The red part turned into shocking pink
Operating system: Darwin-18.7.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 555 OpenGL Engine ATI Technologies Inc. 4.1 ATI-2.11.21
Broken: version: 2.83.0, branch: master, commit date: 2020-06-03 14:38, hash: rB211b6c29f771
Robert Guetzkow (rjg) closed this task as Archived.Jan 20 2021, 10:25 AM
Thank you for your report. Unfortunately, it does not contain the requested information, which are required for us to investigate the issue. Please read this guide, it may help you write a bug report that allows us to fix your problem.
If you need help learning or using Blender, please post a question on one of our community websites, for instance Blender's StackExchange, blenderartists.org or the #support channel on Blender chat. The bug tracker is only for bug reports.
In case you believe that you've found a bug, please create a new bug report through Help > Report a Bug in Blender. We expect all bug reports to follow the submission template. Please provide system information (operating system, GPU, graphics driver version), affected Blender version, previous Blender version that worked properly, a short and precise description of the issue, step by step instructions to reproduce it and, if relevant, a minimal .blend file that showcases the problem.
