Operating system: Windows-10-home-64bit
nvidia geforce 2070super ver.3.2.0.5.70
ryzen 3700x
16(8x2)GB
Broken: version: 2.80, 2.79, 2.92,
Previous fine ver : all version
branch: master
commit date: 2021-01-22 12:00~now
hash: ?
An error occurred while installing'mod3' for import-export of mhw.
"'utf-8' codec can't decode byte 0xb9 in position 22: invalid start byte"
- run blender
- click to "edit" -> "preferences" -> "add-on"
- installing the 'mod3-mhw~()'
(4. If it works normally, there will be'mod3' in import-export.)
Blender's pyton that I downloaded :
If you need more information, I will write it in the comments.
However, I am very new to coding. Please explain the solution in detail.
