CUDA illegal address in cuStreamSynchronize
Operating system: Windows 10
Graphics card: GeForce RTX 2070 (2 cards)
Broken: 2.92 Alpha, fb4113defb46, master, 2020-11-12
Worked: 2.91, 0f45cab862b8, master, 2020-11-25
Cycles, with glass shader, in render view and edit mode causes this error. Blender needs restart, otherwise render view does not update.
  1. Switch to Cycles Render
  2. Apply glass shader to cube
  3. Switch to render view
  4. Go to Edit mode
  5. Switch to face selection mode
  6. (if needed) Select a face.
Notes: Not clear if this is a Blender issue or a Nvidia driver issue. Will keep an eye on driver updates and whether it solves this.
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Feb 24 2021, 1:03 PM
Just to make sure:
Hi Philipp,
I've tested with the version you've provided and the issue is no longer present.
Retraced all the steps and actually switched repeatedly between object mode and edit mode and it all went smooth.
Seems like it was solved in the meantime.
Thanks! :D
Philipp Oeser (lichtwerk) closed this task as Resolved.Feb 24 2021, 2:19 PM
Glad to hear!, will close then.
