CMCaptureCore (1.0 - 80.17.1.1) <A0D43E58-B960-3A80-8807-4115F0E1EF74> /System/Library/PrivateFrameworks/CMCaptureCore.framework/Versions/A/CMCaptureCore
0x7fff2bd5c000 - 0x7fff2bda3fff com.apple.print.framework.PrintCore (16 - 531) <FC56A643-F502-3578-9EFF-375BE6B87691> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff2bda4000 - 0x7fff2be70fff com.apple.TextureIO (3.10.9 - 3.10.9) <0AC15003-4B6A-3FB3-9B41-3EF61A2BD430> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff2be71000 - 0x7fff2be79fff com.apple.InternationalSupport (1.0 - 60) <5485FFDC-CE44-37F4-865F-91B2EFBC6CAF> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff2be7a000 - 0x7fff2bef5fff com.apple.datadetectorscore (8.0 - 674) <A2DEEF63-7643-37AA-9420-ED875629D1B2> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff2bef6000 - 0x7fff2bf54fff com.apple.UserActivity (435 - 435) <075FD354-28FD-3A13-881C-955FA9106D5C> /System/Library/PrivateFrameworks/UserActivity.framework/Versions/A/UserActivity
0x7fff2bf55000 - 0x7fff2c6bffff com.apple.MediaToolbox (1.0 - 2760.6.4.6) <8F9D0503-298B-3FCA-8135-3B3722EF287C> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff2cb79000 - 0x7fff2cba1fff com.apple.locationsupport (2420.12.12 - 2420.12.12) <F02D6025-16B4-3C77-ACEA-89B4808214D3> /System/Library/PrivateFrameworks/LocationSupport.framework/Versions/A/LocationSupport
0x7fff2cba2000 - 0x7fff2cbd3fff libSessionUtility.dylib (76.7) <95615EDE-46B9-32AE-96EC-7F6E5EB6A932> /System/Library/PrivateFrameworks/AudioSession.framework/libSessionUtility.dylib
0x7fff2cbd4000 - 0x7fff2cd04fff com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <D0F9F628-F241-3FA2-A785-7B9DCBB2FEC4> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff2cd05000 - 0x7fff2cd6cfff com.apple.audio.AudioSession (1.0 - 76.7) <C0B1C9EB-A594-31E3-ADDF-118583840E6F> /System/Library/PrivateFrameworks/AudioSession.framework/Versions/A/AudioSession
0x7fff2cd6d000 - 0x7fff2cd7ffff libAudioStatistics.dylib (25.1) <1D07EA54-BE7C-37C4-AA73-5224D402F0C3> /usr/lib/libAudioStatistics.dylib
0x7fff2cd80000 - 0x7fff2cd8ffff com.apple.speech.synthesis.framework (9.0.51 - 9.0.51) <B86A2136-8DD7-395D-BB9F-9416C56DD2D6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff2cd90000 - 0x7fff2cdfbfff com.apple.ApplicationServices.ATS (377 - 516) <3A435648-CC5F-387E-AB37-391AAEABE314> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff2cdfc000 - 0x7fff2ce14fff libresolv.9.dylib (68) <9957A6F4-8B66-3429-86CD-6DF4993EB6F5> /usr/lib/libresolv.9.dylib
0x7fff2ce15000 - 0x7fff2ce28fff libsasl2.2.dylib (214) <F20902AE-3733-3F37-801D-6C3B78C0008A> /usr/lib/libsasl2.2.dylib
0x7fff2cee2000 - 0x7fff2cf46fff com.apple.CoreMediaIO (1000.0 - 5318) <CFFD2205-BFEA-313A-BAF4-61CCA9BA6D68> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff2cf47000 - 0x7fff2d026fff libSMC.dylib (20) <CE5162B7-379E-3DF0-9D1E-44BC98BD2422> /usr/lib/libSMC.dylib
0x7fff2d027000 - 0x7fff2d086fff libcups.2.dylib (494.1) <04A4801E-E1B5-3919-9F14-100F0C2D049B> /usr/lib/libcups.2.dylib
0x7fff2d087000 - 0x7fff2d096fff com.apple.LangAnalysis (1.7.0 - 254) <120945D9-B74D-3A6F-B160-2678E6B6481D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff2d097000 - 0x7fff2d0a1fff com.apple.NetAuth (6.2 - 6.2) <C65B2F54-67EA-3E4D-B84A-BBA94998BD6B> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff2d0a2000 - 0x7fff2d0a9fff com.apple.ColorSyncLegacy (4.13.0 - 1) <33DA9348-EADF-36D2-B999-56854481D272> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff2d0aa000 - 0x7fff2d0b5fff com.apple.QD (4.0 - 416) <7FFC9049-7E42-372B-9105-1C4C94DE0110> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff2d0b6000 - 0x7fff2d724fff com.apple.audio.AudioResourceArbitration (1.0 - 1) <098FD431-D302-3DD5-9AD1-453615A73E68> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
0x7fff2d725000 - 0x7fff2d731fff com.apple.perfdata (1.0 - 67.40.1) <85A57A67-8721-3035-BCEE-D4AC98332D2C> /System/Library/PrivateFrameworks/perfdata.framework/Versions/A/perfdata
0x7fff2d732000 - 0x7fff2d740fff libperfcheck.dylib (41) <67113817-A463-360A-B321-9286DC50FEDA> /usr/lib/libperfcheck.dylib
0x7fff2d741000 - 0x7fff2d750fff com.apple.Kerberos (3.0 - 1) <2E872705-0841-3695-AF79-4160D2A436AB> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff2d751000 - 0x7fff2d7a0fff com.apple.GSS (4.0 - 2.0) <2A38D59F-5F3A-3779-A421-2F8128F22B95> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff2d7a1000 - 0x7fff2d7b1fff com.apple.CommonAuth (4.0 - 2.0) <D9431F22-A16B-3237-9676-B6159B36F5EA> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff2d7b2000 - 0x7fff2d7d8fff com.apple.MobileAssets (1.0 - 659.60.1) <D8986A88-2061-3157-A1BE-452E20ED34F6> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
0x7fff2d806000 - 0x7fff2d828fff com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <3554A1B0-A9AD-3D89-A755-1C9CC7CEA239> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff2d829000 - 0x7fff2d831fff com.apple.CorePhoneNumbers (1.0 - 1) <0DF4C527-E7D3-30E0-9402-4C43B29729CB> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff2d832000 - 0x7fff2d8bdfff libTelephonyUtilDynamic.dylib (5346) <FD27BE40-17A0-3561-90E3-FFB96048C2AD> /usr/lib/libTelephonyUtilDynamic.dylib
0x7fff2d986000 - 0x7fff2d986fff liblaunch.dylib (2038.40.38) <05A7EFDD-4111-3E4D-B668-239B69DE3D0F> /usr/lib/system/liblaunch.dylib
0x7fff2e181000 - 0x7fff2e2c8fff com.apple.Sharing (1575 - 1575) <4E590A26-5934-33EE-BFD9-391A64686FDE> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff2e2c9000 - 0x7fff2e3e9fff com.apple.Bluetooth (8.0.2 - 8.0.2f9) <E3CF73C4-B439-3E30-B74D-3344C2EA2FC9> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff2e3ea000 - 0x7fff2e3fefff com.apple.AppContainer (4.0 - 509.60.2) <A9D28E73-B08F-34E3-AE7B-0855DBA96C3C> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff2e3ff000 - 0x7fff2e402fff com.apple.SecCodeWrapper (4.0 - 509.60.2) <55B0C208-B176-3FE4-8CA2-9F28CA59F8F1> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff2e403000 - 0x7fff2e45cfff com.apple.ProtectedCloudStorage (1.0 - 1) <C84C9C98-5382-3E27-8275-AC9816AA28E8> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff2e45d000 - 0x7fff2e4bcfff com.apple.QuickLookFramework (5.0 - 928.1) <AC6665D6-76C3-3792-AB69-4EF566DD411B> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff2e4bd000 - 0x7fff2e4d9fff com.apple.MetalKit (147.1 - 147.1) <3D1B6242-AA65-37ED-A6F5-01E39F1CC463> /System/Library/Frameworks/MetalKit.framework/Versions/A/MetalKit
0x7fff2e6b0000 - 0x7fff2fb9ffff com.apple.GeoServices (1.0 - 1757.22.10.6.12) <4D6F8EF4-47D4-3F93-90AC-3F4A5772CBCB> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff2fba0000 - 0x7fff2fbabfff com.apple.DirectoryService.Framework (11.1 - 230.40.1) <FC96A8F6-8E19-3CB4-A3ED-4E30B1491746> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff2fbac000 - 0x7fff2fbd7fff com.apple.RemoteViewServices (2.0 - 163) <AC6E2D2F-8131-3A40-97D7-E24E2A45CD66> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff2fbd8000 - 0x7fff2fbe7fff com.apple.SpeechRecognitionCore (6.1.12 - 6.1.12) <F2A0E41A-7976-3175-959A-98DC24AAFFCC> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff2fbe8000 - 0x7fff2fbeffff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <9C14FA0A-D905-375B-8C32-E311ED59B6AD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff2fe33000 - 0x7fff2fe33fff libsystem_product_info_filter.dylib (8.40.1) <7CCAF1A8-F570-341E-B275-0C80B092F8E0> /usr/lib/system/libsystem_product_info_filter.dylib
0x7fff2ff0e000 - 0x7fff2ff0efff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <510A463F-5CA5-3585-969F-2D44583B71C8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff2ff35000 - 0x7fff2ff35fff com.apple.CoreServices (1122.11 - 1122.11) <5DDB040C-6E92-3DBE-9049-873F510F26E2> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff30203000 - 0x7fff30203fff com.apple.Accelerate (1.11 - Accelerate 1.11) <F2FFCC7B-EE3D-3768-A73B-342851B53741> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff30244000 - 0x7fff3024ffff com.apple.MediaAccessibility (1.0 - 130) <9B4710C9-6238-3507-9918-FDA38CDC0B00> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff30250000 - 0x7fff3026ffff com.apple.networking.AlgosScoreFramework (1.0 - 1) <DAB40772-57A1-3545-94FD-4C823D13135C> /System/Library/PrivateFrameworks/AlgosScoreFramework.framework/Versions/A/AlgosScoreFramework
0x7fff30270000 - 0x7fff30274fff com.apple.AppleSRP (5.0 - 1) <882084C9-F925-308F-B778-398FE6741654> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff30275000 - 0x7fff30280fff com.apple.frameworks.CoreDaemon (1.3 - 1.3) <96849317-5346-3D5D-95B7-6C48C3015427> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff30281000 - 0x7fff302b8fff com.apple.framework.SystemAdministration (1.0 - 1.0) <E28F11F0-2155-331E-9CFE-BF858E06ACED> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x7fff30a7a000 - 0x7fff30adcfff com.apple.CoreBluetooth (1.0 - 1) <0FF4CFB1-B8DD-31C3-A000-5016CFE45EB9> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff30add000 - 0x7fff30ae6fff com.apple.SymptomDiagnosticReporter (1.0 - 79.40.12) <4536FFDF-598E-3085-8DDD-26798E1EEBD6> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
0x7fff30ae7000 - 0x7fff30afafff com.apple.PowerLog (1.0 - 1) <7EA1C552-E90E-3DF6-A5B6-915D26694670> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
0x7fff30afb000 - 0x7fff30b07fff com.apple.AppleIDAuthSupport (1.0 - 1) <1EE88692-4059-3A33-B492-E7D7112EFB0C> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff30b08000 - 0x7fff30bb0fff com.apple.DiscRecording (9.0.3 - 9030.4.5) <8676CDCB-15CC-3723-9411-8B8AFA3B370A> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff30bb1000 - 0x7fff30be4fff com.apple.MediaKit (16 - 927.40.2) <C7FB3929-E0E1-3A6C-B138-EE504CCE9EF0> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff30be5000 - 0x7fff30cd0fff com.apple.DiskManagement (14.0 - 1733.60.1) <328DB6AD-221B-35FA-8E31-2E5CD860A0F3> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
0x7fff30cd1000 - 0x7fff3108bfff com.apple.CoreAUC (322.2.0 - 322.2.0) <5E5A1D7F-5D43-3975-AA23-AA0815DCE998> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff3108c000 - 0x7fff3108ffff com.apple.Mangrove (1.0 - 25) <81A9BA84-C61F-3CBF-A127-406E3FD2459E> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff31090000 - 0x7fff310bdfff com.apple.CoreAVCHD (6.1.0 - 6100.4.1) <10CA0E34-19B1-365C-888C-94543A25F10F> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff310be000 - 0x7fff311defff com.apple.FileProvider (326 - 326) <B2A33B9E-66D9-30B5-A18C-AD0D7F3592C5> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
0x7fff311df000 - 0x7fff31202fff com.apple.GenerationalStorage (2.0 - 322) <F2740CA7-334B-3F24-AFE8-2451D1A041C2> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff31579000 - 0x7fff31649fff com.apple.CoreTelephony (113 - 8175.1) <149CCBA2-E5C7-3FAF-AEA1-0BBC4E7A9887> /System/Library/Frameworks/CoreTelephony.framework/Versions/A/CoreTelephony
0x7fff3166e000 - 0x7fff317fbfff com.apple.AVFCore (1.0 - 2000.5.4.2) <46137047-4B3D-3A90-A6ED-68B829489C20> /System/Library/PrivateFrameworks/AVFCore.framework/Versions/A/AVFCore
0x7fff317fc000 - 0x7fff3186efff com.apple.FrontBoardServices (702.3.3 - 702.3.3) <9EAEF19A-4167-3914-A9A8-25C36E586550> /System/Library/PrivateFrameworks/FrontBoardServices.framework/Versions/A/FrontBoardServices
0x7fff3186f000 - 0x7fff31898fff com.apple.BoardServices (1.0 - 526) <87D88A0A-A43D-301B-9393-D06E971BAEDF> /System/Library/PrivateFrameworks/BoardServices.framework/Versions/A/BoardServices
0x7fff31a51000 - 0x7fff31a90fff com.apple.AppleVPAFramework (3.20.4 - 3.20.4) <DF632ED6-E230-3208-8741-446E8E35A515> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
0x7fff31b61000 - 0x7fff31b9dfff com.apple.DebugSymbols (195.1 - 195.1) <6AA76BBC-B0F2-3F37-A6EE-19014DCD06D9> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff31b9e000 - 0x7fff31c5bfff com.apple.CoreSymbolication (12.2 - 64541.4) <A100000D-F881-3C3C-ABC5-3EAC7A272579> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff31c5c000 - 0x7fff31c65fff com.apple.CoreTime (284) <1BE28F6E-940C-31C8-B460-2761FC6B4A3F> /System/Library/PrivateFrameworks/CoreTime.framework/Versions/A/CoreTime
0x7fff31c66000 - 0x7fff31cdcfff com.apple.Rapport (2.2.0 - 220.9) <D333F84F-874B-3B98-A4B2-BABD63B019CB> /System/Library/PrivateFrameworks/Rapport.framework/Versions/A/Rapport
0x7fff32525000 - 0x7fff32572fff com.apple.coreduetcontext (1.0 - 1) <D841DF38-170F-3B40-A41C-56EC30E94FB8> /System/Library/PrivateFrameworks/CoreDuetContext.framework/Versions/A/CoreDuetContext
0x7fff32573000 - 0x7fff32af0fff com.apple.Intents (1.0 - 1) <606E26DB-606D-3BE9-9225-A4B780A1D73C> /System/Library/Frameworks/Intents.framework/Versions/A/Intents
0x7fff32af1000 - 0x7fff32b54fff com.apple.framework.Apple80211 (17.0 - 1728) <2DBC65AC-A7DF-38F9-9174-3382667FBF0F> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff32b55000 - 0x7fff32ca7fff com.apple.CoreWiFi (3.0 - 341) <C18D2E57-A964-380F-A74B-AEFDB3B3ADEC> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff32ca8000 - 0x7fff32cc0fff com.apple.BackBoardServices (1.0 - 1.0) <D0CC2360-6785-3FFF-9311-71A03C78B51A> /System/Library/PrivateFrameworks/BackBoardServices.framework/Versions/A/BackBoardServices
0x7fff32cc1000 - 0x7fff32cf8fff com.apple.LDAPFramework (2.4.28 - 194.5) <C3E9E36B-B981-3FAD-A8EA-9BADE5F2B30D> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff32cf9000 - 0x7fff32cfafff com.apple.TrustEvaluationAgent (2.0 - 35) <D0B7904B-37ED-32B1-8FD3-462383F2BDCB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff32cfb000 - 0x7fff32dfefff libcrypto.44.dylib (56.60.2) <7464291F-2D5C-3AE3-9197-54C8676C23F1> /usr/lib/libcrypto.44.dylib
0x7fff32dff000 - 0x7fff32e2cfff libssl.46.dylib (56.60.2) <0692D04B-A0C4-3632-BB08-2C0C2AC68479> /usr/lib/libssl.46.dylib
0x7fff32e2d000 - 0x7fff32edcfff com.apple.DiskImagesFramework (595.40.1 - 595.40.1) <B0A2C1DD-79A0-3C26-A1A8-22F1989E5415> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff32f14000 - 0x7fff32f23fff com.apple.xpc.RemoteServiceDiscovery (1.0 - 2038.40.38) <EFEFC279-E73A-3557-A4AE-BF67E7C96962> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
0x7fff32f24000 - 0x7fff32f3bfff com.apple.xpc.RemoteXPC (1.0 - 2038.40.38) <DC43AED2-6DD7-31AB-8186-EF69ED7027C4> /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC
0x7fff32f83000 - 0x7fff32f86fff com.apple.help (1.3.8 - 71) <599F7E42-DEF1-3B70-83AB-C3BDF727CF93> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff32f87000 - 0x7fff32f8efff com.apple.EFILogin (2.0 - 2) <B94BFCCA-45B6-3E80-84E7-758350D7CAFD> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff32f8f000 - 0x7fff32f9afff libcsfde.dylib (554) <1F4DFF13-17EC-3672-8A41-056F4E44A377> /usr/lib/libcsfde.dylib
0x7fff32f9b000 - 0x7fff33000fff libcurl.4.dylib (121.40.2) <C9541242-9ED5-3F9B-A2B2-415503447A1F> /usr/lib/libcurl.4.dylib
0x7fff33001000 - 0x7fff33008fff com.apple.LoginUICore (4.0 - 4.0) <8AE86484-F756-3BDE-973A-A70C0345697B> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x7fff331c8000 - 0x7fff331c8fff com.apple.ApplicationServices (48 - 50) <7B536871-3F10-3138-B06B-9C2A3C07EC1E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff334c8000 - 0x7fff334c8fff libHeimdalProxy.dylib (79) <1BD94BF6-8E63-3B21-95DC-E5EEEBFB8AE8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
0x7fff3357b000 - 0x7fff3357bfff com.apple.audio.units.AudioUnit (1.14 - 1.14) <F5EC07DD-8937-37CB-84DF-C7475FFA573E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff335a0000 - 0x7fff335e2fff com.apple.StreamingZip (1.0 - 1) <FEA8C519-ACB4-381C-9F9D-CB92AE094B23> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
0x7fff335e3000 - 0x7fff33603fff com.apple.DuetActivityScheduler (1.0 - 1) <CA10D6CB-848E-3AC9-8D2D-4D5961FE1B5B> /System/Library/PrivateFrameworks/DuetActivityScheduler.framework/Versions/A/DuetActivityScheduler
0x7fff33617000 - 0x7fff33624fff com.apple.IntentsFoundation (1.0 - 1) <9A6961E4-7769-3005-A380-38F701252BA0> /System/Library/PrivateFrameworks/IntentsFoundation.framework/Versions/A/IntentsFoundation
0x7fff33625000 - 0x7fff3362afff com.apple.PushKit (1.0 - 1) <309B12FF-9B68-3120-ABC6-8B52A0E26127> /System/Library/Frameworks/PushKit.framework/Versions/A/PushKit
0x7fff3362b000 - 0x7fff33661fff com.apple.C2 (1.3 - 569) <5370F4A2-1C27-395C-80E4-A36E5BF414E9> /System/Library/PrivateFrameworks/C2.framework/Versions/A/C2
0x7fff33662000 - 0x7fff33693fff com.apple.QuickLookThumbnailing (1.0 - 135.1) <C7826D32-4B8B-3F17-9138-AA978CA579FA> /System/Library/Frameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
0x7fff33694000 - 0x7fff33ea1fff com.apple.vision.EspressoFramework (1.0 - 256.2.2) <C2903F04-5EE0-3FCA-A7D8-6ABFDD38A27B> /System/Library/PrivateFrameworks/Espresso.framework/Versions/A/Espresso
0x7fff33ea2000 - 0x7fff33eb9fff com.apple.ANEServices (4.51 - 4.51) <F86B479B-3FA0-366C-84A6-D35253ABBF5E> /System/Library/PrivateFrameworks/ANEServices.framework/Versions/A/ANEServices
0x7fff33fd6000 - 0x7fff33fd8fff com.apple.CoreDuetDebugLogging (1.0 - 1) <65E1262F-01D6-3C96-BFAF-3BE6BB0996A8> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
0x7fff33fd9000 - 0x7fff33fe6fff com.apple.CoreDuetDaemonProtocol (1.0 - 1) <42503D84-5D78-3F8F-83CA-73CC5E78160D> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
0x7fff34255000 - 0x7fff34518fff com.apple.spotlight.index (10.7.0 - 2150.7.2) <D7C1EBB8-2025-3D21-81AE-B43E6005051F> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
0x7fff34531000 - 0x7fff34581fff com.apple.ChunkingLibrary (334 - 334) <E392AB7F-6EAC-3E2E-93F8-01BA240FEACD> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff34e4d000 - 0x7fff34e63fff com.apple.CoreML.AppleNeuralEngine (1.0 - 1) <BB0C2E05-9F10-3990-9A4B-0A3796F912AB> /System/Library/PrivateFrameworks/AppleNeuralEngine.framework/Versions/A/AppleNeuralEngine
0x7fff34fc9000 - 0x7fff34fccfff com.apple.Cocoa (6.11 - 23) <E44AC98B-5BEA-3087-AB41-C73CEB8A98C8> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff35b3e000 - 0x7fff35b45fff com.apple.DisplayServicesFW (3.1 - 380) <E2038E63-63E3-3F32-A9A1-AAF16F5BFADB> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff363d6000 - 0x7fff363f7fff com.apple.MarkupUI (1.0 - 383.3) <55FC6183-4CC7-38C2-8797-097C24FFCB76> /System/Library/PrivateFrameworks/MarkupUI.framework/Versions/A/MarkupUI
0x7fff3640c000 - 0x7fff36427fff com.apple.openscripting (1.7 - 190) <D0B98DF9-7A61-3810-AE81-2F870DCC2AC0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff36428000 - 0x7fff3642bfff com.apple.securityhi (9.0 - 55008) <DD7770F7-661C-363B-A1F4-8B69EB0FFB6A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff3642c000 - 0x7fff3642ffff com.apple.ink.framework (10.15 - 227) <E10C40B6-2656-36D1-882C-2091CE02883A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff36430000 - 0x7fff36433fff com.apple.CommonPanels (1.2.6 - 101) <101582BA-E64F-391A-BD23-50DCC3CF8939> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff36434000 - 0x7fff3643bfff com.apple.ImageCapture (1708 - 1708) <FE9D13DD-D733-3B2A-B4A6-D3C8313005F5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff3643c000 - 0x7fff376e4fff com.apple.JavaScriptCore (16610 - 16610.3.7.1.9) <3CEFF634-9E86-33F8-9E9C-AACAD4E3412B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff3774f000 - 0x7fff37836fff com.apple.audio.AVFAudio (1.0 - 477.9) <4F121DC8-938F-3E2E-ABCF-49CD95F5FD5C> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fff37837000 - 0x7fff3794bfff com.apple.AVFCapture (1.0 - 80.17.1.1) <FEA644F1-6D58-3E38-9057-33DBCC85D91A> /System/Library/PrivateFrameworks/AVFCapture.framework/Versions/A/AVFCapture
0x7fff3794c000 - 0x7fff379e0fff com.apple.Quagga (47 - 47) <7C13C66E-7748-3D63-87F3-B4F24530E2B8> /System/Library/PrivateFrameworks/Quagga.framework/Versions/A/Quagga
0x7fff379e1000 - 0x7fff37c3cfff com.apple.CMCapture (1.0 - 80.17.1.1) <21771336-D58A-3F59-A4BE-679B1308A4B0> /System/Library/PrivateFrameworks/CMCapture.framework/Versions/A/CMCapture
0x7fff3864e000 - 0x7fff3865dfff com.apple.HID (1.0 - 1) <E5202792-F20F-3458-8CC7-6B158058DC33> /System/Library/PrivateFrameworks/HID.framework/Versions/A/HID
0x7fff3865e000 - 0x7fff38785fff com.apple.QuickLookUIFramework (5.0 - 928.1) <559B0828-7637-319F-9856-3F336376FAA0> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff39421000 - 0x7fff39424fff com.apple.OSAServicesClient (1.0 - 1) <44E39868-F624-3644-B453-962D34737998> /System/Library/PrivateFrameworks/OSAServicesClient.framework/Versions/A/OSAServicesClient
0x7fff39458000 - 0x7fff3945ffff com.apple.URLFormatting (146 - 146.8) <B77A6E0A-66AD-3044-AB17-10ECA706A151> /System/Library/PrivateFrameworks/URLFormatting.framework/Versions/A/URLFormatting
0x7fff3c00e000 - 0x7fff3c1c9fff libFosl_dynamic.dylib (200) <98F6E5F9-58F1-318D-B064-E265673D6152> /usr/lib/libFosl_dynamic.dylib
0x7fff3c1ca000 - 0x7fff3c1eefff com.apple.quicklook.QuickLookSupport (1.0 - 135.1) <44CCD2F4-B9E3-34FD-81BC-388B730D8068> /System/Library/PrivateFrameworks/QuickLookSupport.framework/Versions/A/QuickLookSupport
0x7fff3c1ef000 - 0x7fff3c286fff com.apple.AirPlaySync (1.0 - 2760.6.4.6) <74BB0488-C512-36A1-A153-956D7A874AE6> /System/Library/PrivateFrameworks/AirPlaySync.framework/Versions/A/AirPlaySync
0x7fff3d0a2000 - 0x7fff3d125fff com.apple.CorePDF (4.0 - 529) <7E6D5BFD-7A7A-3999-84EA-28AFEB1C2CA2> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff3d126000 - 0x7fff3d129fff com.apple.print.framework.Print (15 - 271) <8411879F-7E3E-3882-BD06-68E797A3B9D6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff3d12a000 - 0x7fff3d12dfff com.apple.Carbon (160 - 164) <5683716A-5610-3B97-B473-B4652067E7A6> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff3d227000 - 0x7fff3d227fff com.apple.avfoundation (2.0 - 2000.5.4.2) <12890AA5-14D5-3DEA-9FBB-FBB7E3F34BDF> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff3d3b2000 - 0x7fff3d3d1fff com.apple.private.SystemPolicy (1.0 - 1) <CFE0B0C6-DF5B-31EB-9D79-B23E00A80B05> /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy
0x7fff3d57e000 - 0x7fff3d59bfff com.apple.sidecar-core (1.0 - 228) <7D771E63-1A57-3B3D-BBC0-2ACE9D19BA64> /System/Library/PrivateFrameworks/SidecarCore.framework/Versions/A/SidecarCore
0x7fff3d59c000 - 0x7fff3d5a3fff com.apple.QuickLookNonBaseSystem (1.0 - 1) <9E56C6AB-0873-3982-B3D6-573761702607> /System/Library/PrivateFrameworks/QuickLookNonBaseSystem.framework/Versions/A/QuickLookNonBaseSystem
0x7fff3db4a000 - 0x7fff3db61fff com.apple.SafariServices.framework (16610 - 16610.3.7.1.9) <011F7AF4-198C-3430-B677-9CE84C23D211> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
0x7fff3dcfb000 - 0x7fff3dd06fff com.apple.MallocStackLogging (1.0 - 1) <C1A21524-381D-39CA-AD63-A3B9F67FC6CA> /System/Library/PrivateFrameworks/MallocStackLogging.framework/Versions/A/MallocStackLogging
0x7fff3dd1c000 - 0x7fff3dd2efff libmis.dylib (274.60.2) <54387457-A60B-3390-AD6D-3B380792CD79> /usr/lib/libmis.dylib
0x7fff3dd4b000 - 0x7fff3debdfff com.apple.CoreHandwriting (161 - 1.2) <503717BE-E9B6-3805-B9C8-8DA329788629> /System/Library/PrivateFrameworks/CoreHandwriting.framework/Versions/A/CoreHandwriting
0x7fff3debe000 - 0x7fff3e11dfff com.apple.imageKit (3.0 - 1100) <0FB1CD82-6DCD-333B-831E-9E81A4A14C7B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff3e11e000 - 0x7fff3e23dfff com.apple.PencilKit (1.0 - 1) <61DD7515-94AF-35A6-92AF-B1473BC8E8BF> /System/Library/Frameworks/PencilKit.framework/Versions/A/PencilKit
0x7fff3e23e000 - 0x7fff3e24ffff com.apple.sidecar-ui (1.0 - 228) <65430CA2-E7AC-3569-947B-B8B8E8D4BF9E> /System/Library/PrivateFrameworks/SidecarUI.framework/Versions/A/SidecarUI
0x7fff3e839000 - 0x7fff3e89bfff com.apple.ImageCaptureCore (1708 - 1708) <505F35F3-99B2-3608-9766-9AD477A0D5EB> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff3e89c000 - 0x7fff3e8c2fff com.apple.quartzfilters (1.10.0 - 98) <9C2F0204-D844-3C03-AEE2-1EC2DA58ACFD> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff3f068000 - 0x7fff3f199fff com.apple.AnnotationKit (1.0 - 383.3) <60747C5F-3747-3D9D-A1A8-C351E83E6E40> /System/Library/PrivateFrameworks/AnnotationKit.framework/Versions/A/AnnotationKit
0x7fff3f19a000 - 0x7fff3f63bfff com.apple.QuartzComposer (5.1 - 383) <CECFD875-ECE5-35A1-B97A-C493F183639C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff3f63c000 - 0x7fff3f729fff com.apple.PDFKit (1.0 - 950.10.3) <13BE9A0B-F8C5-3C02-B5BC-ABDDDC4A8932> /System/Library/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff414b2000 - 0x7fff414e1fff libncurses.5.4.dylib (57) <05652959-10ED-3D39-8E0E-C6FC5A68B045> /usr/lib/libncurses.5.4.dylib
0x7fff414e2000 - 0x7fff414ebfff com.apple.IOAccelMemoryInfo (1.0 - 1) <90735179-1E6C-3D1F-8CCF-08AC441B19A2> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
0x7fff41543000 - 0x7fff41546fff com.apple.quartzframework (1.5 - 25) <F7A81E93-FDF9-3DAC-80F9-AF4D5887B2E0> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff41922000 - 0x7fff41940fff libCGInterfaces.dylib (544) <488D608D-374C-3A2F-B8AC-D78E2F6E6DB7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff43f30000 - 0x7fff441a9fff com.apple.RawCamera.bundle (9.10.0 - 1420.3) <D6521255-C614-3A4C-83E1-42A3C3079CBE> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff46c28000 - 0x7fff46c33fff libGPUSupportMercury.dylib (18.1.1) <5C061A05-CD21-3442-A80B-1901D64C9B9E> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff48294000 - 0x7fff482e2fff com.apple.osanalytics.OSAnalytics (1.0 - 1) <EF7537E3-982B-3FA2-BFFC-F8071EFF0B31> /System/Library/PrivateFrameworks/OSAnalytics.framework/Versions/A/OSAnalytics
0x7fff4c327000 - 0x7fff4c32afff com.apple.FinderSyncPriv (1.3 - 1350.2.10) <456C118F-398C-329C-BC89-7B1EAC693835> /System/Library/PrivateFrameworks/FinderSyncPriv.framework/Versions/A/FinderSyncPriv
0x7fff52252000 - 0x7fff522e4fff com.apple.Symbolication (12.2 - 64541.7.1) <EC806042-5249-35DC-90BA-953A86D1854A> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff5641a000 - 0x7fff5641dfff com.apple.ForceFeedback (1.0.6 - 1.0.6) <AB29674E-26C2-360C-9117-54AC93E80CB0> /System/Library/Frameworks/ForceFeedback.framework/Versions/A/ForceFeedback
0x7fff5ee93000 - 0x7fff5f8a6fff libSC.dylib (4.2.13) <7F3979D1-8399-3098-80F8-88707ED65975> /System/Library/Extensions/AMDShared.bundle/Contents/PlugIns/libSC.dylib
0x7fff6a3b8000 - 0x7fff6a3bcfff libmetal_timestamp.dylib (31001.160) <2EC7EA90-5313-3812-8E72-910C643A996C> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/31001/Libraries/libmetal_timestamp.dylib
0x7fff6c826000 - 0x7fff6c82cfff libCoreFSCache.dylib (177.22) <4ECE128D-5E79-3ADF-8FE7-4FE8F565F8AA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff6c82d000 - 0x7fff6c831fff libCoreVMClient.dylib (177.22) <E0DBED1D-39B4-3E51-9EA8-D1ECAED93EAB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff6c832000 - 0x7fff6c841fff com.apple.opengl (18.1.1 - 18.1.1) <D8EE3AD0-C0D0-32F7-9C6D-39341099EB55> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff6c842000 - 0x7fff6c844fff libCVMSPluginSupport.dylib (18.1.1) <5F020D32-8663-3CB8-A50C-F939D4D4C31F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff6c845000 - 0x7fff6c84dfff libGFXShared.dylib (18.1.1) <2271532D-E2B3-3D4D-ADF0-0935F8DCE89B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff6c84e000 - 0x7fff6c881fff libGLImage.dylib (18.1.1) <528E53A3-33E1-34C7-8EE3-C42AE5255553> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff6c882000 - 0x7fff6c8befff libGLU.dylib (18.1.1) <15CBDF20-8A87-3D84-90F8-D19F4A2B06E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff6c8bf000 - 0x7fff6ca53fff libGLProgrammability.dylib (18.1.1) <570616B1-98D2-3DF2-844A-EE845A8B8EDE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff6ca54000 - 0x7fff6ca5efff libGL.dylib (18.1.1) <157B74E1-F30D-3F9D-9AF8-AAA333D2812D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff6ca5f000 - 0x7fff6cbdafff GLEngine (18.1.1) <155E1C82-C69A-3E86-8569-3C134C7FEAC6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff6cbdb000 - 0x7fff6cc04fff GLRendererFloat (18.1.1) <49B0A782-AE84-35BC-91F8-880C2B7EE004> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff6de95000 - 0x7fff6deedfff com.apple.opencl (4.5 - 4.5) <8A3D06D5-4E82-355C-AE1B-E2C91DB58233> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff6ea37000 - 0x7fff6ebf7fff com.apple.AMDMTLBronzeDriver (4.2.13 - 4.0.2) <36056DBB-370D-38B0-A011-9534ABBF2ACD> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
0x7fff6ed70000 - 0x7fff6edbffff ATIRadeonX4000SCLib.dylib (4.2.13) <78CC44AC-F1E7-3F18-8FE4-216B9E7BFDFC> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCLib.dylib
0x7fff6f777000 - 0x7fff6f799fff com.apple.audio.OpenAL (1.8 - 1.8) <8CF29FAE-D1F5-37FA-B529-D999AFE990FD> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
0x7fff783ad000 - 0x7fff783b4fff libRosetta.dylib (203.13.2) <FF72E19B-3B02-34D4-A821-3397BB28AC02> /usr/lib/libRosetta.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 31
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 14159
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)
Writable regions: Total=3.1G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=3.1G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 384K 3
Activity Tracing 256K 1
CG backing stores 5760K 6
CG image 1252K 14
CoreAnimation 80K 8
CoreGraphics 12K 2
CoreImage 4K 1
CoreUI image data 944K 8
Foundation 16K 1
Kernel Alloc Once 8K 1
MALLOC 790.4M 156
MALLOC guard page 48K 10
MALLOC_MEDIUM (reserved) 1.7G 17 reserved VM address space (unallocated)
MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)
OpenGL GLSL 256K 3
STACK GUARD 156K 39
Stack 72.8M 40
VM_ALLOCATE 91.0M 3767
__CTF 759 1
__DATA 91.7M 429
__DATA_CONST 20.1M 250
__DATA_DIRTY 1254K 148
__FONT_DATA 4K 1
__GLSLBUILTINS 5176K 1
__LINKEDIT 542.0M 36
__OBJC_RO 60.5M 1
__OBJC_RW 2452K 2
__TEXT 498.4M 428
__UNICODE 588K 1
mapped file 91.9M 26
shared memory 40K 4
TOTAL 4.3G 5406
TOTAL, minus reserved VM space 2.2G 5406
Model: iMac19,1, BootROM 1554.60.15.0.0, 8 processors, 8-Core Intel Core i9, 3,6 GHz, 40 GB, SMC 2.46f13
Graphics: kHW_AMDRadeonPro580XItem, Radeon Pro 580X, spdisplays_pcie_device, 8 GB
Memory Module: BANK 0/ChannelA-DIMM0, 4 GB, DDR4, 2667 MHz, SK Hynix, HMA851S6CJR6N-VK
Memory Module: BANK 1/ChannelA-DIMM1, 16 GB, DDR4, 2667 MHz, 859B, CT16G4SFD8266.M16FE
Memory Module: BANK 2/ChannelB-DIMM0, 4 GB, DDR4, 2667 MHz, SK Hynix, HMA851S6CJR6N-VK
Memory Module: BANK 3/ChannelB-DIMM1, 16 GB, DDR4, 2667 MHz, 859B, CT16G4SFD8266.M16FE
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x7BF), wl0: Sep 11 2020 16:57:49 version 9.30.440.2.32.5.61 FWID 01-129bddb
Bluetooth: Version 8.0.2f9, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Network Service: Wi-Fi, AirPort, en1
PCI Card: pci1b73,1100, sppci_usbxhci, Thunderbolt@133,0,0
PCI Card: pci11c1,5901, sppci_ieee1394openhci, Thunderbolt@134,0,0
PCI Card: pci1b21,612, sppci_ahci, Thunderbolt@132,0,0
PCI Card: pci1b21,612, sppci_ahci, Thunderbolt@131,0,0
Serial ATA Device: Samsung SSD 840 EVO 500GB, 500,11 GB
Serial ATA Device: Samsung SSD 840 EVO 1TB, 1 TB
USB Device: VLI Product String
USB Device: USB 3.1 Bus
USB Device: FaceTime HD Camera (Built-in)
USB Device: Wired Keyboard 600
USB Device: USB 3.0 Bus
FireWire Device: unknown_device, Unknown
Thunderbolt Bus: iMac, Apple Inc., 47.4
Thunderbolt Device: AKiTiO Thunder 2 Dock, inXtron, 3, 25.1
