Transform node does not rotate/scale instances
The Transform node should rotate and scale instances as well.
The test file is without the Collection Info node.
Jacques Lucke (JacquesLucke) reopened this task as Confirmed.EditedJan 21 2021, 10:45 AM
The fix is not doing what I was thinking. Instances should not rotate/scale on their own axis. Instead everything should be scaled together.
The center of the spheres should still be exactly at the vertex positions after the transform node.
Sorry for not being more explicit before.
Right, I was just testing this out with the collection info node so I didn't notice this issue as the instances were placed at the object origin then.
