Safe Buffers checkbox disables cryptomatte metadata
Closed, ResolvedPublicBUG
Graphics card: GeForce RTX 3070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.79
Broken: version: 2.92.0 Alpha, branch: master, commit date: 2021-01-07 22:28, hash: rB61f1faac3f21
Also Broken: version 2.83 LTS (We found this bug today at work)
If the "safe buffers" checkbox (in the render>performance>final render tab) is checked, blender doesn't write/create the metadata for the cryptomatte. This is especially important if blender is used in a compositing pipeline with nuke or fusion.
  1. Open a new Blender file
  2. Check any cryptomatte option in the Output Properties (I used "Object")
  3. Navigate in the Property Panel to Render Properties > Performance >Final Render
  4. Check Save Buffers
  5. Render the scene
  6. In the image editor of the rendered image press "n" or open the side panel
  7. Navigate to Image > Metadata
There will be only the metadata information from Output Properties> Metadata
But the cycles metadata and especially the metadata for the cryptomatte are missing.
Here is an example of the metadata:
with Safe Buffers:
whitout Safe Buffers (these metadata are important):
Robert Guetzkow (rjg) changed the task status from Needs Triage to Confirmed.Jan 9 2021, 11:18 AM
I can confirm the issue. This appears to be a similar problem to T64953 but for Save Buffers.
Brecht Van Lommel (brecht) changed the subtype of this task from "Report" to "Bug".Jan 18 2021, 12:36 PM
