vertex weight proximity BUG?
Graphics card: GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.92
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash: rB0f45cab862b8
can`t animate target object for modifier?
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Feb 4 2021, 1:38 PM
Please always attach an example .blend file (this just speeds up the process).
In your case you are using an empty [that doesnt have geometry -- even though you are using the Geometry Proximity Mode], so scaling wont make a difference here.
Have you tried this with a "real" UVSphere [that has real geometry]?
Philipp Oeser (lichtwerk) closed this task as Archived.Feb 19 2021, 5:05 PM
