Cycles Adaptive Subdivision fails when using EXR file to build shader.
Graphics card: GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash: rB0f45cab862b8
Worked: n/a
I am creating an ocean in Houdini, and export displacement map as EXR sequence for rendering in Cycles. The EXR images contain RGB channels for vector displacement, and an Alpha channel for Cusp(white water). I used the color channel for displacement and it has no problem. However, when I use the Alpha channel to adjust the color, the displacement suddenly becomes huge, in both viewport and final render. Scaling it down will not fix the problem because the interpolation of the displacement is also altered. I have tried with both 16bit and 32bit EXRs and the problem remains. I had this problem in previous Blender versions, and different PCs(different CPU/GPU) too.
  1. Create a plane, add Subdivision Surface modifier, check Adaptive Subdivision.
  2. Create a new material, add Displacement node, add Image Texture node.
  3. For Image Texture node, open an EXR image file with RGBA channels.
  4. Plug color output of Image Texture to Displacement node, and Displacement to Material Output.
  5. Leave Principled node plugged into Material Output.
  6. Add a Color Mix node, and set two different colors(e.g. black/white), plug color output to Principled color input.
  7. Plug the Alpha output of Image Texture into Fac of the Color Mix node.
  8. Add a Colorramp node. // This is where my problem shows, the displacement in the render view suddenly changed(becomes huge on Z axis).
  9. If problem does not occur, continue to use Image Texture Alpha or Color output as factor to play with the color.
// This problem happens at a probability(about 90% in my case).
My Temporary Fix
  1. Disconnect Principled node from Material Output.
  2. Disconnect Displacement node from Material Output.
  3. Disconnect Principled node color INPUT from any node.
  4. Replug Principled node into Material Output.
  5. Replug Displacement node into Material Output.
  6. Replug Principled node color INPUT to previous color nodes.
// If I tried to connect/disconnect or add other nodes at this point, the same problem will come back again.
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Jan 6 2021, 6:00 PM
Could you share the .blend file please?
(this ensures we are all on the same page - and also saves a bit of setup time, if multiple devs are looking at this, this adds up...)
Hi Philipp,
File uploaded with packed sample EXR image.
Problem already shown in this file on my PC, once goes into Render View.
I should have used Vector Displacement node instead of Displacement node, but the problem remains. If it doesn't show up, changing frames on the timeline will trigger the problem too.
Evan Wilson (EAW) closed this task as Archived.Jan 7 2021, 9:55 AM
Thank you for the report.
Blender defaults to Linear and Premultiplied alpha for float images. When the alpha output socket of the image texture node is connected to anything, the color channels are un-premultiplied (divided by the alpha channel), which gives you that large offset.
Change the Color Space to Non-Color. The "colors" in a displacement map aren't really colors, but data. This tells Blender not to do any color management on the imported image.
