Cycles viewport denoising fails with OIDN if it's not selected before going into rendered mode (GPU)
Closed, ResolvedPublicBUG
Graphics card: GeForce GTX 1070 with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 451.67
Broken: version:
  • 2.93.0 Alpha, branch: master, commit date: 2021-01-13 23:58, hash: rB0876829e7a77
  • 2.92.0 Beta, branch: master, commit date: 2021-01-14 20:13, hash: rB30dd31a7b3d8
  • 2.92.0 Alpha, branch: master, commit date: 2020-12-17 20:43, hash: rB23233fcf056e
  • 2.92.0 Alpha, branch: master, commit date: 2020-11-19 22:15, hash: rBfdd3032f8fad
  • 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash: rB0f45cab862b8
Worked: Never?
If you're using Cycles, device set to GPU, and are in the rendered view mode, if you then select viewport denoising with OIDN the viewport will fail to render and you'll receive a "Denoiser type not supported by compute device"
However, if you select the denoising option _before_ going into rendered mode, things will work fine. See steps below.
  • Start with default scene
  • Enable Cycles, set the device to GPU, AND enable Viewport denoising set to OIDN
  • Switch to rendered mode
  • Things work fine. Toggle the viewport denoising option on and off. Still works fine.
  • Go back to Solid shading mode AND disable Viewport denoising
  • Go back to Rendered mode. Works fine
  • Enable Viewport denoising now. Fails
Robert Guetzkow (rjg) changed the task status from Needs Triage to Confirmed.EditedJan 18 2021, 11:18 AM
The computation of OpenImageDenoise is happening on the CPU. However, if it works or not shouldn't depend on the order of operations, so even if this wouldn't be supported in newer versions because of a reason unknown to me, it should behave consistently.
I have to correct myself, the same issue can be reproduced in 2.91.0.
Brecht Van Lommel (brecht) changed the subtype of this task from "Report" to "Bug".Jan 18 2021, 12:36 PM
Brecht Van Lommel (brecht) triaged this task as High priority.Jan 18 2021, 1:11 PM
