"Join Geometry" node causes cycles to only display one of the geometries
Graphics card: GeForce RTX 2080 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.09
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-01-28 22:25, hash: rB92b0803f35a7
Cycles not displaying all geometry when using a "Join Geometry" node, neither in rendered viewport nor in render
eevee is working all right
open the file Bug_ex2.blend, set one of the viewports to rendered in cycles
compare solid viewport to rendered viewport, some geometry is not displayed
now swap the inputs of the Join Geometry node,
i have another issue that might be related.
using the file
one can see that Cycles stops working correctly if two objects use the same geometry nodes tree cycles does not display both objects, instead one of them, and samples the whole time in viewport
explanation
suzanne and plane have a Geometry Nodes modifer called "Geometry Nodes.002"
restricting one of the objects viewport visibility causes cycles to preview viewport correctly again, however when both are visible it behaves weird
it does not work in f12 render either
Hans Goudey (HooglyBoogly) renamed this task from "Join Geometry" node causes cycles to only display one of the geometrys to "Join Geometry" node causes cycles to only display one of the geometries .Jan 31 2021, 4:39 AM
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Feb 1 2021, 4:52 PM
Can confirm the first issue reported here.
i have another issue that might be related...
Please report that separately.
I also get the issue reported in T84899 in this file..
Jacques Lucke (JacquesLucke) claimed this task.
I cannot reproduce this anymore, looks like it is fixed.
