Operating system:MocOS Big Sur 11.1 2.4 GHz 8-Core Intel Core i9 64 GB 2667 MHz DDR4
Graphics card: Intel UHD Graphics 630 1536 MB
Broken: Version 2.91.0 (2.91.0 2020-11-25)
Worked: (2.81)
Blender crashes randomly on Mac OS. Sometimes after just sitting idle for several minutes, other times after editing meshes or attempt to render in viewport (Cycles or EEVEE) or render frames or animation.
Very hard to find a definitive pattern when crash occurs.
Seems that when I create files on version 2.83 or 2.91 it works better, but loading files (especially large files) from earlier versions crash very often.
See OS crash log below :
Process: Blender [741]
Path: /Applications/Blender_291/Blender.app/Contents/MacOS/Blender
Identifier: org.blenderfoundation.blender
Version: 2.91.0 (2.91.0 2020-11-25)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Blender [741]
User ID: 502
Date/Time: 2021-01-18 10:23:19.889 -0700
OS Version: macOS 11.1 (20C69)
Report Version: 12
Bridge OS Version: 5.1 (18P3030)
Anonymous UUID: 531B82B0-E5F1-69EA-9B13-8CDC7102AB5B
Time Awake Since Boot: 660 seconds
System Integrity Protection: enabled
Crashed Thread: 1
Exception Type: EXC_CRASH (SIGSEGV)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: Blender [741]
Thread 0:: Dispatch queue: com.apple.main-thread
0 GLEngine 0x00007fff6cbc4690 gleRunVertexSubmitImmediate + 5632
1 GLEngine 0x00007fff6cb4b197 glDrawElementsInstancedBaseVertex_GL3Exec + 807
2 libGL.dylib 0x00007fff6ca923cf glDrawElementsInstancedBaseVertex + 45
3 org.blenderfoundation.blender 0x000000010083c775 draw_call_single_do + 469
4 org.blenderfoundation.blender 0x000000010083bf1a drw_draw_pass_ex + 1626
5 org.blenderfoundation.blender 0x000000010083b8af DRW_draw_pass + 31
6 org.blenderfoundation.blender 0x000000010087cf4d OVERLAY_draw_scene + 365
7 org.blenderfoundation.blender 0x0000000100832d8a drw_engines_draw_scene + 186
8 org.blenderfoundation.blender 0x000000010083198d DRW_draw_render_loop_ex + 1565
9 org.blenderfoundation.blender 0x00000001010c3778 view3d_main_region_draw + 136
10 org.blenderfoundation.blender 0x0000000100c71e70 ED_region_do_draw + 336
11 org.blenderfoundation.blender 0x00000001006f849d wm_draw_update + 1757
12 org.blenderfoundation.blender 0x00000001006f6110 WM_main + 48
13 org.blenderfoundation.blender 0x00000001002f297a main + 890
14 libdyld.dylib 0x00007fff203aa621 start + 1
Thread 1 Crashed:
0 libsystem_kernel.dylib 0x00007fff2035aeba semaphore_wait_trap + 10
1 libdispatch.dylib 0x00007fff201e4c5c _dispatch_sema4_wait + 16
2 libdispatch.dylib 0x00007fff201e512e _dispatch_semaphore_wait_slow + 98
3 org.blenderfoundation.blender 0x000000010624dc32 IlmThread_2_4::(anonymous namespace)::DefaultWorkerThread::run() + 50
4 org.blenderfoundation.blender 0x000000010624c79e void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_4::Thread::*)(), IlmThread_2_4::Thread*> >(void*) + 62
5 libsystem_pthread.dylib 0x00007fff2038f950 _pthread_start + 224
6 libsystem_pthread.dylib 0x00007fff2038b47b thread_start + 15
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:: AMCP Logging Spool
1 com.apple.audio.caulk 0x00007fff2848a92a caulk::mach::semaphore::wait_or_error() + 16
2 com.apple.audio.caulk 0x00007fff284776e6 caulk::semaphore::timed_wait(double) + 110
3 com.apple.audio.caulk 0x00007fff28477634 caulk::concurrent::details::worker_thread::run() + 30
4 com.apple.audio.caulk 0x00007fff284773c0 void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 45
Thread 18:: com.apple.audio.IOThread.client
0 libsystem_kernel.dylib 0x00007fff2035ae7e mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff2035b1f0 mach_msg + 60
2 com.apple.audio.CoreAudio 0x00007fff21e7dde5 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 111
3 com.apple.audio.CoreAudio 0x00007fff21d19477 invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int) + 3435
4 com.apple.audio.CoreAudio 0x00007fff21ebcf3a HALB_IOThread::Entry(void*) + 72
Thread 19:
1 org.blenderfoundation.blender 0x00000001006ecc68 tbb::internal::rml::private_worker::run() + 104
2 org.blenderfoundation.blender 0x00000001006ecbf9 tbb::internal::rml::private_worker::thread_routine(void*) + 9
3 libsystem_pthread.dylib 0x00007fff2038f950 _pthread_start + 224
4 libsystem_pthread.dylib 0x00007fff2038b47b thread_start + 15
Thread 20:
Thread 21:
Thread 22:
Thread 23:
Thread 24:
Thread 25:
Thread 26:
Thread 27:
Thread 28:
Thread 29:
Thread 30:
Thread 31:
Thread 32:
Thread 33:
Thread 34:: com.apple.NSEventThread
2 com.apple.CoreFoundation 0x00007fff20487bf7 __CFRunLoopServiceMachPort + 316
3 com.apple.CoreFoundation 0x00007fff204862ca __CFRunLoopRun + 1315
4 com.apple.CoreFoundation 0x00007fff204856ce CFRunLoopRunSpecific + 563
5 com.apple.AppKit 0x00007fff22e28c16 _NSEventThread + 124
6 libsystem_pthread.dylib 0x00007fff2038f950 _pthread_start + 224
7 libsystem_pthread.dylib 0x00007fff2038b47b thread_start + 15
Thread 35:: Dispatch queue: com.apple.opengl.cvmDoWork
2 libdispatch.dylib 0x00007fff201fa776 _dispatch_mach_send_and_wait_for_reply + 518
3 libdispatch.dylib 0x00007fff201fab6e dispatch_mach_send_with_result_and_wait_for_reply + 50
4 libxpc.dylib 0x00007fff200d21ac xpc_connection_send_message_with_reply_sync + 238
5 libCoreVMClient.dylib 0x00007fff6c86670a cvms_element_build_and_get_internal + 229
6 libCoreVMClient.dylib 0x00007fff6c86660e cvms_element_build_from_source + 169
7 libCVMSPluginSupport.dylib 0x00007fff6c87bf14 cvm_deferred_build_modular(void*) + 422
8 libdispatch.dylib 0x00007fff201e47c7 _dispatch_client_callout + 8
9 libdispatch.dylib 0x00007fff201ea5fe _dispatch_lane_serial_drain + 606
10 libdispatch.dylib 0x00007fff201eb0cb _dispatch_lane_invoke + 375
11 libdispatch.dylib 0x00007fff201f4c5d _dispatch_workloop_worker_thread + 819
12 libsystem_pthread.dylib 0x00007fff2038c499 _pthread_wqthread + 314
13 libsystem_pthread.dylib 0x00007fff2038b467 start_wqthread + 15
Thread 36:
0 libsystem_pthread.dylib 0x00007fff2038b458 start_wqthread + 0
Thread 37:
Thread 38:
Thread 1 crashed with X86 Thread State (64-bit):
rax: 0x000000000000000e rbx: 0x00006000001cd210 rcx: 0x000070000c275f08 rdx: 0x0000000000000028
rdi: 0x0000000000001903 rsi: 0x0000000000000003 rbp: 0x000070000c275f20 rsp: 0x000070000c275f08
r8: 0x0000000000001703 r9: 0x0000000000000000 r10: 0x0000000000002503 r11: 0x0000000000000246
r12: 0x0000000000000000 r13: 0x0000000000000000 r14: 0x00006000001cd210 r15: 0xffffffffffffffff
rip: 0x00007fff2035aeba rfl: 0x0000000000000246 cr2: 0x000070000c275ff8
Logical CPU: 0
Error Code: 0x01000024
Trap Number: 133
Thread 1 instruction stream not available.
Thread 1 last branch register state not available.
Binary Images:
0x1001ae000 - 0x10a981fff +org.blenderfoundation.blender (2.91.0 - 2.91.0 2020-11-25) <A18D3102-5B87-3997-9B07-0AAF11241DA7> /Applications/Blender_291/Blender.app/Contents/MacOS/Blender
0x11162e000 - 0x11169afff +libomp.dylib (0) <535E76BC-1650-3651-9C62-97A995647107> /Applications/Blender_291/Blender.app/Contents/Resources/lib/libomp.dylib
0x115871000 - 0x115874fff com.apple.CloudDocsFileProvider (1.0 - 726) <89C091B1-BB9C-3919-8051-B8A86E94FC57> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/CloudDocsFileProvider.bundle/Contents/MacOS/CloudDocsFileProvider
0x117196000 - 0x1172f9fff com.apple.audio.units.Components (1.14 - 1.14) <79BEEEC4-3C3B-3C49-AF25-792C6CE5BF68> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x117332000 - 0x1178e1fff com.apple.audio.AudioDSPComponents (1.0 - 1) <6F81B244-A378-3A25-BFBB-5C3EFCF560B6> /System/Library/Components/AudioDSP.component/Contents/MacOS/AudioDSP
0x117d2e000 - 0x117d3dfff libobjc-trampolines.dylib (818.2) <12B587A2-8631-3B7A-B862-5091C411AC2C> /usr/lib/libobjc-trampolines.dylib
0x117d89000 - 0x118108fff com.apple.AMDRadeonX6000MTLDriver (4.2.13 - 4.0.2) <1448CDC1-D6D3-3312-A291-7E17D1610D5D> /System/Library/Extensions/AMDRadeonX6000MTLDriver.bundle/Contents/MacOS/AMDRadeonX6000MTLDriver
0x11898e000 - 0x118ae1fff com.apple.AMDRadeonX6000GLDriver (4.2.13 - 4.0.2) <5669BE74-1CF9-3829-9F6D-4FFFC8147A8E> /System/Library/Extensions/AMDRadeonX6000GLDriver.bundle/Contents/MacOS/AMDRadeonX6000GLDriver
0x11f305000 - 0x11f306fff +_heapq.cpython-37m-darwin.so (0) <20086BF0-0130-3463-B824-F98C6D51BE39> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_heapq.cpython-37m-darwin.so
0x11f50f000 - 0x11f514fff +math.cpython-37m-darwin.so (0) <F76ADA60-2AAA-34A7-BB31-26405F501673> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/math.cpython-37m-darwin.so
0x11fbf1000 - 0x11fe0afff +_hashlib.cpython-37m-darwin.so (0) <C9C14775-5B8E-3512-98E0-537BF4984A54> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_hashlib.cpython-37m-darwin.so
0x11fea3000 - 0x11fea8fff +_blake2.cpython-37m-darwin.so (0) <7FD886EF-36D2-329A-B8CE-AAF09D7269E8> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_blake2.cpython-37m-darwin.so
0x11feb2000 - 0x11fec2fff +_sha3.cpython-37m-darwin.so (0) <D7698BDC-8C9A-3198-81AD-6044B3FFB378> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_sha3.cpython-37m-darwin.so
0x11fecd000 - 0x11fecdfff +_bisect.cpython-37m-darwin.so (0) <1F871C75-B7E3-3531-B4FD-9127E49825DD> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_bisect.cpython-37m-darwin.so
0x11fed5000 - 0x11fed6fff +_random.cpython-37m-darwin.so (0) <6EA0F0A9-EB67-39B1-8BC9-CD20C494E8F6> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_random.cpython-37m-darwin.so
0x11ff1e000 - 0x11ff24fff +_json.cpython-37m-darwin.so (0) <6C52949D-6062-3DBB-8601-8FC34D195603> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_json.cpython-37m-darwin.so
0x11ffad000 - 0x11ffbffff +zlib.cpython-37m-darwin.so (0) <8EF3CAAD-13A3-3C17-B25F-8F3D16F65850> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/zlib.cpython-37m-darwin.so
0x11ffca000 - 0x11ffe0fff +_bz2.cpython-37m-darwin.so (0) <E0F8E75D-B92D-3624-ABAE-FAC3B29181F2> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_bz2.cpython-37m-darwin.so
0x11ffeb000 - 0x120019fff +_lzma.cpython-37m-darwin.so (0) <B82293C1-035E-3C19-B6E1-E93BEB44DA1B> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_lzma.cpython-37m-darwin.so
0x120028000 - 0x120028fff +grp.cpython-37m-darwin.so (0) <DEEAC15B-D065-3D28-9F79-32426A8C67B7> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/grp.cpython-37m-darwin.so
0x120030000 - 0x120034fff +_struct.cpython-37m-darwin.so (0) <AFC22996-5DC5-3B8F-B881-06BF3CE37AA9> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_struct.cpython-37m-darwin.so
0x120042000 - 0x120048fff +binascii.cpython-37m-darwin.so (0) <03796BF6-3DC5-3C9B-9D69-32549A2602EB> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/binascii.cpython-37m-darwin.so
0x120311000 - 0x12031ffff +_datetime.cpython-37m-darwin.so (0) <87D99FDA-6F48-3410-B90A-CD992418681B> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_datetime.cpython-37m-darwin.so
0x120a8d000 - 0x120a90fff com.apple.FileProviderOverride (326 - 326) <30A4FABB-09A9-3847-9097-C47264FE43CC> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FileProviderOverride.bundle/Contents/MacOS/FileProviderOverride
0x120aa1000 - 0x120abcfff com.apple.findersync.fileprovideroverride.FinderSyncCollaborationFileProviderOverride (1.0 - 1350.2.10) <13CEAF66-0099-3F21-B489-6DA4F088AB43> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FinderSyncCollaborationFileProviderOverride.bundle/Contents/MacOS/FinderSyncCollaborationFileProviderOverride
0x121019000 - 0x1210b4fff dyld (832.7.1) <DEA51514-B4E8-3368-979B-89D0F8397ABC> /usr/lib/dyld
0x7fff200c5000 - 0x7fff200c6fff libsystem_blocks.dylib (78) <9CF131C6-16FB-3DD0-B046-9E0B6AB99935> /usr/lib/system/libsystem_blocks.dylib
0x7fff200c7000 - 0x7fff200fcfff libxpc.dylib (2038.40.38) <003A027D-9CE3-3794-A319-88495844662D> /usr/lib/system/libxpc.dylib
0x7fff200fd000 - 0x7fff20114fff libsystem_trace.dylib (1277.50.1) <48C14376-626E-3C81-B0F5-7416E64580C7> /usr/lib/system/libsystem_trace.dylib
0x7fff20115000 - 0x7fff201b3fff libcorecrypto.dylib (1000.60.19) <92F0211E-506E-3760-A3C2-808BF3905C07> /usr/lib/system/libcorecrypto.dylib
0x7fff201b4000 - 0x7fff201e0fff libsystem_malloc.dylib (317.40.8) <2EF43B96-90FB-3C50-B73E-035238504E33> /usr/lib/system/libsystem_malloc.dylib
0x7fff201e1000 - 0x7fff20225fff libdispatch.dylib (1271.40.12) <CEF1460B-1362-381A-AE69-6BCE2D8C215B> /usr/lib/system/libdispatch.dylib
0x7fff20226000 - 0x7fff2025efff libobjc.A.dylib (818.2) <45EA2DE2-B612-3486-B156-2359CE279159> /usr/lib/libobjc.A.dylib
0x7fff2025f000 - 0x7fff20261fff libsystem_featureflags.dylib (28.60.1) <7B4EBDDB-244E-3F78-8895-566FE22288F3> /usr/lib/system/libsystem_featureflags.dylib
0x7fff20262000 - 0x7fff202eafff libsystem_c.dylib (1439.40.11) <06D9F593-C815-385D-957F-2B5BCC223A8A> /usr/lib/system/libsystem_c.dylib
0x7fff202eb000 - 0x7fff20340fff libc++.1.dylib (904.4) <AE3A940A-7A9C-3F99-B175-3511528D8DFE> /usr/lib/libc++.1.dylib
0x7fff20341000 - 0x7fff20359fff libc++abi.dylib (904.4) <DDFCBF9C-432D-3B8A-8641-578D2EDDCAD8> /usr/lib/libc++abi.dylib
0x7fff2035a000 - 0x7fff20388fff libsystem_kernel.dylib (7195.60.75) <4BD61365-29AF-3234-8002-D989D295FDBB> /usr/lib/system/libsystem_kernel.dylib
0x7fff20389000 - 0x7fff20394fff libsystem_pthread.dylib (454.60.1) <8DD3A0BC-2C92-31E3-BBAB-CE923A4342E4> /usr/lib/system/libsystem_pthread.dylib
0x7fff20395000 - 0x7fff203cffff libdyld.dylib (832.7.1) <2F8A14F5-7CB8-3EDD-85EA-7FA960BBC04E> /usr/lib/system/libdyld.dylib
0x7fff203d0000 - 0x7fff203d9fff libsystem_platform.dylib (254.60.1) <3F7F6461-7B5C-3197-ACD7-C8A0CFCC6F55> /usr/lib/system/libsystem_platform.dylib
0x7fff203da000 - 0x7fff20405fff libsystem_info.dylib (542.40.3) <0979757C-5F0D-3F5A-9E0E-EBF234B310AF> /usr/lib/system/libsystem_info.dylib
0x7fff20406000 - 0x7fff208a1fff com.apple.CoreFoundation (6.9 - 1770.300) <EAC298C4-CE3E-3551-A832-42ED9A13EF74> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff208a2000 - 0x7fff20ad1fff com.apple.LaunchServices (1122.11 - 1122.11) <CAEEC254-68AE-39B5-8452-EC3E1EE8577B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff20ad2000 - 0x7fff20ba5fff com.apple.gpusw.MetalTools (1.0 - 1) <C235D5FA-0B9D-3E72-A8CE-67174E1B9E7C> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff20ba6000 - 0x7fff20e09fff libBLAS.dylib (1336.40.1) <AD2D155C-1294-3D10-817A-F6A581E6ACF1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff20e0a000 - 0x7fff20e57fff com.apple.Lexicon-framework (1.0 - 86.1) <D54364A6-1C4C-33D7-8B24-C753777B3654> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff20e58000 - 0x7fff20ec6fff libSparse.dylib (106) <60559226-6E4B-3601-B6CA-E3B85B5EB27B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff20ec7000 - 0x7fff20f44fff com.apple.SystemConfiguration (1.20 - 1.20) <8524EE4C-628F-315A-9531-44DD83CE275E> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff20f45000 - 0x7fff20f7afff libCRFSuite.dylib (50) <6CA29EAA-0585-3682-9AD2-DFD3D87A74D4> /usr/lib/libCRFSuite.dylib
0x7fff20f7b000 - 0x7fff211b2fff libmecabra.dylib (929.1.1) <39F5AD50-3AF2-3CFB-BD21-2DC45AA92A91> /usr/lib/libmecabra.dylib
0x7fff211b3000 - 0x7fff21516fff com.apple.Foundation (6.9 - 1770.300) <44A7115B-7FF0-3300-B61B-0FA71B63C715> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff21517000 - 0x7fff21603fff com.apple.LanguageModeling (1.0 - 247.1) <BCB1F8A7-54B9-36D1-B742-70DF7657BF0B> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff21604000 - 0x7fff2173afff com.apple.CoreDisplay (231.3 - 231.3) <229BF97A-1D56-3CB4-8338-E0D464F73A33> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff2173b000 - 0x7fff219b0fff com.apple.audio.AudioToolboxCore (1.0 - 1180.23) <56821802-07B9-3FA9-AF73-D943BAE0DE57> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
0x7fff219b1000 - 0x7fff21b99fff com.apple.CoreText (677.2.0.5 - 677.2.0.5) <B0B2A8DD-A6F1-3EF7-9351-1BA604353A11> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff21b9a000 - 0x7fff2223dfff com.apple.audio.CoreAudio (5.0 - 5.0) <DF623EC9-FC55-3B3C-94FF-6A5C50A981B3> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff2223e000 - 0x7fff2258ffff com.apple.security (7.0 - 59754.60.13) <A20AB68D-51DA-340B-B813-F2AFC81F7143> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff22590000 - 0x7fff227f1fff libicucore.A.dylib (66109) <6C0A0196-2778-3035-81CE-7CA48D6C0628> /usr/lib/libicucore.A.dylib
0x7fff227f2000 - 0x7fff227fbfff libsystem_darwin.dylib (1439.40.11) <BD269412-C9D0-32EE-B42B-B09A187A9B95> /usr/lib/system/libsystem_darwin.dylib
0x7fff227fc000 - 0x7fff22ae3fff com.apple.CoreServices.CarbonCore (1307 - 1307) <9C615967-6D8E-307F-B028-6278A4FA7C8C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff22ae4000 - 0x7fff22b22fff com.apple.CoreServicesInternal (476 - 476) <FD1692F7-A4B4-3FE5-B9C8-E0840D53C7D0> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff22b23000 - 0x7fff22b5dfff com.apple.CSStore (1122.11 - 1122.11) <088D0108-AA14-3610-86A0-89D0C605384F> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
0x7fff22b5e000 - 0x7fff22c0bfff com.apple.framework.IOKit (2.0.2 - 1845.60.2) <F2299682-5884-363F-9069-AA804E712C74> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff22c0c000 - 0x7fff22c17fff libsystem_notify.dylib (279.40.4) <98D74EEF-60D9-3665-B877-7BE1558BA83E> /usr/lib/system/libsystem_notify.dylib
0x7fff22c18000 - 0x7fff22c63fff libsandbox.1.dylib (1441.60.4) <243C983D-0AEF-3A09-9489-CF1FC75925CC> /usr/lib/libsandbox.1.dylib
0x7fff22c64000 - 0x7fff239c6fff com.apple.AppKit (6.9 - 2022.20.119) <4CB42914-672D-3AF0-A0A5-2209088A3DA0> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff239c7000 - 0x7fff23c1afff com.apple.UIFoundation (1.0 - 726.11) <71C63CE5-094D-34AF-B538-8DCAB3B66DE9> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff23c1b000 - 0x7fff23c2dfff com.apple.UniformTypeIdentifiers (633.0.2 - 633.0.2) <7BEC7DDC-2B7A-3B5D-B994-5FA352FC485A> /System/Library/Frameworks/UniformTypeIdentifiers.framework/Versions/A/UniformTypeIdentifiers
0x7fff23c2e000 - 0x7fff23db8fff com.apple.desktopservices (1.17 - 1346.2.1) <732C8A0C-E7F8-372D-AE5B-84497067135E> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff23db9000 - 0x7fff23dcbfff com.apple.metadata.SpotlightLinguistics (1.0 - 1) <C49ACE74-8DBC-300C-8A31-FD95FE8BC03A> /System/Library/PrivateFrameworks/SpotlightLinguistics.framework/Versions/A/SpotlightLinguistics
0x7fff24085000 - 0x7fff246c8fff libnetwork.dylib (2288.60.5) <180FE916-8DD6-3385-B231-0C423B7D2BD3> /usr/lib/libnetwork.dylib
0x7fff246c9000 - 0x7fff24b66fff com.apple.CFNetwork (1209.1 - 1209.1) <60DE4CD6-B5AF-3E0E-8AF1-39ECFC1B8C98> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff24b67000 - 0x7fff24b75fff libsystem_networkextension.dylib (1295.60.5) <F476B1CB-3561-30C5-A78E-44E99B1720A3> /usr/lib/system/libsystem_networkextension.dylib
0x7fff24b76000 - 0x7fff24b76fff libenergytrace.dylib (22) <9BE5E51A-F531-3D59-BBBC-486FFF97BD30> /usr/lib/libenergytrace.dylib
0x7fff24b77000 - 0x7fff24bd2fff libMobileGestalt.dylib (978.60.2) <F721B185-0E6A-396B-A50F-0F55810D9A67> /usr/lib/libMobileGestalt.dylib
0x7fff24bd3000 - 0x7fff24be9fff libsystem_asl.dylib (385) <940C5BB9-4928-3A63-97F2-132797C8B7E5> /usr/lib/system/libsystem_asl.dylib
0x7fff24bea000 - 0x7fff24c01fff com.apple.TCC (1.0 - 1) <457D5F24-A346-38FC-8FA1-43B0C835E035> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff24c02000 - 0x7fff24f67fff com.apple.SkyLight (1.600.0 - 569.6) <35876384-45F9-3C62-995B-38EC31BE75D7> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff24f68000 - 0x7fff255fbfff com.apple.CoreGraphics (2.0 - 1463.2.2) <323F725F-CB03-3AAD-AFBC-37B430B3FD4E> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff255fc000 - 0x7fff256f2fff com.apple.ColorSync (4.13.0 - 3472) <7387EBC7-CBD9-34FE-B4A3-345E4750FD81> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff256f3000 - 0x7fff2574efff com.apple.HIServices (1.22 - 713) <9AF2CDD9-8B68-3606-8C9E-1842420ACDA7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff25afa000 - 0x7fff25f18fff com.apple.CoreData (120 - 1044.3) <76179A55-CA89-3967-A0A7-C419DB735983> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff25f19000 - 0x7fff25f2ffff com.apple.ProtocolBuffer (1 - 285.20.8.8.1) <8EE538E7-2BB1-3E29-8FC3-938335998B22> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff25f30000 - 0x7fff260effff libsqlite3.dylib (321.1) <D7017429-8D46-3ECB-8B70-4625C74918F3> /usr/lib/libsqlite3.dylib
0x7fff260f0000 - 0x7fff2616cfff com.apple.Accounts (113 - 113) <99421243-019F-3A2F-A671-092026FA2F74> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fff2616d000 - 0x7fff26185fff com.apple.commonutilities (8.0 - 900) <76711775-FF46-38CA-88F3-B4201C285C7F> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
0x7fff26186000 - 0x7fff26207fff com.apple.BaseBoard (526 - 526) <38C24B3A-8226-3FD5-8C28-B11D02747B56> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
0x7fff26208000 - 0x7fff26253fff com.apple.RunningBoardServices (1.0 - 505.60.2) <F99A0D0C-D063-3E3F-8D1F-0E0B35E7CE2C> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
0x7fff26254000 - 0x7fff262c9fff com.apple.AE (918.0.1 - 918.0.1) <3A298716-A130-345E-B8FF-74194849015E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff262ca000 - 0x7fff262d0fff libdns_services.dylib (1310.60.4) <61EB26AD-C09E-3140-955E-16BF7DD2D6E3> /usr/lib/libdns_services.dylib
0x7fff262d1000 - 0x7fff262d8fff libsystem_symptoms.dylib (1431.60.1) <88F35AAC-746F-3176-81DF-49CE3D285636> /usr/lib/system/libsystem_symptoms.dylib
0x7fff262d9000 - 0x7fff2645dfff com.apple.Network (1.0 - 1) <EED4099E-B17C-3E0B-AA8F-78A2D4F26CBF> /System/Library/Frameworks/Network.framework/Versions/A/Network
0x7fff2645e000 - 0x7fff26482fff com.apple.analyticsd (1.0 - 1) <99FE0234-454F-36FF-9DE9-36B94D8753F9> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
0x7fff26483000 - 0x7fff26485fff libDiagnosticMessagesClient.dylib (112) <1014A32B-89EE-3ADD-971F-9CB973172F69> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff26486000 - 0x7fff264d2fff com.apple.spotlight.metadata.utilities (1.0 - 2150.7.2) <37A1E760-2006-366C-9FAC-FB70227393FB> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0x7fff264d3000 - 0x7fff2656dfff com.apple.Metadata (10.7.0 - 2150.7.2) <509C6597-ABB2-3B81-8E09-C51A755CCDA2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff2656e000 - 0x7fff26574fff com.apple.DiskArbitration (2.7 - 2.7) <83DED679-BE65-3475-8AFF-D664BBAFA60A> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff26575000 - 0x7fff26c1bfff com.apple.vImage (8.1 - 544) <305D97CC-B47C-32FD-9EC5-43259A469A14> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff26c1c000 - 0x7fff26ee9fff com.apple.QuartzCore (1.11 - 925.5) <D59138DC-10CD-3DF8-9F04-CCDB6102C370> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff26eea000 - 0x7fff26f2bfff libFontRegistry.dylib (309) <790676A3-2B74-3239-A60D-429069933542> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff26f2c000 - 0x7fff2706dfff com.apple.coreui (2.1 - 689.4) <0DA8F4E0-9473-374E-8B48-F0A40AEC63CE> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff2706e000 - 0x7fff27159fff com.apple.ViewBridge (551.3 - 551.3) <36D0DCA7-CAAE-33C1-90F6-98876CB8BCF3> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff2715a000 - 0x7fff27165fff com.apple.PerformanceAnalysis (1.275 - 275) <2F811EE6-D4D4-347E-B4A0-961F0DF050E5> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff27166000 - 0x7fff27175fff com.apple.OpenDirectory (11.1 - 230.40.1) <7710743E-6F55-342E-88FA-18796CF83700> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff27176000 - 0x7fff27195fff com.apple.CFOpenDirectory (11.1 - 230.40.1) <32ECCB06-56D8-3704-935B-7D5363B2988E> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff27196000 - 0x7fff2719efff com.apple.CoreServices.FSEvents (1290.40.2 - 1290.40.2) <FB18B8D7-C7F5-3CAB-B538-3F4B4E85D1F1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff2719f000 - 0x7fff271c3fff com.apple.coreservices.SharedFileList (144 - 144) <93D2192D-7A27-3FD4-B3AB-A4DCBF8419B7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff271c4000 - 0x7fff271c6fff libapp_launch_measurement.dylib (14.1) <9E2700C3-E993-3695-988E-FEF798B75E34> /usr/lib/libapp_launch_measurement.dylib
0x7fff271c7000 - 0x7fff2720ffff com.apple.CoreAutoLayout (1.0 - 21.10.1) <998BC461-F4F5-396E-9798-1C8126AD61DA> /System/Library/PrivateFrameworks/CoreAutoLayout.framework/Versions/A/CoreAutoLayout
0x7fff27210000 - 0x7fff272f2fff libxml2.2.dylib (34.8) <68396181-8100-390C-8886-EFB79F5B484C> /usr/lib/libxml2.2.dylib
0x7fff272f3000 - 0x7fff2733ffff com.apple.CoreVideo (1.8 - 408.4) <0D5AD16E-A871-3ACB-B910-39B87928E937> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff27340000 - 0x7fff27342fff com.apple.loginsupport (1.0 - 1) <4F860927-F6F5-3A99-A103-744CF365634F> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff27343000 - 0x7fff2736bfff com.apple.aps.framework (4.0 - 4.0) <F8FAEB30-AFCF-36A1-9E72-25681E6C5BF7> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff2736c000 - 0x7fff27389fff com.apple.UserManagement (1.0 - 1) <B5CEAA26-4C5F-3AF4-BDFE-35DE7C8DE1BE> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
0x7fff2738a000 - 0x7fff27529fff com.apple.cloudkit.CloudKit (962 - 962) <2D82071D-495C-3E80-BF3C-CB181FECB500> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff2752a000 - 0x7fff275acfff com.apple.CloudDocs (1.0 - 726) <C6CB66A3-64B6-31C5-BA53-8F564D4D5719> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff282a6000 - 0x7fff28322fff com.apple.corelocation (2420.12.12 - 2420.12.12) <F4C3D15D-BEFE-37A9-A55F-2BFB16842FBE> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff28323000 - 0x7fff28333fff libsystem_containermanager.dylib (318.60.1) <4ED09A19-04CC-3464-9EFB-F674932020B5> /usr/lib/system/libsystem_containermanager.dylib
0x7fff28334000 - 0x7fff28345fff com.apple.IOSurface (289.3 - 289.3) <A3B10665-5909-30EE-BE34-F3284D6D5975> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff28346000 - 0x7fff2834efff com.apple.IOAccelerator (439.52 - 439.52) <3944C92D-7838-3D2F-A453-9DB15C815D7B> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff2834f000 - 0x7fff28474fff com.apple.Metal (244.32.7 - 244.32.7) <413B81AE-653F-3CF7-B5A4-A4391436E6D1> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff28475000 - 0x7fff28491fff com.apple.audio.caulk (1.0 - 70) <952BA9D4-BAD3-3319-8C17-F7BB2655F80C> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
0x7fff28492000 - 0x7fff2857bfff com.apple.CoreMedia (1.0 - 2760.6.4.6) <CBCD783B-B3C9-37B8-835C-A3BACEC35BB5> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff2857c000 - 0x7fff286d8fff libFontParser.dylib (305.2.0.6) <76C6C92A-1B16-3FB7-9EA2-7227D379C20F> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
0x7fff286d9000 - 0x7fff289d8fff com.apple.HIToolbox (2.1.1 - 1060.4) <93518490-429F-3E31-8344-15D479C2F4CE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff289d9000 - 0x7fff289ecfff com.apple.framework.DFRFoundation (1.0 - 265) <FB85651D-6221-38AF-BD6D-29BFF5830D36> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff289ed000 - 0x7fff289f0fff com.apple.dt.XCTTargetBootstrap (1.0 - 17500) <13ADD312-F6F5-3C03-BD3B-9331B3851285> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
0x7fff289f1000 - 0x7fff28a1afff com.apple.CoreSVG (1.0 - 149) <A0DAE6AE-9DDA-37B4-A087-545A242CF982> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
0x7fff28a1b000 - 0x7fff28c54fff com.apple.ImageIO (3.3.0 - 2130.2.7) <0FE3D51B-EC76-3558-BD56-7BFF61A6793D> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff28c55000 - 0x7fff28fd2fff com.apple.CoreImage (16.1.0 - 1120.10) <46F1E4F5-DF8F-32D4-8D0C-6FCF2C27A5CD> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff28fd3000 - 0x7fff2902efff com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <E2377275-53D7-31A0-AEAF-0A0273B99B92> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff2902f000 - 0x7fff29032fff libsystem_configuration.dylib (1109.60.2) <C57B346B-0A03-3F87-BCAC-87B702FA0719> /usr/lib/system/libsystem_configuration.dylib
0x7fff29033000 - 0x7fff29037fff libsystem_sandbox.dylib (1441.60.4) <8CE27199-D633-31D2-AB08-56380A1DA9FB> /usr/lib/system/libsystem_sandbox.dylib
0x7fff29038000 - 0x7fff29039fff com.apple.AggregateDictionary (1.0 - 1) <7F2AFEBB-FF06-3194-B691-B411F3456962> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
0x7fff2903a000 - 0x7fff2903dfff com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <250CD2CA-E796-3CB0-9ADD-054998903B1D> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff2903e000 - 0x7fff2903ffff liblangid.dylib (136) <224DC045-2B60-39AF-B89E-E524175667F5> /usr/lib/liblangid.dylib
0x7fff29040000 - 0x7fff290e0fff com.apple.CoreNLP (1.0 - 245) <F876FD71-F077-3CF7-B94D-9E05A17E03D7> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff290e1000 - 0x7fff290e7fff com.apple.LinguisticData (1.0 - 399) <D1B7F1D5-EB9E-3555-BA57-3611FA153C44> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff290e8000 - 0x7fff297a4fff libBNNS.dylib (288.60.2) <E3FF47D5-7DD9-3A9E-A819-C79B0CC17C03> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff297a5000 - 0x7fff29978fff libvDSP.dylib (760.40.6) <9434101D-E001-357F-9503-9896C6011F52> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff29979000 - 0x7fff2998bfff com.apple.CoreEmoji (1.0 - 128) <7CCFC59A-8746-3E52-AF1D-1B67798E940C> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff2998c000 - 0x7fff29996fff com.apple.IOMobileFramebuffer (343.0.0 - 343.0.0) <9A6F913C-EC79-3FC1-A92C-3A1BA96D8DFB> /System/Library/PrivateFrameworks/IOMobileFramebuffer.framework/Versions/A/IOMobileFramebuffer
0x7fff29997000 - 0x7fff29a69fff com.apple.framework.CoreWLAN (16.0 - 1657) <AB3F880B-52C5-3006-82FE-9E6857C09DE7> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff29a6a000 - 0x7fff29c69fff com.apple.CoreUtils (6.5 - 650.5) <198A4273-5B92-3A05-A99D-7FD4914A959A> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff29c6a000 - 0x7fff29c8cfff com.apple.MobileKeyBag (2.0 - 1.0) <2B6BF51A-68B0-3108-9597-8B618E6B457B> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff29c8d000 - 0x7fff29c9dfff com.apple.AssertionServices (1.0 - 505.60.2) <9F8620BD-A58D-3A42-9B9E-DEC21517EF1A> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
0x7fff29c9e000 - 0x7fff29d2afff com.apple.securityfoundation (6.0 - 55240.40.4) <5F06D141-62F4-3405-BA72-24673B170A16> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff29d2b000 - 0x7fff29d34fff com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <C5E4B35C-FFDA-3423-890F-06DAD1F684F5> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff29d35000 - 0x7fff29d39fff com.apple.xpc.ServiceManagement (1.0 - 1) <2C03BEB7-915C-3A3A-A44F-A77775E1BFD5> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff29d3a000 - 0x7fff29d3cfff libquarantine.dylib (119.40.2) <19D42B9D-3336-3543-AF75-6E605EA31599> /usr/lib/system/libquarantine.dylib
0x7fff29d3d000 - 0x7fff29d48fff libCheckFix.dylib (31) <3381FC93-F188-348C-9345-5567A7116CEF> /usr/lib/libCheckFix.dylib
0x7fff29d49000 - 0x7fff29d60fff libcoretls.dylib (169) <9C244029-6B45-3583-B27F-BB7BBF84D814> /usr/lib/libcoretls.dylib
0x7fff29d61000 - 0x7fff29d71fff libbsm.0.dylib (68.40.1) <DC652D50-FA69-3801-9361-004D4D6832D0> /usr/lib/libbsm.0.dylib
0x7fff29d72000 - 0x7fff29dbbfff libmecab.dylib (929.1.1) <B5D8C96C-D3B8-32F8-84F9-A432CEAD4E5C> /usr/lib/libmecab.dylib
0x7fff29dbc000 - 0x7fff29dc1fff libgermantok.dylib (24) <F9772A76-7AFA-3E0B-A02C-A61FC6CA8D8B> /usr/lib/libgermantok.dylib
0x7fff29dc2000 - 0x7fff29dd7fff libLinearAlgebra.dylib (1336.40.1) <D2826FAB-174C-3CD6-A765-06D83A9A0EDB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff29dd8000 - 0x7fff29ffffff com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <231CF580-952A-32BC-A423-9B9756AC9744> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff2a000000 - 0x7fff2a04ffff com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <65A993E4-3DC2-3152-98D5-A1DF3DB4573F> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
0x7fff2a050000 - 0x7fff2a196fff com.apple.MLCompute (1.0 - 1) <BCEA1149-197E-398F-9424-E29B0AD0829F> /System/Library/Frameworks/MLCompute.framework/Versions/A/MLCompute
0x7fff2a197000 - 0x7fff2a1cdfff com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <F719DA57-EAAA-3527-B859-21025722932F> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff2a1ce000 - 0x7fff2a20bfff com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <FCCC0D3F-74D2-3107-82B3-E2B500E36AAE> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
0x7fff2a20c000 - 0x7fff2a29cfff com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <21527A17-2D6F-3BDF-9A74-F90FA6E26BB3> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff2a29d000 - 0x7fff2a2acfff com.apple.AppleFSCompression (125 - 1.0) <D1E7DC71-1929-30A8-B73E-268387110608> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff2a2ad000 - 0x7fff2a2bafff libbz2.1.0.dylib (44) <0575C0D0-B107-3E53-857F-DEC55998197B> /usr/lib/libbz2.1.0.dylib
0x7fff2a2bb000 - 0x7fff2a2bffff libsystem_coreservices.dylib (127) <A2D875B9-8BA8-33AD-BE92-ADAB915A8D5B> /usr/lib/system/libsystem_coreservices.dylib
0x7fff2a2c0000 - 0x7fff2a2edfff com.apple.CoreServices.OSServices (1122.11 - 1122.11) <870F34BE-C0ED-318B-858D-5F1E4757D552> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff2a2ee000 - 0x7fff2a41ffff com.apple.AuthKit (1.0 - 1) <8239C235-54DE-39F3-98DC-920AF2BE6187> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff2a4c3000 - 0x7fff2a4d5fff libz.1.dylib (76) <9F89FD60-03F7-3175-AB34-5112B99E2B8A> /usr/lib/libz.1.dylib
0x7fff2a4d6000 - 0x7fff2a51dfff libsystem_m.dylib (3186.40.2) <79820D9E-0FF1-3F20-AF4F-F87EE20CE8C9> /usr/lib/system/libsystem_m.dylib
0x7fff2a51e000 - 0x7fff2a51efff libcharset.1.dylib (59) <414F6A1C-1EBC-3956-AC2D-CCB0458F31AF> /usr/lib/libcharset.1.dylib
0x7fff2a51f000 - 0x7fff2a524fff libmacho.dylib (973.4) <28AE1649-22ED-3C4D-A232-29D37F821C39> /usr/lib/system/libmacho.dylib
0x7fff2a525000 - 0x7fff2a540fff libkxld.dylib (7195.60.75) <3600A314-332A-343D-B45D-D9D8B302545D> /usr/lib/system/libkxld.dylib
0x7fff2a541000 - 0x7fff2a54cfff libcommonCrypto.dylib (60178.40.2) <1D0A75A5-DEC5-39C6-AB3D-E789B8866712> /usr/lib/system/libcommonCrypto.dylib
0x7fff2a54d000 - 0x7fff2a557fff libunwind.dylib (200.10) <C5792A9C-DF0F-3821-BC14-238A78462E8A> /usr/lib/system/libunwind.dylib
0x7fff2a558000 - 0x7fff2a55ffff liboah.dylib (203.13.2) <FF72E19B-3B02-34D4-A821-3397BB28AC02> /usr/lib/liboah.dylib
0x7fff2a560000 - 0x7fff2a56afff libcopyfile.dylib (173.40.2) <89483CD4-DA46-3AF2-AE78-FC37CED05ACC> /usr/lib/system/libcopyfile.dylib
0x7fff2a56b000 - 0x7fff2a572fff libcompiler_rt.dylib (102.2) <0DB26EC8-B4CD-3268-B865-C2FC07E4D2AA> /usr/lib/system/libcompiler_rt.dylib
0x7fff2a573000 - 0x7fff2a575fff libsystem_collections.dylib (1439.40.11) <D40D8097-0ABF-3645-B065-168F43ACFF4C> /usr/lib/system/libsystem_collections.dylib
0x7fff2a576000 - 0x7fff2a578fff libsystem_secinit.dylib (87.60.1) <99B5FD99-1A8B-37C1-BD70-04990FA33B1C> /usr/lib/system/libsystem_secinit.dylib
0x7fff2a579000 - 0x7fff2a57bfff libremovefile.dylib (49.40.3) <750012C2-7097-33C3-B796-2766E6CDE8C1> /usr/lib/system/libremovefile.dylib
0x7fff2a57c000 - 0x7fff2a57cfff libkeymgr.dylib (31) <2C7B58B0-BE54-3A50-B399-AA49C19083A9> /usr/lib/system/libkeymgr.dylib
0x7fff2a57d000 - 0x7fff2a584fff libsystem_dnssd.dylib (1310.60.4) <81EFC44D-450E-3AA3-AC8F-D7EF68F464B4> /usr/lib/system/libsystem_dnssd.dylib
0x7fff2a585000 - 0x7fff2a58afff libcache.dylib (83) <2F7F7303-DB23-359E-85CD-8B2F93223E2A> /usr/lib/system/libcache.dylib
0x7fff2a58b000 - 0x7fff2a58cfff libSystem.B.dylib (1292.60.1) <A7FB4899-9E04-37ED-9DD8-8FFF0400879C> /usr/lib/libSystem.B.dylib
0x7fff2a58d000 - 0x7fff2a590fff libfakelink.dylib (3) <34B6DC95-E19A-37C0-B9D0-558F692D85F5> /usr/lib/libfakelink.dylib
0x7fff2a591000 - 0x7fff2a591fff com.apple.SoftLinking (1.0 - 1) <90D679B3-DFFD-3604-B89F-1BCF70B3EBA4> /System/Library/PrivateFrameworks/SoftLinking.framework/Versions/A/SoftLinking
0x7fff2a592000 - 0x7fff2a5c9fff libpcap.A.dylib (98.40.1) <E1995A1C-7EEB-3340-B1E1-DD45FA625C12> /usr/lib/libpcap.A.dylib
0x7fff2a5ca000 - 0x7fff2a6bafff libiconv.2.dylib (59) <3E53F735-1D7E-3ABB-BC45-AAA37F535830> /usr/lib/libiconv.2.dylib
0x7fff2a6bb000 - 0x7fff2a6ccfff libcmph.dylib (8) <865FA425-831D-3E49-BD1B-14188D2A98AA> /usr/lib/libcmph.dylib
0x7fff2a6cd000 - 0x7fff2a73efff libarchive.2.dylib (83.40.4) <76B2F421-5335-37FB-9CD5-1018878B9E74> /usr/lib/libarchive.2.dylib
0x7fff2a73f000 - 0x7fff2a7a6fff com.apple.SearchKit (1.4.1 - 1.4.1) <7BDD2800-BDDC-3DE0-A4A8-B1E855130E3B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff2a7a7000 - 0x7fff2a7a8fff libThaiTokenizer.dylib (3) <513547CD-5C7F-37BE-A2AD-55A22F279588> /usr/lib/libThaiTokenizer.dylib
0x7fff2a7a9000 - 0x7fff2a7d0fff com.apple.applesauce (1.0 - 16.26) <AE525243-2CE7-373E-994E-C2457611EB3C> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff2a7d1000 - 0x7fff2a7e8fff libapple_nghttp2.dylib (1.41) <CC004768-6E3B-3D80-9431-61149EBE2E10> /usr/lib/libapple_nghttp2.dylib
0x7fff2a7e9000 - 0x7fff2a7fbfff libSparseBLAS.dylib (1336.40.1) <CEBD7B0F-A54D-3A43-BD7E-E8BC2C7B7F0C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff2a7fc000 - 0x7fff2a7fdfff com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <1BFEB124-CF05-342F-BC65-B233EAB661D9> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff2a7fe000 - 0x7fff2a802fff libpam.2.dylib (28.40.1) <AE84F5FA-DDB0-3028-AF25-D6B6A12DBA6A> /usr/lib/libpam.2.dylib
0x7fff2a803000 - 0x7fff2a81bfff libcompression.dylib (96.40.6) <45B8B821-8EB6-34FE-92E9-5CBA474499E2> /usr/lib/libcompression.dylib
0x7fff2a81c000 - 0x7fff2a821fff libQuadrature.dylib (7) <FB21F53D-4A40-327F-BD3B-C7C8D08C6A86> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff2a822000 - 0x7fff2abbefff libLAPACK.dylib (1336.40.1) <509FBCC6-4ECB-3192-98A6-D0C030E4E9D8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff2abbf000 - 0x7fff2ac0dfff com.apple.DictionaryServices (1.2 - 341) <83CDCE83-6B48-35F1-BACF-83240D940777> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff2ac0e000 - 0x7fff2ac26fff liblzma.5.dylib (16) <A45348BC-AA9C-39D6-A7C3-2246A3EFA34C> /usr/lib/liblzma.5.dylib
0x7fff2ac27000 - 0x7fff2ac28fff libcoretls_cfhelpers.dylib (169) <C0F19E92-DACB-3100-8610-62DEC5E5FB81> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff2ac29000 - 0x7fff2ad22fff com.apple.APFS (1677.60.23 - 1677.60.23) <8271EE40-CDF5-3E0B-9F42-B49DC7C46C98> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff2ad23000 - 0x7fff2ad30fff libxar.1.dylib (452) <3F3DA942-DC7B-31EF-BCF1-38F99F59A660> /usr/lib/libxar.1.dylib
0x7fff2ad31000 - 0x7fff2ad34fff libutil.dylib (58.40.2) <85CF2B3B-6BEB-381D-8683-1DE2B0167ECC> /usr/lib/libutil.dylib
0x7fff2ad35000 - 0x7fff2ad5dfff libxslt.1.dylib (17.2) <2C881E82-6E2C-3E92-8DC5-3C2D05FE7C95> /usr/lib/libxslt.1.dylib
0x7fff2ad5e000 - 0x7fff2ad68fff libChineseTokenizer.dylib (37) <36891BB5-4A83-33A3-9995-CC5DB2AB53CE> /usr/lib/libChineseTokenizer.dylib
0x7fff2ad69000 - 0x7fff2ae27fff libvMisc.dylib (760.40.6) <219319E1-BDBD-34D1-97B7-E46256785D3C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff2ae28000 - 0x7fff2aec0fff libate.dylib (3.0.4) <51D50D08-F614-3929-AFB1-BF4ED9BE4751> /usr/lib/libate.dylib
0x7fff2aec1000 - 0x7fff2aec8fff libIOReport.dylib (64) <3C26FBDC-931E-3318-8225-C10849CF1D60> /usr/lib/libIOReport.dylib
0x7fff2aec9000 - 0x7fff2aef7fff com.apple.CrashReporterSupport (10.13 - 15047) <5377E0C9-5D89-38C0-B129-1A086716F3E9> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff2afe4000 - 0x7fff2afebfff libMatch.1.dylib (38) <DC1E67E0-2690-3EE0-840D-461DA2980D9D> /usr/lib/libMatch.1.dylib
0x7fff2afec000 - 0x7fff2b077fff libCoreStorage.dylib (554) <8EEB1047-EFC1-3C1B-8E33-A446EB043AD5> /usr/lib/libCoreStorage.dylib
0x7fff2b078000 - 0x7fff2b0cbfff com.apple.AppleVAFramework (6.1.3 - 6.1.3) <8A5B1C42-DD83-303B-85DE-754FB6C10E1A> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff2b0cc000 - 0x7fff2b0e5fff libexpat.1.dylib (26) <4408FC72-BDAA-33AE-BE14-4008642794ED> /usr/lib/libexpat.1.dylib
0x7fff2b0e6000 - 0x7fff2b0effff libheimdal-asn1.dylib (597.40.10) <032931C8-B042-3B3D-93D3-5B3E27431FEA> /usr/lib/libheimdal-asn1.dylib
0x7fff2b0f0000 - 0x7fff2b104fff com.apple.IconFoundation (479.3 - 479.3) <650C91C9-D6A1-3FF7-964B-DE1065F2243C> /System/Library/PrivateFrameworks/IconFoundation.framework/Versions/A/IconFoundation
0x7fff2b105000 - 0x7fff2b172fff com.apple.IconServices (479.3 - 479.3) <63CAB1AB-C485-382A-9088-F6E3937BB8E9> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff2b173000 - 0x7fff2b210fff com.apple.MediaExperience (1.0 - 1) <A7A754CE-61AB-39B8-AA31-3AEB14695F55> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
0x7fff2b211000 - 0x7fff2b23afff com.apple.persistentconnection (1.0 - 1.0) <C3F975D3-A87C-353C-BA1F-072825E60E8C> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
0x7fff2b23b000 - 0x7fff2b249fff com.apple.GraphVisualizer (1.0 - 100.1) <7035CCDF-5B9D-365C-A1FA-1D961EBEE44D> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff2b24a000 - 0x7fff2b665fff com.apple.vision.FaceCore (4.3.2 - 4.3.2) <E0518821-B65D-31A4-8C37-DF3569CF8867> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff2b666000 - 0x7fff2b6b0fff com.apple.OTSVG (1.0 - 677.2.0.5) <D2722431-6C71-3144-A024-6ED06334AEE0> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
0x7fff2b6b1000 - 0x7fff2b6b7fff com.apple.xpc.AppServerSupport (1.0 - 2038.40.38) <27B96AA0-421E-3E5A-B9D8-9BA3F0D133E9> /System/Library/PrivateFrameworks/AppServerSupport.framework/Versions/A/AppServerSupport
0x7fff2b6b8000 - 0x7fff2b6c9fff libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <CAD78803-0F56-316E-A7F1-D2BF26CA2DD6> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
0x7fff2b6ca000 - 0x7fff2b6ccfff libspindump.dylib (295) <C6F804A3-5682-3766-A324-76667364873D> /usr/lib/libspindump.dylib
0x7fff2b6cd000 - 0x7fff2b78dfff com.apple.Heimdal (4.0 - 2.0) <8BB18335-5DD3-3154-85C8-0145C64556A2> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff2b78e000 - 0x7fff2b7a8fff com.apple.login (3.0 - 3.0) <343A182A-F6C9-366E-BF0C-2124E5367F19> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
0x7fff2b928000 - 0x7fff2b92bfff libodfde.dylib (26) <E653BDF5-2C86-3FFB-928A-2D86B3D661E5> /usr/lib/libodfde.dylib
0x7fff2b92c000 - 0x7fff2b996fff com.apple.bom (14.0 - 233) <A62EEEE5-3027-3F25-BCD9-32D36922106E> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff2b997000 - 0x7fff2b9e1fff com.apple.AppleJPEG (1.0 - 1) <A2E9E2A4-AEDC-3481-BDC9-05D9AD84FC25> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff2b9e2000 - 0x7fff2bac0fff libJP2.dylib (2130.2.7) <9D837C01-3D6C-3D71-8E92-3673CE06A21F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff2bac1000 - 0x7fff2bac4fff com.apple.WatchdogClient.framework (1.0 - 98.60.1) <8374BBBB-65CB-3D46-9AD6-0DD1FB99AD88> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
0x7fff2bac5000 - 0x7fff2baf8fff com.apple.MultitouchSupport.framework (4400.28 - 4400.28) <E9A95272-5E84-3B64-8263-8C7F84456269> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff2baf9000 - 0x7fff2bc4bfff com.apple.VideoToolbox (1.0 - 2760.6.4.6) <35098775-A188-3BE0-B0B1-7CE0027BA295> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff2bc4c000 - 0x7fff2bc7efff libAudioToolboxUtility.dylib (1180.23) <58B4505B-F0EA-37FC-9F5A-6F9F05B0F2A5> /usr/lib/libAudioToolboxUtility.dylib
0x7fff2bc7f000 - 0x7fff2bca5fff libPng.dylib (2130.2.7) <1F3FED3B-FB07-3F43-8EAD-6100017FBAB5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff2bca6000 - 0x7fff2bd03fff libTIFF.dylib (2130.2.7) <27E9A2D3-003D-3D97-AD85-BE595EA0516F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff2bd04000 - 0x7fff2bd1efff com.apple.IOPresentment (53 - 37) <070919DC-978E-3DB3-80FD-FB0C1BAAE80A> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff2bd1f000 - 0x7fff2bd25fff com.apple.GPUWrangler (6.2.2 - 6.2.2) <F4B3905F-C024-33C1-82C8-F1744AF8516E> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff2bd26000 - 0x7fff2bd29fff libRadiance.dylib (2130.2.7) <7ABF94D2-5281-363F-A613-9C945D77AAE8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff2bd2a000 - 0x7fff2bd2ffff com.apple.DSExternalDisplay (3.1 - 380) <BA802582-F1EB-35B8-902F-3D0F426124E0> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff2bd30000 - 0x7fff2bd54fff libJPEG.dylib (2130.2.7) <FDD55379-6673-31E4-B916-7949459B60AE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff2bd55000 - 0x7fff2bd84fff com.apple.ATSUI (1.0 - 1) <B82D099B-4F53-3B60-8BAA-975C41EFD356> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
0x7fff2bd85000 - 0x7fff2bd89fff libGIF.dylib (2130.2.7) <C51FB0BA-E5C0-335B-9C64-185B1DDC9166> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff2bd8a000 - 0x7fff2bd93fff com.apple.CMCaptureCore (1.0 - 80.17.1.1) <A0D43E58-B960-3A80-8807-4115F0E1EF74> /System/Library/PrivateFrameworks/CMCaptureCore.framework/Versions/A/CMCaptureCore
0x7fff2bd94000 - 0x7fff2bddbfff com.apple.print.framework.PrintCore (16 - 531) <FC56A643-F502-3578-9EFF-375BE6B87691> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff2bddc000 - 0x7fff2bea8fff com.apple.TextureIO (3.10.9 - 3.10.9) <0AC15003-4B6A-3FB3-9B41-3EF61A2BD430> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff2bea9000 - 0x7fff2beb1fff com.apple.InternationalSupport (1.0 - 60) <5485FFDC-CE44-37F4-865F-91B2EFBC6CAF> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff2beb2000 - 0x7fff2bf2dfff com.apple.datadetectorscore (8.0 - 674) <A2DEEF63-7643-37AA-9420-ED875629D1B2> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff2bf2e000 - 0x7fff2bf8cfff com.apple.UserActivity (435 - 435) <075FD354-28FD-3A13-881C-955FA9106D5C> /System/Library/PrivateFrameworks/UserActivity.framework/Versions/A/UserActivity
0x7fff2bf8d000 - 0x7fff2c6f7fff com.apple.MediaToolbox (1.0 - 2760.6.4.6) <8F9D0503-298B-3FCA-8135-3B3722EF287C> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff2cbb1000 - 0x7fff2cbd9fff com.apple.locationsupport (2420.12.12 - 2420.12.12) <F02D6025-16B4-3C77-ACEA-89B4808214D3> /System/Library/PrivateFrameworks/LocationSupport.framework/Versions/A/LocationSupport
0x7fff2cbda000 - 0x7fff2cc0bfff libSessionUtility.dylib (76.7) <95615EDE-46B9-32AE-96EC-7F6E5EB6A932> /System/Library/PrivateFrameworks/AudioSession.framework/libSessionUtility.dylib
0x7fff2cc0c000 - 0x7fff2cd3cfff com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <D0F9F628-F241-3FA2-A785-7B9DCBB2FEC4> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff2cd3d000 - 0x7fff2cda4fff com.apple.audio.AudioSession (1.0 - 76.7) <C0B1C9EB-A594-31E3-ADDF-118583840E6F> /System/Library/PrivateFrameworks/AudioSession.framework/Versions/A/AudioSession
0x7fff2cda5000 - 0x7fff2cdb7fff libAudioStatistics.dylib (25.1) <1D07EA54-BE7C-37C4-AA73-5224D402F0C3> /usr/lib/libAudioStatistics.dylib
0x7fff2cdb8000 - 0x7fff2cdc7fff com.apple.speech.synthesis.framework (9.0.51 - 9.0.51) <B86A2136-8DD7-395D-BB9F-9416C56DD2D6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff2cdc8000 - 0x7fff2ce33fff com.apple.ApplicationServices.ATS (377 - 516) <3A435648-CC5F-387E-AB37-391AAEABE314> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff2ce34000 - 0x7fff2ce4cfff libresolv.9.dylib (68) <9957A6F4-8B66-3429-86CD-6DF4993EB6F5> /usr/lib/libresolv.9.dylib
0x7fff2ce4d000 - 0x7fff2ce60fff libsasl2.2.dylib (214) <F20902AE-3733-3F37-801D-6C3B78C0008A> /usr/lib/libsasl2.2.dylib
0x7fff2cf7f000 - 0x7fff2d05efff libSMC.dylib (20) <CE5162B7-379E-3DF0-9D1E-44BC98BD2422> /usr/lib/libSMC.dylib
0x7fff2d05f000 - 0x7fff2d0befff libcups.2.dylib (494.1) <04A4801E-E1B5-3919-9F14-100F0C2D049B> /usr/lib/libcups.2.dylib
0x7fff2d0bf000 - 0x7fff2d0cefff com.apple.LangAnalysis (1.7.0 - 254) <120945D9-B74D-3A6F-B160-2678E6B6481D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff2d0cf000 - 0x7fff2d0d9fff com.apple.NetAuth (6.2 - 6.2) <C65B2F54-67EA-3E4D-B84A-BBA94998BD6B> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff2d0da000 - 0x7fff2d0e1fff com.apple.ColorSyncLegacy (4.13.0 - 1) <33DA9348-EADF-36D2-B999-56854481D272> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff2d0e2000 - 0x7fff2d0edfff com.apple.QD (4.0 - 416) <7FFC9049-7E42-372B-9105-1C4C94DE0110> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff2d0ee000 - 0x7fff2d75cfff com.apple.audio.AudioResourceArbitration (1.0 - 1) <098FD431-D302-3DD5-9AD1-453615A73E68> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
0x7fff2d75d000 - 0x7fff2d769fff com.apple.perfdata (1.0 - 67.40.1) <85A57A67-8721-3035-BCEE-D4AC98332D2C> /System/Library/PrivateFrameworks/perfdata.framework/Versions/A/perfdata
0x7fff2d76a000 - 0x7fff2d778fff libperfcheck.dylib (41) <67113817-A463-360A-B321-9286DC50FEDA> /usr/lib/libperfcheck.dylib
0x7fff2d779000 - 0x7fff2d788fff com.apple.Kerberos (3.0 - 1) <2E872705-0841-3695-AF79-4160D2A436AB> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff2d789000 - 0x7fff2d7d8fff com.apple.GSS (4.0 - 2.0) <2A38D59F-5F3A-3779-A421-2F8128F22B95> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff2d7d9000 - 0x7fff2d7e9fff com.apple.CommonAuth (4.0 - 2.0) <D9431F22-A16B-3237-9676-B6159B36F5EA> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff2d7ea000 - 0x7fff2d810fff com.apple.MobileAssets (1.0 - 659.60.1) <D8986A88-2061-3157-A1BE-452E20ED34F6> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
0x7fff2d83e000 - 0x7fff2d860fff com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <3554A1B0-A9AD-3D89-A755-1C9CC7CEA239> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff2d861000 - 0x7fff2d869fff com.apple.CorePhoneNumbers (1.0 - 1) <0DF4C527-E7D3-30E0-9402-4C43B29729CB> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff2d9be000 - 0x7fff2d9befff liblaunch.dylib (2038.40.38) <05A7EFDD-4111-3E4D-B668-239B69DE3D0F> /usr/lib/system/liblaunch.dylib
0x7fff2e1b9000 - 0x7fff2e300fff com.apple.Sharing (1575 - 1575) <4E590A26-5934-33EE-BFD9-391A64686FDE> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff2e301000 - 0x7fff2e421fff com.apple.Bluetooth (8.0.2 - 8.0.2f9) <E3CF73C4-B439-3E30-B74D-3344C2EA2FC9> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff2e422000 - 0x7fff2e436fff com.apple.AppContainer (4.0 - 509.60.2) <A9D28E73-B08F-34E3-AE7B-0855DBA96C3C> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff2e437000 - 0x7fff2e43afff com.apple.SecCodeWrapper (4.0 - 509.60.2) <55B0C208-B176-3FE4-8CA2-9F28CA59F8F1> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff2e43b000 - 0x7fff2e494fff com.apple.ProtectedCloudStorage (1.0 - 1) <C84C9C98-5382-3E27-8275-AC9816AA28E8> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff2e6e8000 - 0x7fff2fbd7fff com.apple.GeoServices (1.0 - 1757.22.10.6.12) <4D6F8EF4-47D4-3F93-90AC-3F4A5772CBCB> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff2fbd8000 - 0x7fff2fbe3fff com.apple.DirectoryService.Framework (11.1 - 230.40.1) <FC96A8F6-8E19-3CB4-A3ED-4E30B1491746> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff2fbe4000 - 0x7fff2fc0ffff com.apple.RemoteViewServices (2.0 - 163) <AC6E2D2F-8131-3A40-97D7-E24E2A45CD66> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff2fc10000 - 0x7fff2fc1ffff com.apple.SpeechRecognitionCore (6.1.12 - 6.1.12) <F2A0E41A-7976-3175-959A-98DC24AAFFCC> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff2fc20000 - 0x7fff2fc27fff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <9C14FA0A-D905-375B-8C32-E311ED59B6AD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff2fe6b000 - 0x7fff2fe6bfff libsystem_product_info_filter.dylib (8.40.1) <7CCAF1A8-F570-341E-B275-0C80B092F8E0> /usr/lib/system/libsystem_product_info_filter.dylib
0x7fff2ff46000 - 0x7fff2ff46fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <510A463F-5CA5-3585-969F-2D44583B71C8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff2ff6d000 - 0x7fff2ff6dfff com.apple.CoreServices (1122.11 - 1122.11) <5DDB040C-6E92-3DBE-9049-873F510F26E2> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff3023b000 - 0x7fff3023bfff com.apple.Accelerate (1.11 - Accelerate 1.11) <F2FFCC7B-EE3D-3768-A73B-342851B53741> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff3027c000 - 0x7fff30287fff com.apple.MediaAccessibility (1.0 - 130) <9B4710C9-6238-3507-9918-FDA38CDC0B00> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff30288000 - 0x7fff302a7fff com.apple.networking.AlgosScoreFramework (1.0 - 1) <DAB40772-57A1-3545-94FD-4C823D13135C> /System/Library/PrivateFrameworks/AlgosScoreFramework.framework/Versions/A/AlgosScoreFramework
0x7fff302a8000 - 0x7fff302acfff com.apple.AppleSRP (5.0 - 1) <882084C9-F925-308F-B778-398FE6741654> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff302ad000 - 0x7fff302b8fff com.apple.frameworks.CoreDaemon (1.3 - 1.3) <96849317-5346-3D5D-95B7-6C48C3015427> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff302b9000 - 0x7fff302f0fff com.apple.framework.SystemAdministration (1.0 - 1.0) <E28F11F0-2155-331E-9CFE-BF858E06ACED> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x7fff30ab2000 - 0x7fff30b14fff com.apple.CoreBluetooth (1.0 - 1) <0FF4CFB1-B8DD-31C3-A000-5016CFE45EB9> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff30b15000 - 0x7fff30b1efff com.apple.SymptomDiagnosticReporter (1.0 - 79.40.12) <4536FFDF-598E-3085-8DDD-26798E1EEBD6> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
0x7fff30b1f000 - 0x7fff30b32fff com.apple.PowerLog (1.0 - 1) <7EA1C552-E90E-3DF6-A5B6-915D26694670> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
0x7fff30b33000 - 0x7fff30b3ffff com.apple.AppleIDAuthSupport (1.0 - 1) <1EE88692-4059-3A33-B492-E7D7112EFB0C> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff30b40000 - 0x7fff30be8fff com.apple.DiscRecording (9.0.3 - 9030.4.5) <8676CDCB-15CC-3723-9411-8B8AFA3B370A> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff30be9000 - 0x7fff30c1cfff com.apple.MediaKit (16 - 927.40.2) <C7FB3929-E0E1-3A6C-B138-EE504CCE9EF0> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff30c1d000 - 0x7fff30d08fff com.apple.DiskManagement (14.0 - 1733.60.1) <328DB6AD-221B-35FA-8E31-2E5CD860A0F3> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
0x7fff30d09000 - 0x7fff310c3fff com.apple.CoreAUC (322.2.0 - 322.2.0) <5E5A1D7F-5D43-3975-AA23-AA0815DCE998> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff310c4000 - 0x7fff310c7fff com.apple.Mangrove (1.0 - 25) <81A9BA84-C61F-3CBF-A127-406E3FD2459E> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff310c8000 - 0x7fff310f5fff com.apple.CoreAVCHD (6.1.0 - 6100.4.1) <10CA0E34-19B1-365C-888C-94543A25F10F> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff310f6000 - 0x7fff31216fff com.apple.FileProvider (326 - 326) <B2A33B9E-66D9-30B5-A18C-AD0D7F3592C5> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
0x7fff31217000 - 0x7fff3123afff com.apple.GenerationalStorage (2.0 - 322) <F2740CA7-334B-3F24-AFE8-2451D1A041C2> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff31a89000 - 0x7fff31ac8fff com.apple.AppleVPAFramework (3.20.4 - 3.20.4) <DF632ED6-E230-3208-8741-446E8E35A515> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
0x7fff31b99000 - 0x7fff31bd5fff com.apple.DebugSymbols (195.1 - 195.1) <6AA76BBC-B0F2-3F37-A6EE-19014DCD06D9> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff31bd6000 - 0x7fff31c93fff com.apple.CoreSymbolication (12.2 - 64541.4) <A100000D-F881-3C3C-ABC5-3EAC7A272579> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff31c94000 - 0x7fff31c9dfff com.apple.CoreTime (284) <1BE28F6E-940C-31C8-B460-2761FC6B4A3F> /System/Library/PrivateFrameworks/CoreTime.framework/Versions/A/CoreTime
0x7fff32b29000 - 0x7fff32b8cfff com.apple.framework.Apple80211 (17.0 - 1728) <2DBC65AC-A7DF-38F9-9174-3382667FBF0F> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff32b8d000 - 0x7fff32cdffff com.apple.CoreWiFi (3.0 - 341) <C18D2E57-A964-380F-A74B-AEFDB3B3ADEC> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff32cf9000 - 0x7fff32d30fff com.apple.LDAPFramework (2.4.28 - 194.5) <C3E9E36B-B981-3FAD-A8EA-9BADE5F2B30D> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff32d31000 - 0x7fff32d32fff com.apple.TrustEvaluationAgent (2.0 - 35) <D0B7904B-37ED-32B1-8FD3-462383F2BDCB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff32d33000 - 0x7fff32e36fff libcrypto.44.dylib (56.60.2) <7464291F-2D5C-3AE3-9197-54C8676C23F1> /usr/lib/libcrypto.44.dylib
0x7fff32e37000 - 0x7fff32e64fff libssl.46.dylib (56.60.2) <0692D04B-A0C4-3632-BB08-2C0C2AC68479> /usr/lib/libssl.46.dylib
0x7fff32e65000 - 0x7fff32f14fff com.apple.DiskImagesFramework (595.40.1 - 595.40.1) <B0A2C1DD-79A0-3C26-A1A8-22F1989E5415> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff32f4c000 - 0x7fff32f5bfff com.apple.xpc.RemoteServiceDiscovery (1.0 - 2038.40.38) <EFEFC279-E73A-3557-A4AE-BF67E7C96962> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
0x7fff32f5c000 - 0x7fff32f73fff com.apple.xpc.RemoteXPC (1.0 - 2038.40.38) <DC43AED2-6DD7-31AB-8186-EF69ED7027C4> /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC
0x7fff32fbb000 - 0x7fff32fbefff com.apple.help (1.3.8 - 71) <599F7E42-DEF1-3B70-83AB-C3BDF727CF93> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff32fbf000 - 0x7fff32fc6fff com.apple.EFILogin (2.0 - 2) <B94BFCCA-45B6-3E80-84E7-758350D7CAFD> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff32fc7000 - 0x7fff32fd2fff libcsfde.dylib (554) <1F4DFF13-17EC-3672-8A41-056F4E44A377> /usr/lib/libcsfde.dylib
0x7fff32fd3000 - 0x7fff33038fff libcurl.4.dylib (121.40.2) <C9541242-9ED5-3F9B-A2B2-415503447A1F> /usr/lib/libcurl.4.dylib
0x7fff33039000 - 0x7fff33040fff com.apple.LoginUICore (4.0 - 4.0) <8AE86484-F756-3BDE-973A-A70C0345697B> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x7fff33200000 - 0x7fff33200fff com.apple.ApplicationServices (48 - 50) <7B536871-3F10-3138-B06B-9C2A3C07EC1E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff33500000 - 0x7fff33500fff libHeimdalProxy.dylib (79) <1BD94BF6-8E63-3B21-95DC-E5EEEBFB8AE8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
0x7fff335b3000 - 0x7fff335b3fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <F5EC07DD-8937-37CB-84DF-C7475FFA573E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff335d8000 - 0x7fff3361afff com.apple.StreamingZip (1.0 - 1) <FEA8C519-ACB4-381C-9F9D-CB92AE094B23> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
0x7fff3365d000 - 0x7fff33662fff com.apple.PushKit (1.0 - 1) <309B12FF-9B68-3120-ABC6-8B52A0E26127> /System/Library/Frameworks/PushKit.framework/Versions/A/PushKit
0x7fff33663000 - 0x7fff33699fff com.apple.C2 (1.3 - 569) <5370F4A2-1C27-395C-80E4-A36E5BF414E9> /System/Library/PrivateFrameworks/C2.framework/Versions/A/C2
0x7fff336cc000 - 0x7fff33ed9fff com.apple.vision.EspressoFramework (1.0 - 256.2.2) <C2903F04-5EE0-3FCA-A7D8-6ABFDD38A27B> /System/Library/PrivateFrameworks/Espresso.framework/Versions/A/Espresso
0x7fff33eda000 - 0x7fff33ef1fff com.apple.ANEServices (4.51 - 4.51) <F86B479B-3FA0-366C-84A6-D35253ABBF5E> /System/Library/PrivateFrameworks/ANEServices.framework/Versions/A/ANEServices
0x7fff3428d000 - 0x7fff34550fff com.apple.spotlight.index (10.7.0 - 2150.7.2) <D7C1EBB8-2025-3D21-81AE-B43E6005051F> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
0x7fff34569000 - 0x7fff345b9fff com.apple.ChunkingLibrary (334 - 334) <E392AB7F-6EAC-3E2E-93F8-01BA240FEACD> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff34e85000 - 0x7fff34e9bfff com.apple.CoreML.AppleNeuralEngine (1.0 - 1) <BB0C2E05-9F10-3990-9A4B-0A3796F912AB> /System/Library/PrivateFrameworks/AppleNeuralEngine.framework/Versions/A/AppleNeuralEngine
0x7fff35001000 - 0x7fff35004fff com.apple.Cocoa (6.11 - 23) <E44AC98B-5BEA-3087-AB41-C73CEB8A98C8> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff36444000 - 0x7fff3645ffff com.apple.openscripting (1.7 - 190) <D0B98DF9-7A61-3810-AE81-2F870DCC2AC0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff36460000 - 0x7fff36463fff com.apple.securityhi (9.0 - 55008) <DD7770F7-661C-363B-A1F4-8B69EB0FFB6A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff36464000 - 0x7fff36467fff com.apple.ink.framework (10.15 - 227) <E10C40B6-2656-36D1-882C-2091CE02883A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff36468000 - 0x7fff3646bfff com.apple.CommonPanels (1.2.6 - 101) <101582BA-E64F-391A-BD23-50DCC3CF8939> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff3646c000 - 0x7fff36473fff com.apple.ImageCapture (1708 - 1708) <FE9D13DD-D733-3B2A-B4A6-D3C8313005F5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff39459000 - 0x7fff3945cfff com.apple.OSAServicesClient (1.0 - 1) <44E39868-F624-3644-B453-962D34737998> /System/Library/PrivateFrameworks/OSAServicesClient.framework/Versions/A/OSAServicesClient
0x7fff3d15e000 - 0x7fff3d161fff com.apple.print.framework.Print (15 - 271) <8411879F-7E3E-3882-BD06-68E797A3B9D6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff3d162000 - 0x7fff3d165fff com.apple.Carbon (160 - 164) <5683716A-5610-3B97-B473-B4652067E7A6> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff3d3ea000 - 0x7fff3d409fff com.apple.private.SystemPolicy (1.0 - 1) <CFE0B0C6-DF5B-31EB-9D79-B23E00A80B05> /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy
0x7fff3dd33000 - 0x7fff3dd3efff com.apple.MallocStackLogging (1.0 - 1) <C1A21524-381D-39CA-AD63-A3B9F67FC6CA> /System/Library/PrivateFrameworks/MallocStackLogging.framework/Versions/A/MallocStackLogging
0x7fff3dd54000 - 0x7fff3dd66fff libmis.dylib (274.60.2) <54387457-A60B-3390-AD6D-3B380792CD79> /usr/lib/libmis.dylib
0x7fff3dd67000 - 0x7fff3dd6afff com.apple.gpusw.GPURawCounter (12.25 - 12.0) <17751B3E-2CF3-3944-BA02-124E56A10426> /System/Library/PrivateFrameworks/GPURawCounter.framework/Versions/A/GPURawCounter
0x7fff4151a000 - 0x7fff41523fff com.apple.IOAccelMemoryInfo (1.0 - 1) <90735179-1E6C-3D1F-8CCF-08AC441B19A2> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
0x7fff4195a000 - 0x7fff41978fff libCGInterfaces.dylib (544) <488D608D-374C-3A2F-B8AC-D78E2F6E6DB7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff43f68000 - 0x7fff441e1fff com.apple.RawCamera.bundle (9.10.0 - 1420.3) <D6521255-C614-3A4C-83E1-42A3C3079CBE> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff46c60000 - 0x7fff46c6bfff libGPUSupportMercury.dylib (18.1.1) <5C061A05-CD21-3442-A80B-1901D64C9B9E> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff482cc000 - 0x7fff4831afff com.apple.osanalytics.OSAnalytics (1.0 - 1) <EF7537E3-982B-3FA2-BFFC-F8071EFF0B31> /System/Library/PrivateFrameworks/OSAnalytics.framework/Versions/A/OSAnalytics
0x7fff4c35f000 - 0x7fff4c362fff com.apple.FinderSyncPriv (1.3 - 1350.2.10) <456C118F-398C-329C-BC89-7B1EAC693835> /System/Library/PrivateFrameworks/FinderSyncPriv.framework/Versions/A/FinderSyncPriv
0x7fff5228a000 - 0x7fff5231cfff com.apple.Symbolication (12.2 - 64541.7.1) <EC806042-5249-35DC-90BA-953A86D1854A> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff56452000 - 0x7fff56455fff com.apple.ForceFeedback (1.0.6 - 1.0.6) <AB29674E-26C2-360C-9117-54AC93E80CB0> /System/Library/Frameworks/ForceFeedback.framework/Versions/A/ForceFeedback
0x7fff5ea3a000 - 0x7fff5eecafff com.apple.driver.AppleIntelKBLGraphicsMTLDriver (16.1.7.1 - 16.0.1) <B3FAA649-5890-3A9C-8111-CE3DC093C5B3> /System/Library/Extensions/AppleIntelKBLGraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsMTLDriver
0x7fff5eecb000 - 0x7fff5f8defff libSC.dylib (4.2.13) <7F3979D1-8399-3098-80F8-88707ED65975> /System/Library/Extensions/AMDShared.bundle/Contents/PlugIns/libSC.dylib
0x7fff5fc27000 - 0x7fff60c0afff com.apple.driver.AppleIntelKBLGraphicsGLDriver (16.1.7.1 - 16.0.1) <413F1002-6C49-39B7-85BE-3151E4104B88> /System/Library/Extensions/AppleIntelKBLGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsGLDriver
0x7fff6a3f0000 - 0x7fff6a3f4fff libmetal_timestamp.dylib (31001.160) <2EC7EA90-5313-3812-8E72-910C643A996C> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/31001/Libraries/libmetal_timestamp.dylib
0x7fff6c85e000 - 0x7fff6c864fff libCoreFSCache.dylib (177.22) <4ECE128D-5E79-3ADF-8FE7-4FE8F565F8AA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff6c865000 - 0x7fff6c869fff libCoreVMClient.dylib (177.22) <E0DBED1D-39B4-3E51-9EA8-D1ECAED93EAB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff6c86a000 - 0x7fff6c879fff com.apple.opengl (18.1.1 - 18.1.1) <D8EE3AD0-C0D0-32F7-9C6D-39341099EB55> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff6c87a000 - 0x7fff6c87cfff libCVMSPluginSupport.dylib (18.1.1) <5F020D32-8663-3CB8-A50C-F939D4D4C31F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff6c87d000 - 0x7fff6c885fff libGFXShared.dylib (18.1.1) <2271532D-E2B3-3D4D-ADF0-0935F8DCE89B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff6c886000 - 0x7fff6c8b9fff libGLImage.dylib (18.1.1) <528E53A3-33E1-34C7-8EE3-C42AE5255553> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff6c8ba000 - 0x7fff6c8f6fff libGLU.dylib (18.1.1) <15CBDF20-8A87-3D84-90F8-D19F4A2B06E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff6c8f7000 - 0x7fff6ca8bfff libGLProgrammability.dylib (18.1.1) <570616B1-98D2-3DF2-844A-EE845A8B8EDE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff6ca8c000 - 0x7fff6ca96fff libGL.dylib (18.1.1) <157B74E1-F30D-3F9D-9AF8-AAA333D2812D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff6ca97000 - 0x7fff6cc12fff GLEngine (18.1.1) <155E1C82-C69A-3E86-8569-3C134C7FEAC6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff6cc13000 - 0x7fff6cc3cfff GLRendererFloat (18.1.1) <49B0A782-AE84-35BC-91F8-880C2B7EE004> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff6decd000 - 0x7fff6df25fff com.apple.opencl (4.5 - 4.5) <8A3D06D5-4E82-355C-AE1B-E2C91DB58233> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff6ee48000 - 0x7fff6ee97fff ATIRadeonX6000SCLib.dylib (4.2.13) <D3702C4F-73AC-3AED-9D42-33299E60E0C3> /System/Library/Extensions/AMDRadeonX6000GLDriver.bundle/Contents/MacOS/ATIRadeonX6000SCLib.dylib
0x7fff6f7af000 - 0x7fff6f7d1fff com.apple.audio.OpenAL (1.8 - 1.8) <8CF29FAE-D1F5-37FA-B529-D999AFE990FD> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
0x7fff7012d000 - 0x7fff70137fff com.apple.AccessibilityBundles (1.0 - 172) <5522C7FE-EAC0-3080-B363-56F19547B00A> /System/Library/PrivateFrameworks/AccessibilityBundles.framework/Versions/A/AccessibilityBundles
0x7fff783e5000 - 0x7fff783ecfff libRosetta.dylib (203.13.2) <FF72E19B-3B02-34D4-A821-3397BB28AC02> /usr/lib/libRosetta.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 3
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 523
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)
Writable regions: Total=7.3G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=7.3G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 512K 4
Activity Tracing 256K 1
CG backing stores 4608K 6
CG image 580K 6
CoreAnimation 76K 7
CoreGraphics 12K 2
CoreUI image data 672K 5
Foundation 16K 1
Kernel Alloc Once 8K 1
MALLOC 5.3G 474
MALLOC guard page 48K 10
MALLOC_MEDIUM (reserved) 960.0M 15 reserved VM address space (unallocated)
MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)
OpenGL GLSL 256K 3
STACK GUARD 156K 39
Stack 72.8M 40
VM_ALLOCATE 663.3M 1326
__CTF 759 1
__DATA 89.4M 382
__DATA_CONST 17.5M 211
__DATA_DIRTY 914K 113
__FONT_DATA 4K 1
__GLSLBUILTINS 5176K 1
__LINKEDIT 545.7M 38
__OBJC_RO 60.5M 1
__OBJC_RW 2452K 3
__TEXT 460.0M 380
__UNICODE 588K 1
mapped file 89.6M 26
shared memory 40K 4
TOTAL 8.6G 3103
TOTAL, minus reserved VM space 7.3G 3103
