Blend cloud smaller images not showing up on Safari (Mac - Big Sur)
Hi, see attached screen cap. When I click on the images, I get a grey square. If I find the magnify area, I can get a larger version or download but the (large thumbnails?) are not visible.
Hi Mike,
It's my first time reporting anything so I don't know what the accepted protocol with these things is so I'm going to say 'thank you' because it seems the right thing to do.
I don't know whether that will give you an annoying notification which will distract you from your work - if it does, please tell me and I won't disturb again :)
I appreciate the amazing stuff you all do with Blender and Blendcloud.
Adam
Mike Newbon (mikenewbon) closed this task as Resolved.Jan 12 2021, 1:44 PM
Hey @Adam Allen-Foord (adamaf) - sorry it took so long to resolve. Please try it out and let me know if it has been fixed for you.
Explanation:
I wasted a lot of time assuming it was a CSS issue and going backwards and forwards with this - it turned out to be a HTML issue.
The issue was related to the image set - for some reason safari doesn't want to play nice with this one instance. I tried a few things - editing the element directly inline and removing one of the image sets seemed to fix the problem, but copying that to production didn't fix it. The image set really wasn't achieving anything here due to the upper-limit of the modal width being so small, so I just switched to a simple image and it has fixed the issue.
Hi @Mike Newbon (mikenewbon),
Yes, working fine, many thanks :)
Adam
