Blender crashes when changing scenes
Operating system: Darwin-19.6.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 5500M OpenGL Engine ATI Technologies Inc. 4.1 ATI-3.10.19
Broken: version: 2.91.2, branch: master, commit date: 2021-01-19 16:15, hash: rB5be9ef417703
I have a few scenes in the project. Sometimes after I make changes to a different scene and switch back to a scene that was working before it crashes. From them on it will always crash whenever I go to that scene and there is no way to get back into that scene.
with this bland file just go to scene "wings2"
Here is the crash log
Process: Blender [67283]
Path: /Applications/Blender.app/Contents/MacOS/Blender
Identifier: org.blenderfoundation.blender
Version: 2.91.2 (2.91.2 2021-01-19)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Blender [67283]
User ID: 501
Date/Time: 2021-02-10 13:37:49.681 -0800
OS Version: Mac OS X 10.15.7 (19H114)
Report Version: 12
Bridge OS Version: 5.1 (18P3030)
Anonymous UUID: 813206A7-FEB6-78D2-53A1-D08726C4767A
Sleep/Wake UUID: B2138730-094D-40DA-8AE3-3C44DDB752EB
Time Awake Since Boot: 930000 seconds
Time Since Wake: 68000 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGSEGV)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: Blender [67283]
Application Specific Information:
dyld: in dladdr()
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff72de7f02 swtch_pri + 10
1 libsystem_pthread.dylib 0x00007fff72ea8698 sched_yield + 11
2 org.blenderfoundation.blender 0x000000010d7966b5 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::receive_or_steal_task(long&, long) + 565
3 org.blenderfoundation.blender 0x000000010d796169 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 329
4 org.blenderfoundation.blender 0x000000010f658768 tbb::internal::task_group_base::wait() + 24
5 org.blenderfoundation.blender 0x0000000114f4db34 BLI_task_pool_work_and_wait + 516
6 org.blenderfoundation.blender 0x0000000113859cc1 blender::deg::deg_evaluate_on_refresh(blender::deg::Depsgraph*) + 657
7 org.blenderfoundation.blender 0x000000010d53dc9f BKE_scene_graph_update_for_newframe + 127
8 org.blenderfoundation.blender 0x000000010d7cd6e0 WM_window_set_active_scene + 176
9 org.blenderfoundation.blender 0x000000010dcd30ee rna_Window_scene_update + 62
10 org.blenderfoundation.blender 0x000000010db41925 rna_property_update + 325
11 org.blenderfoundation.blender 0x000000010e082f67 template_ID_set_property_exec_fn + 87
12 org.blenderfoundation.blender 0x000000010e046b56 ui_apply_but_funcs_after + 406
13 org.blenderfoundation.blender 0x000000010e043233 ui_handler_region_menu + 387
14 org.blenderfoundation.blender 0x000000010d7a6724 wm_handlers_do_intern + 1380
15 org.blenderfoundation.blender 0x000000010d7a1f3f wm_handlers_do + 31
16 org.blenderfoundation.blender 0x000000010d7a13b0 wm_event_do_handlers + 1488
17 org.blenderfoundation.blender 0x000000010d79ab50 WM_main + 32
18 org.blenderfoundation.blender 0x000000010d39763a main + 890
19 libdyld.dylib 0x00007fff72ca6cc9 start + 1
Thread 1:
0 libsystem_kernel.dylib 0x00007fff72de7e36 semaphore_wait_trap + 10
1 libdispatch.dylib 0x00007fff72c4daed _dispatch_sema4_wait + 16
2 libdispatch.dylib 0x00007fff72c4dfbf _dispatch_semaphore_wait_slow + 98
3 org.blenderfoundation.blender 0x00000001132f1652 IlmThread_2_4::(anonymous namespace)::DefaultWorkerThread::run() + 50
4 org.blenderfoundation.blender 0x00000001132f01be void* std::1::thread_proxy<std::1::tuple<std::1::unique_ptr<std::1::thread_struct, std::1::default_delete<std::1::__thread_struct> >, void (IlmThread_2_4::Thread::*)(), IlmThread_2_4::Thread*> >(void*) + 62
5 libsystem_pthread.dylib 0x00007fff72eab109 _pthread_start + 148
6 libsystem_pthread.dylib 0x00007fff72ea6b8b thread_start + 15
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:
0 libsystem_pthread.dylib 0x00007fff72ea6b68 start_wqthread + 0
Thread 18:: AMCP Logging Spool
1 com.apple.audio.caulk 0x00007fff6c87cb16 caulk::mach::semaphore::wait() + 16
2 com.apple.audio.caulk 0x00007fff6c87c9b2 caulk::semaphore::timed_wait(double) + 106
3 com.apple.audio.caulk 0x00007fff6c87c7c4 caulk::concurrent::details::worker_thread::run() + 30
4 com.apple.audio.caulk 0x00007fff6c87c1e4 void* caulk::thread_proxy<std::1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 45
Thread 19:
Thread 20:: com.apple.audio.IOThread.client
0 libsystem_kernel.dylib 0x00007fff72de7dfa mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff72de8170 mach_msg + 60
2 com.apple.audio.CoreAudio 0x00007fff382d8bf1 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 111
3 com.apple.audio.CoreAudio 0x00007fff381d4d88 invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int) + 2677
4 com.apple.audio.CoreAudio 0x00007fff38308b9e HALB_IOThread::Entry(void*) + 72
Thread 21:
1 org.blenderfoundation.blender 0x000000010d7916b8 tbb::internal::rml::private_worker::run() + 104
2 org.blenderfoundation.blender 0x000000010d791649 tbb::internal::rml::private_worker::thread_routine(void*) + 9
3 libsystem_pthread.dylib 0x00007fff72eab109 _pthread_start + 148
4 libsystem_pthread.dylib 0x00007fff72ea6b8b thread_start + 15
Thread 22:
Thread 23:
Thread 24:
Thread 25:
Thread 26:
Thread 27:
0 dyld 0x000000012a3862a5 ImageLoaderMachO::findClosestSymbol(mach_header const*, void const*, void const**) + 379
1 dyld 0x000000012a37a162 dladdr + 138
2 libdyld.dylib 0x00007fff72ca4270 dladdr + 174
3 libsystem_c.dylib 0x00007fff72cf8801 backtrace_symbols + 109
4 org.blenderfoundation.blender 0x0000000114f4b224 BLI_system_backtrace + 68
5 org.blenderfoundation.blender 0x000000010d39af48 sig_handle_crash + 392
6 libsystem_platform.dylib 0x00007fff72e9f5fd _sigtramp + 29
7 ??? 000000000000000000 0 + 0
8 org.blenderfoundation.blender 0x0000000114f4ecce tbb::interface7::internal::delegated_function<RangeTask::operator()(tbb::blocked_range<int> const&) const::'lambda'() const, void>::operator()() const + 62
9 org.blenderfoundation.blender 0x000000010d78a3fb tbb::interface7::internal::isolate_within_arena(tbb::interface7::internal::delegate_base&, long) + 75
10 org.blenderfoundation.blender 0x0000000114f4f530 void tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>, tbb::blocked_range<int> >(tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>&, tbb::blocked_range<int>&) + 800
11 org.blenderfoundation.blender 0x0000000114f4f0dd void tbb::interface9::internal::partition_type_base<tbb::interface9::internal::auto_partition_type>::execute<tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>, tbb::blocked_range<int> >(tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>&, tbb::blocked_range<int>&) + 205
12 org.blenderfoundation.blender 0x0000000114f4f009 tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>::execute() + 73
13 org.blenderfoundation.blender 0x000000010d796a39 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
14 org.blenderfoundation.blender 0x000000010d796121 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
15 org.blenderfoundation.blender 0x000000010d787575 tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 533
16 org.blenderfoundation.blender 0x000000010d7908bb tbb::internal::market::process(rml::job&) + 43
17 org.blenderfoundation.blender 0x000000010d791708 tbb::internal::rml::private_worker::run() + 184
18 org.blenderfoundation.blender 0x000000010d791649 tbb::internal::rml::private_worker::thread_routine(void*) + 9
19 libsystem_pthread.dylib 0x00007fff72eab109 _pthread_start + 148
20 libsystem_pthread.dylib 0x00007fff72ea6b8b thread_start + 15
Thread 28:
Thread 29:
Thread 30:
Thread 31:
0 org.blenderfoundation.blender 0x0000000114ece0f4 normal_quad_v3 + 4
1 org.blenderfoundation.blender 0x0000000114f4ecce tbb::interface7::internal::delegated_function<RangeTask::operator()(tbb::blocked_range<int> const&) const::'lambda'() const, void>::operator()() const + 62
2 org.blenderfoundation.blender 0x000000010d78a3fb tbb::interface7::internal::isolate_within_arena(tbb::interface7::internal::delegate_base&, long) + 75
3 org.blenderfoundation.blender 0x0000000114f4f530 void tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>, tbb::blocked_range<int> >(tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>&, tbb::blocked_range<int>&) + 800
4 org.blenderfoundation.blender 0x0000000114f4f0dd void tbb::interface9::internal::partition_type_base<tbb::interface9::internal::auto_partition_type>::execute<tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>, tbb::blocked_range<int> >(tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>&, tbb::blocked_range<int>&) + 205
5 org.blenderfoundation.blender 0x0000000114f4f009 tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>::execute() + 73
6 org.blenderfoundation.blender 0x000000010d796a39 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
7 org.blenderfoundation.blender 0x000000010d796121 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
8 org.blenderfoundation.blender 0x000000010d793a5e tbb::internal::generic_scheduler::local_spawn_root_and_wait(tbb::task*, tbb::task*&) + 222
9 org.blenderfoundation.blender 0x0000000114f4ed90 tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>::run(tbb::blocked_range<int> const&, RangeTask const&, tbb::auto_partitioner const&) + 160
10 org.blenderfoundation.blender 0x0000000114f4e073 BLI_task_parallel_range + 291
11 org.blenderfoundation.blender 0x000000010d4a3d1a BKE_mesh_calc_normals_poly + 138
12 org.blenderfoundation.blender 0x000000010d4a4723 BKE_mesh_ensure_normals_for_display + 259
13 org.blenderfoundation.blender 0x000000010d3aab9b mesh_calc_modifier_final_normals + 219
14 org.blenderfoundation.blender 0x000000010d3a9e7f mesh_calc_modifiers + 3935
15 org.blenderfoundation.blender 0x000000010d3a8c4b mesh_build_data + 123
16 org.blenderfoundation.blender 0x000000010d3a7f15 makeDerivedMesh + 133
17 org.blenderfoundation.blender 0x000000010d4f40a8 BKE_object_handle_data_update + 1016
18 org.blenderfoundation.blender 0x000000010d4f4594 BKE_object_eval_uber_data + 52
19 org.blenderfoundation.blender 0x0000000113859ed6 blender::deg::(anonymous namespace)::deg_task_run_func(TaskPool*, void*) + 134
20 org.blenderfoundation.blender 0x000000010d78a3fb tbb::interface7::internal::isolate_within_arena(tbb::interface7::internal::delegate_base&, long) + 75
21 org.blenderfoundation.blender 0x0000000114f4df32 tbb::internal::function_task<Task>::execute() + 50
22 org.blenderfoundation.blender 0x000000010d796a39 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
23 org.blenderfoundation.blender 0x000000010d796121 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
24 org.blenderfoundation.blender 0x000000010d787575 tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 533
25 org.blenderfoundation.blender 0x000000010d7908bb tbb::internal::market::process(rml::job&) + 43
26 org.blenderfoundation.blender 0x000000010d791708 tbb::internal::rml::private_worker::run() + 184
27 org.blenderfoundation.blender 0x000000010d791649 tbb::internal::rml::private_worker::thread_routine(void*) + 9
28 libsystem_pthread.dylib 0x00007fff72eab109 _pthread_start + 148
29 libsystem_pthread.dylib 0x00007fff72ea6b8b thread_start + 15
Thread 32:
Thread 33:
Thread 34:
Thread 35:
Thread 36:: com.apple.NSEventThread
2 com.apple.CoreFoundation 0x00007fff38bf6ef5 CFRunLoopServiceMachPort + 247
3 com.apple.CoreFoundation 0x00007fff38bf59c2
CFRunLoopRun + 1319
4 com.apple.CoreFoundation 0x00007fff38bf4e3e CFRunLoopRunSpecific + 462
5 com.apple.AppKit 0x00007fff36008954 _NSEventThread + 132
6 libsystem_pthread.dylib 0x00007fff72eab109 _pthread_start + 148
7 libsystem_pthread.dylib 0x00007fff72ea6b8b thread_start + 15
Thread 37:
Thread 38:
Thread 39:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000  rbx: 0x0000000000000020  rcx: 0x00007fff72de7f02  rdx: 0x0000f0b000000000
rdi: 0x0000000000000000  rsi: 0x0000f0b04d5cad7a  rbp: 0x00007ffee29ab2e0  rsp: 0x00007ffee29ab2d8
 r8: 0x0000000000000000   r9: 0x0000000000000000  r10: 0x0000f0b04d5cafde  r11: 0x0000000000000246
r12: 0x000000000000000f  r13: 0x0000000000000021  r14: 0x0000000000000003  r15: 0x00007fe50ce80c80
rip: 0x00007fff72de7f02  rfl: 0x0000000000000246  cr2: 0x000070000d725aec
Logical CPU: 0
Error Code: 0x00000000
Trap Number: 222
Binary Images:
   0x10d254000 -        0x117a23f87 +org.blenderfoundation.blender (2.91.2 - 2.91.2 2021-01-19) <CF9C6FA1-AACE-3485-AA72-AD4E96F436F1> /Applications/Blender.app/Contents/MacOS/Blender
   0x11e6d2000 -        0x11e73effb +libomp.dylib (0) <535E76BC-1650-3651-9C62-97A995647107> /Applications/Blender.app/Contents/Resources/lib/libomp.dylib
   0x121b31000 -        0x121b33ff3  com.apple.CloudDocsFileProvider (1.0 - 698.17) <C03D572A-4C6B-3DFA-8AA9-064B4808BA72> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/CloudDocsFileProvider.bundle/Contents/MacOS/CloudDocsFileProvider
   0x121b3c000 -        0x121b3ffff  com.apple.FileProviderOverride (304.1 - 304.1) <FF452DA5-75BC-3EF3-B372-F4FD9B7D57B9> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FileProviderOverride.bundle/Contents/MacOS/FileProviderOverride
   0x1232d1000 -        0x12342aff7  com.apple.audio.units.Components (1.14 - 1.14) <21193A0C-D32B-3EAD-B84B-28DF911131B6> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
   0x12345d000 -        0x1238bdfff  com.apple.audio.AudioDSPComponents (1.0 - 1) <F84D78A6-A8F1-3A07-BEB7-306455FDD65A> /System/Library/Components/AudioDSP.component/Contents/MacOS/AudioDSP
   0x12393d000 -        0x123940047  libobjc-trampolines.dylib (787.1) <88F9B648-C455-36F8-BBB9-7D1A9F57D073> /usr/lib/libobjc-trampolines.dylib
   0x123a12000 -        0x123bd4ff7  com.apple.AMDRadeonX6000GLDriver (3.10.19 - 3.1.0) <D138CC1C-7AC0-3DF2-B677-F869715EFD70> /System/Library/Extensions/AMDRadeonX6000GLDriver.bundle/Contents/MacOS/AMDRadeonX6000GLDriver
   0x128f10000 -        0x128f11ff7 +_heapq.cpython-37m-darwin.so (0) <20086BF0-0130-3463-B824-F98C6D51BE39> /Applications/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_heapq.cpython-37m-darwin.so
   0x12911a000 -        0x12911fffb +math.cpython-37m-darwin.so (0) <F76ADA60-2AAA-34A7-BB31-26405F501673> /Applications/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/math.cpython-37m-darwin.so
   0x129f80000 -        0x129f97ffb  com.apple.findersync.fileprovideroverride.FinderSyncCollaborationFileProviderOverride (1.0 - 1298.7.1) <1911451B-5BA5-3A08-AB9F-2729A55BDE38> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FinderSyncCollaborationFileProviderOverride.bundle/Contents/MacOS/FinderSyncCollaborationFileProviderOverride
   0x12a36a000 -        0x12a3fbf47  dyld (750.6) <F58DDECD-315C-3B7C-8162-A5E8E1D62FE3> /usr/lib/dyld
0x7fff2c2ef000 -     0x7fff2c325fff  ATIRadeonX6000SCLib.dylib (3.10.19) <272ECA57-9BB2-3735-9AF1-25BD1CF91A77> /System/Library/Extensions/AMDRadeonX6000GLDriver.bundle/Contents/MacOS/ATIRadeonX6000SCLib.dylib
0x7fff2c326000 -     0x7fff2c59bffc  com.apple.AMDRadeonX6000MTLDriver (3.10.19 - 3.1.0) <F9BD9DB4-B0C3-3FC7-ABF5-8AED9E8CB952> /System/Library/Extensions/AMDRadeonX6000MTLDriver.bundle/Contents/MacOS/AMDRadeonX6000MTLDriver
0x7fff2d4f4000 -     0x7fff2de71fff  libSC.dylib (3.10.19) <6990D42E-C5F0-320A-8DBF-3728D99E54FA> /System/Library/Extensions/AMDShared.bundle/Contents/PlugIns/libSC.dylib
0x7fff3056b000 -     0x7fff31572ff7  com.apple.driver.AppleIntelKBLGraphicsGLDriver (14.7.11 - 14.0.7) <78AC4BB6-0535-3F90-BF7E-0916369C8C2D> /System/Library/Extensions/AppleIntelKBLGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsGLDriver
0x7fff31573000 -     0x7fff31972ff1  com.apple.driver.AppleIntelKBLGraphicsMTLDriver (14.7.11 - 14.0.7) <1384ABF0-8ED1-3E30-828E-FE067DE1368A> /System/Library/Extensions/AppleIntelKBLGraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsMTLDriver
0x7fff34412000 -     0x7fff3460dff8  com.apple.avfoundation (2.0 - 1855.3) <0837D912-3783-35D6-A94A-E474E18600CF> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff3460e000 -     0x7fff346daffe  com.apple.audio.AVFAudio (1.0 - 415.75) <CAC3CA5F-FCF6-37EB-8F1A-090340E2C38E> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fff347fa000 -     0x7fff347fafff  com.apple.Accelerate (1.11 - Accelerate 1.11) <4F9977AE-DBDB-3A16-A536-AC1F9938DCDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff347fb000 -     0x7fff34811fef  libCGInterfaces.dylib (524.2.1) <8FD09D09-BB19-36C5-ADE9-4F22DA235AEE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff34812000 -     0x7fff34e68fff  com.apple.vImage (8.1 - 524.2.1) <EA6F5FF2-7A1B-35D5-A5A3-D2B3386ECB75> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff34e69000 -     0x7fff350d0ff7  libBLAS.dylib (1303.60.1) <C6C2D42F-7456-3DBF-8BE2-9AA06EFC78FD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff350d1000 -     0x7fff355a4fef  libBNNS.dylib (144.100.2) <99C61C48-B14C-3DA6-8C31-6BF72DA0A3A9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff355a5000 -     0x7fff35940fff  libLAPACK.dylib (1303.60.1) <5E3E3867-50C3-3E6A-9A2E-007CE77A4641> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff35941000 -     0x7fff35956fec  libLinearAlgebra.dylib (1303.60.1) <3D433800-0099-33E0-8C81-15F83247B2C9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff35957000 -     0x7fff3595cff3  libQuadrature.dylib (7) <371F36A7-B12F-363E-8955-F24F7C2048F6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff3595d000 -     0x7fff359cdfff  libSparse.dylib (103) <B8A10D0C-4577-343D-B310-A3E81265D107> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff359ce000 -     0x7fff359e0fef  libSparseBLAS.dylib (1303.60.1) <B147FEF6-A0DB-3830-BF06-45BEC58DB576> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff359e1000 -     0x7fff35bb8fd7  libvDSP.dylib (735.140.1) <D63DC0A5-B8B4-3562-A574-E73BC3B57407> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff35bb9000 -     0x7fff35c7bfef  libvMisc.dylib (735.140.1) <3601FDE3-B142-398D-987D-8151A51F0A96> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff35c7c000 -     0x7fff35c7cfff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <F6C5613D-2284-342B-9160-9731F78B4DE5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff35c7d000 -     0x7fff35cdcff0  com.apple.Accounts (113 - 113) <E2438070-30AB-3B89-AE63-1E485B92D108> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fff35e26000 -     0x7fff36be6ff2  com.apple.AppKit (6.9 - 1894.60.100) <322D043D-1140-3486-9523-3F56FF4D8349> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff36c36000 -     0x7fff36c36fff  com.apple.ApplicationServices (48 - 50) <20CF59CD-A395-3570-A4DB-589D55C70B3F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff36c37000 -     0x7fff36ca2fff  com.apple.ApplicationServices.ATS (377 - 493.0.4.1) <87EA5DE1-506A-39FD-88BE-D8A3416C9012> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff36d3b000 -     0x7fff36d79ff0  libFontRegistry.dylib (274.0.5.1) <F3461C05-0370-359B-9F03-5C1C1F7763EC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff36dd4000 -     0x7fff36e03fff  com.apple.ATSUI (1.0 - 1) <5F513967-DDD7-3F22-AD14-8A38ABD9F2D0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
0x7fff36e04000 -     0x7fff36e08ffb  com.apple.ColorSyncLegacy (4.13.0 - 1) <72EE68DB-F069-37F5-AA2A-40D5FCF139F4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff36ea2000 -     0x7fff36ef9ffa  com.apple.HIServices (1.22 - 676) <14DF4D42-E24D-3EBD-9A9D-93124D8D6AA1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff36efa000 -     0x7fff36f08fff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <01B8B6B3-E2C3-3607-B34A-8283A7E0E924> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff36f09000 -     0x7fff36f4effa  com.apple.print.framework.PrintCore (15.4 - 516.2) <437BCF12-48D2-3770-8BC9-567718FB1BCA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff36f4f000 -     0x7fff36f59ff7  com.apple.QD (4.0 - 413) <27A36D07-B5E9-32E6-87B6-3127F260F48D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff36f5a000 -     0x7fff36f67ffc  com.apple.speech.synthesis.framework (9.0.24 - 9.0.24) <75344F8F-32CA-3558-B4E6-F56D498250E4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff36f68000 -     0x7fff37049ffa  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <6185BF20-D2E7-3812-8FD8-EC5237672104> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff3704b000 -     0x7fff3704bfff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <918ED3EB-0232-31F3-9BF5-18D1CB11523F> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff373e2000 -     0x7fff37771ffa  com.apple.CFNetwork (1128.0.1 - 1128.0.1) <07F9CA9C-B954-3EA0-A710-3122BFF9F057> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff377ed000 -     0x7fff377edfff  com.apple.Carbon (160 - 162) <6A5EB506-7A43-3879-A358-E6B9182C3733> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff377ee000 -     0x7fff377f1ff3  com.apple.CommonPanels (1.2.6 - 101) <9F6E13D9-374B-386F-8E15-FDD6CE967859> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff377f2000 -     0x7fff37ae6ff3  com.apple.HIToolbox (2.1.1 - 994.6) <EAF2DAC3-66B1-30BF-AF10-72DDA90D1044> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff37ae7000 -     0x7fff37aeaff3  com.apple.help (1.3.8 - 71) <36483951-6F3E-3F7E-8A5B-191C2357EF17> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff37aeb000 -     0x7fff37af0ff7  com.apple.ImageCapture (9.0 - 1600.65) <1A1F320E-3E85-3F3D-8AE0-B238C4E92D40> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff37af1000 -     0x7fff37af1fff  com.apple.ink.framework (10.15 - 227) <284507AE-EF47-3ABC-86A4-669243DB1D33> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff37af2000 -     0x7fff37b0cffa  com.apple.openscripting (1.7 - 185.1) <B6E28747-5FC7-3461-8A71-864A969ED022> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff37b2d000 -     0x7fff37b2dfff  com.apple.print.framework.Print (15 - 271) <0D9FB08F-EA87-3BE7-821B-C61BA5601050> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff37b2e000 -     0x7fff37b30ff7  com.apple.securityhi (9.0 - 55008) <390C6FAA-99BF-3924-9180-9EAE41D9C6BE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff37b31000 -     0x7fff37b37fff  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <9614A01E-8303-3422-A3BA-6CE27540E09A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff37b38000 -     0x7fff37cd0ffa  com.apple.cloudkit.CloudKit (867 - 867) <1B851180-FC00-357F-B6C1-BB0EA7D6D5CA> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff37cd1000 -     0x7fff37cd1fff  com.apple.Cocoa (6.11 - 23) <85C8B9B4-6F0B-3BD5-8934-C299FE481A44> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff37cdf000 -     0x7fff37dd5fff  com.apple.ColorSync (4.13.0 - 3394.9) <A126406C-DA38-3FFE-8B25-BB9859EFD159> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff380c0000 -     0x7fff385c9ffb  com.apple.audio.CoreAudio (5.0 - 5.0) <47923B12-3D14-328A-9C86-27A3A2A73068> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff3861c000 -     0x7fff38654fff  com.apple.CoreBluetooth (1.0 - 1) <23DBB313-A082-3C08-8E1F-2D31EE4247EF> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff38655000 -     0x7fff38a3ffe8  com.apple.CoreData (120 - 977.3) <49AE61CA-C91E-31FE-9BD0-1AACFFB5181E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff38a40000 -     0x7fff38b72ff6  com.apple.CoreDisplay (1.0 - 186.6.15) <213D7011-8180-3CF4-9BE7-FB8F75DCDB95> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff38b73000 -     0x7fff38ff2feb  com.apple.CoreFoundation (6.9 - 1677.201) <56B0FE5F-D493-3DF1-ABFF-ECC450268B97> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff38ff4000 -     0x7fff39669ff8  com.apple.CoreGraphics (2.0 - 1355.22) <4A3CDE7B-4578-3058-966A-3D1DC095A935> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff39677000 -     0x7fff399d2ff0  com.apple.CoreImage (15.0.0 - 940.9) <69361069-01AB-342E-862B-73A74271A765> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff399d3000 -     0x7fff39a3cff0  com.apple.corelocation (2394.0.22 - 2394.0.22) <75966124-2FB7-33C3-BE49-3DD5F327F911> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff39a90000 -     0x7fff39d92ff2  com.apple.CoreML (1.0 - 1) <FD17F9EB-1930-314C-B6B4-2A2E643AC771> /System/Library/Frameworks/CoreML.framework/Versions/A/CoreML
0x7fff39d93000 -     0x7fff39e6effc  com.apple.CoreMedia (1.0 - 2625.9) <A3FF3AFC-8C1C-36E5-9179-66D8F075EE35> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff39e6f000 -     0x7fff39ed1ffe  com.apple.CoreMediaIO (1000.0 - 5125.6) <6BAFCF2A-9431-39C9-86EE-DC56F861B209> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff39f5b000 -     0x7fff39f5bfff  com.apple.CoreServices (1069.24 - 1069.24) <2D1A6C60-DD34-368F-88FF-E39C9FE549A9> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff39f5c000 -     0x7fff39fe1fff  com.apple.AE (838.1 - 838.1) <2E5FD5AE-8A7F-353F-9BD1-0241F3586181> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff39fe2000 -     0x7fff3a2c3ff7  com.apple.CoreServices.CarbonCore (1217 - 1217) <BE379206-99FA-30CD-8391-2708473A633F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff3a2c4000 -     0x7fff3a311ffd  com.apple.DictionaryServices (1.2 - 323.6) <26B70C82-25BC-353A-858F-945B14C803A2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff3a312000 -     0x7fff3a31aff7  com.apple.CoreServices.FSEvents (1268.100.1 - 1268.100.1) <FC84DB48-A3CE-30F7-A918-B3587731ACC7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff3a31b000 -     0x7fff3a555ff6  com.apple.LaunchServices (1069.24 - 1069.24) <9A5359D9-9148-3B18-B868-56A9DA5FB60C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff3a556000 -     0x7fff3a5eeff1  com.apple.Metadata (10.7.0 - 2076.7) <0973F7E5-D58C-3574-A3CE-4F12CAC2D4C7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff3a5ef000 -     0x7fff3a61cfff  com.apple.CoreServices.OSServices (1069.24 - 1069.24) <0E4F48AD-402C-3E9D-9CA9-6DD9479B28F9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff3a61d000 -     0x7fff3a684fff  com.apple.SearchKit (1.4.1 - 1.4.1) <2C5E1D85-E8B1-3DC5-91B9-E3EDB48E9369> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff3a685000 -     0x7fff3a6a9ff5  com.apple.coreservices.SharedFileList (131.4 - 131.4) <02DE0D56-E371-3EF5-9BC1-FA435451B412> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff3a906000 -     0x7fff3a9cdffc  com.apple.CoreTelephony (113 - 7560.1) <31D93EB1-0A20-3383-9680-090E441F25D8> /System/Library/Frameworks/CoreTelephony.framework/Versions/A/CoreTelephony
0x7fff3a9ce000 -     0x7fff3ab85ffc  com.apple.CoreText (643.1.5.2 - 643.1.5.2) <ADDE38C3-C247-34AD-9903-0276050E242C> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff3ab86000 -     0x7fff3abcaffb  com.apple.CoreVideo (1.8 - 344.3) <5314E70D-325F-3E98-99FC-00FDF520747E> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff3abcb000 -     0x7fff3ac58ffc  com.apple.framework.CoreWLAN (13.0 - 1601.2) <6223BFD5-D451-3DE9-90F6-F609AC0B0027> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff3ae20000 -     0x7fff3aecaff0  com.apple.DiscRecording (9.0.3 - 9030.4.5) <BCF3AFB0-6E1A-3F28-A575-1FD2D74E7C19> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff3aeef000 -     0x7fff3aef5fff  com.apple.DiskArbitration (2.7 - 2.7) <0BBBB6A6-604D-368B-9943-50B8CE75D51D> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff3b0ea000 -     0x7fff3b218ff6  com.apple.FileProvider (304.1 - 304.1) <E8BB1D4B-05D6-386C-865C-F8C750CEC308> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
0x7fff3b22d000 -     0x7fff3b22fff3  com.apple.ForceFeedback (1.0.6 - 1.0.6) <9B324178-4FAA-3686-9E01-634607F38493> /System/Library/Frameworks/ForceFeedback.framework/Versions/A/ForceFeedback
0x7fff3b230000 -     0x7fff3b5f5fff  com.apple.Foundation (6.9 - 1677.201) <E020DC09-4221-3961-A450-638525789B38> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff3b662000 -     0x7fff3b6b2ff7  com.apple.GSS (4.0 - 2.0) <2F3A67E6-D42A-3CF0-9041-A42C22D46F95> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff3b7ef000 -     0x7fff3b903ff3  com.apple.Bluetooth (7.0.6 - 7.0.6f8) <C7AF719C-51B4-3727-A947-EB01204272D9> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff3b969000 -     0x7fff3ba0dff3  com.apple.framework.IOKit (2.0.2 - 1726.140.1) <14223387-6F81-3976-8605-4BC2F253A93E> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff3ba0f000 -     0x7fff3ba20ffb  com.apple.IOSurface (269.11 - 269.11) <BCD744D4-E17E-3C2E-B69C-F69C789892E9> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff3ba3e000 -     0x7fff3ba9eff5  com.apple.ImageCaptureCore (1.0 - 1600.65) <281CE141-B350-30E2-B345-FC7E7DF1AA3A> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff3ba9f000 -     0x7fff3bbfcfee  com.apple.ImageIO.framework (3.3.0 - 1976.11.4) <6FC6EE76-F76F-312C-9C67-4B9F0E0B832A> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff3bbfd000 -     0x7fff3bc00fff  libGIF.dylib (1976.11.4) <F57785E7-6FDA-30A1-B926-CD4D727B56DC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff3bc01000 -     0x7fff3bcbafe7  libJP2.dylib (1976.11.4) <A6CC541D-37C4-3A90-86B0-2F67B917B4EE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff3bcbb000 -     0x7fff3bcdefe3  libJPEG.dylib (1976.11.4) <37FA33BD-1C78-3FA6-8D35-3F3755462597> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff3bf5b000 -     0x7fff3bf75fef  libPng.dylib (1976.11.4) <1AD4B940-5B1F-39A4-873C-9C568AA287B7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff3bf76000 -     0x7fff3bf77fff  libRadiance.dylib (1976.11.4) <868D2C2C-1909-31B1-A0C2-C971F0BE1EC5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff3bf78000 -     0x7fff3bfbefff  libTIFF.dylib (1976.11.4) <1125DCD0-337D-3E01-84F9-106DEEEA5715> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff3bfd7000 -     0x7fff3c466ff8  com.apple.Intents (1.0 - 1) <B2884C7F-0D08-3E3C-91A3-7FB755BB5CB1> /System/Library/Frameworks/Intents.framework/Versions/A/Intents
0x7fff3c469000 -     0x7fff3d509ff1  com.apple.JavaScriptCore (15609 - 15609.4.1) <18766B97-AB12-331C-984C-F1C7C9363E8B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff3d520000 -     0x7fff3d532ff3  com.apple.Kerberos (3.0 - 1) <03BB492B-016E-37BF-B020-39C2CF7487FE> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff3d533000 -     0x7fff3d533fff  libHeimdalProxy.dylib (77) <0A2905EE-9533-3345-AF9B-AAC71513BDFD> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
0x7fff3d8c5000 -     0x7fff3d8cfffb  com.apple.MediaAccessibility (1.0 - 125.1) <98065EA1-3484-3A5A-B05C-D2FABED8CEA4> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff3d99b000 -     0x7fff3e0e8ff2  com.apple.MediaToolbox (1.0 - 2625.9) <3A848992-9182-382A-BF7D-5CB9707BE27B> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff3e0ea000 -     0x7fff3e1b4fff  com.apple.Metal (212.8 - 212.8) <98C944D6-62C8-355E-90F8-C1CA2429EF24> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff3e1b6000 -     0x7fff3e1d0ff5  com.apple.MetalKit (141.2 - 141.2) <FAACD940-5CF2-300A-83F3-86ABA7FDC531> /System/Library/Frameworks/MetalKit.framework/Versions/A/MetalKit
0x7fff3e1d1000 -     0x7fff3e20eff7  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <7EBAC15D-7837-395D-B405-1E29F7DA68FA> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff3e20f000 -     0x7fff3e299fe2  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <B424FE0C-6E90-3BFA-A6E7-DD86C735AE90> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff3e29a000 -     0x7fff3e2bfff4  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <02006D92-E2AB-3892-A96B-37F6520C19BA> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff3e2c0000 -     0x7fff3e2d5ffb  com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <CAA5A368-DB71-34F6-AEF9-27A8BC298F53> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
0x7fff3e2d6000 -     0x7fff3e434ffc  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <05612E06-50CB-318F-9F8E-EF4D49FAB3B0> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff3e435000 -     0x7fff3e484ff4  com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <B0B591F8-6875-351E-867F-8EB3CD38CD52> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
0x7fff3e485000 -     0x7fff3e486ff5  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <F2921F9A-3041-3495-878D-64134267B847> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff3f514000 -     0x7fff3f520ffe  com.apple.NetFS (6.0 - 4.0) <4415F027-D36D-3B9C-96BA-AD22B44A4722> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff3f521000 -     0x7fff3f678ff3  com.apple.Network (1.0 - 1) <4A0F3B93-4D23-3E74-9A3D-AD19E9C0E59E> /System/Library/Frameworks/Network.framework/Versions/A/Network
0x7fff3f679000 -     0x7fff3f8d9ffa  com.apple.NetworkExtension (1.0 - 1) <3ED35C5A-B170-373E-8277-D4198E408810> /System/Library/Frameworks/NetworkExtension.framework/Versions/A/NetworkExtension
0x7fff3f964000 -     0x7fff3f986fff  com.apple.audio.OpenAL (1.8 - 1.8) <6D66C5D7-8410-35B7-B06E-3BE56E0A708E> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
0x7fff420a1000 -     0x7fff420a9ff7  libcldcpuengine.dylib (2.14) <D20EF7DF-8508-3707-A9B3-B7D8190971F5> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff420aa000 -     0x7fff42102fff  com.apple.opencl (3.5 - 3.5) <293FE223-9186-320B-81A4-EC8104C38357> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff42103000 -     0x7fff4211ffff  com.apple.CFOpenDirectory (10.15 - 220.40.1) <7E6C88EB-3DD9-32B0-81FC-179552834FA9> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff42120000 -     0x7fff4212bffd  com.apple.OpenDirectory (10.15 - 220.40.1) <4A92D8D8-A9E5-3A9C-942F-28576F6BCDF5> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff42a91000 -     0x7fff42a93fff  libCVMSPluginSupport.dylib (17.10.22) <2B6C3C16-3F5F-36A8-8070-2A862B90328B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff42a94000 -     0x7fff42a99fff  libCoreFSCache.dylib (176.15) <E9A20E72-B17F-33D6-8894-41934A10B822> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff42a9a000 -     0x7fff42a9efff  libCoreVMClient.dylib (176.15) <018A48BA-1326-3847-8FB5-A7C99322EB87> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff42a9f000 -     0x7fff42aa7ff7  libGFXShared.dylib (17.10.22) <AB47B927-65E3-3924-88BE-0A5BE7906785> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff42aa8000 -     0x7fff42ab2fff  libGL.dylib (17.10.22) <FB5E6A75-398E-38EF-8CB2-59F5BFE3034C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff42ab3000 -     0x7fff42ae7ff7  libGLImage.dylib (17.10.22) <9A3FE633-61B8-3CC7-8183-62960109401A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff42ae8000 -     0x7fff42c7cff7  libGLProgrammability.dylib (17.10.22) <85815C4E-3376-33DF-9FBB-6512142AB61B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff42c7d000 -     0x7fff42cb9fff  libGLU.dylib (17.10.22) <D8B4D804-7323-30BC-871C-B7236FFC2FE3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff436f5000 -     0x7fff43704ff7  com.apple.opengl (17.10.22 - 17.10.22) <D3C57A32-6BD0-3228-B1C4-0F42A6128A6C> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff43705000 -     0x7fff4387efff  GLEngine (17.10.22) <B902FF53-A960-3137-99BD-1F9774F9586C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff4387f000 -     0x7fff438a7fff  GLRendererFloat (17.10.22) <F3D43FBE-7871-3260-B7C9-9BE260F081CD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff438b6000 -     0x7fff439a9ff5  com.apple.PDFKit (1.0 - 845.4.1) <A58B3E4C-6B27-32A7-AC6E-35BCB5A45944> /System/Library/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff439aa000 -     0x7fff43ac1ff9  com.apple.PencilKit (1.0 - 1) <95301D00-CE35-3F53-BAE1-6E6217706702> /System/Library/Frameworks/PencilKit.framework/Versions/A/PencilKit
0x7fff43d62000 -     0x7fff43d68ff6  com.apple.PushKit (1.0 - 1) <AD547A25-1A0B-3FA6-8676-82C37F267A4A> /System/Library/Frameworks/PushKit.framework/Versions/A/PushKit
0x7fff43e89000 -     0x7fff440cfff7  com.apple.imageKit (3.0 - 1081) <5F086EE2-5745-3E28-B292-1DE5E0652E36> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff440d0000 -     0x7fff4458ffff  com.apple.QuartzComposer (5.1 - 378) <9C10ADF7-94B0-3779-AD44-5AF6394A32AF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff44590000 -     0x7fff445b5ffc  com.apple.quartzfilters (1.10.0 - Tag) <876E8B28-9500-34C6-B297-EA404D89C903> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff445b6000 -     0x7fff446c0ff7  com.apple.QuickLookUIFramework (5.0 - 906.3) <7128FB8C-83B0-3250-BF86-E8A1772CF1F5> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff446c1000 -     0x7fff446c1fff  com.apple.quartzframework (1.5 - 23) <48F3D0F9-323E-34E5-8F63-CF541F2B7B0E> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff446c2000 -     0x7fff44945ffb  com.apple.QuartzCore (1.11 - 841.4) <FE927B0E-BD49-32CC-8A55-90F553C86C15> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff44946000 -     0x7fff4499fff5  com.apple.QuickLookFramework (5.0 - 906.3) <959CE934-B541-3172-846F-4D1709353526> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff449a0000 -     0x7fff449d5ffc  com.apple.QuickLookThumbnailing (1.0 - 1) <9CCB50D8-AA39-3744-93FB-7B5B65467AB3> /System/Library/Frameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
0x7fff44ea6000 -     0x7fff44ec0ff2  com.apple.SafariServices.framework (15610 - 15610.2.11.51.10) <15E5509B-9AE4-3980-971A-74E9E80996FB> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
0x7fff454c8000 -     0x7fff45811ff1  com.apple.security (7.0 - 59306.140.5) <B6F8368F-2395-379B-B768-71C53BB1B903> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff45812000 -     0x7fff4589affb  com.apple.securityfoundation (6.0 - 55236.60.1) <7C69DF47-4017-3DF2-B55B-712B481654CB> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff458c9000 -     0x7fff458cdff8  com.apple.xpc.ServiceManagement (1.0 - 1) <9B36FD0E-D280-35EB-ABAB-6AC5D7B2118F> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff46579000 -     0x7fff465f3ff7  com.apple.SystemConfiguration (1.19 - 1.19) <84F9B3BB-F7AF-3B7C-8CD0-D3C22D19619F> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff46873000 -     0x7fff46bf6ff4  com.apple.VideoToolbox (1.0 - 2625.9) <6CF18E28-A7A8-3952-8171-7E4FF4FB37FA> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff4a563000 -     0x7fff4a628fe7  com.apple.APFS (1412.141.1 - 1412.141.1) <C86A3423-E61C-335A-9D17-0B3CE5BB6467> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff4b73d000 -     0x7fff4b73eff1  com.apple.AggregateDictionary (1.0 - 1) <95A291F5-B69F-3C37-9483-C3B2EBF52AC1> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
0x7fff4bb91000 -     0x7fff4bcdcff5  com.apple.AnnotationKit (1.0 - 325.9) <9BB0EDB6-3808-30FC-B0ED-764DE5AAB893> /System/Library/PrivateFrameworks/AnnotationKit.framework/Versions/A/AnnotationKit
0x7fff4bcdd000 -     0x7fff4bcfaff4  com.apple.AppContainer (4.0 - 448.100.6) <87CEE13C-8585-3EFB-92CD-0852DFF0921B> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff4bd4f000 -     0x7fff4bd5dff7  com.apple.AppSandbox (4.0 - 448.100.6) <0F49AA04-3400-349A-9096-6D4D7ED61027> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fff4c1d9000 -     0x7fff4c1fdffb  com.apple.framework.Apple80211 (13.0 - 1610.1) <D94E03E8-4C38-3B2F-8DF4-473ACC5A7D71> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff4c4bb000 -     0x7fff4c4cafd7  com.apple.AppleFSCompression (119.100.1 - 1.0) <466ABD77-2E52-36D1-8E39-77AE2CC61611> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff4c5c9000 -     0x7fff4c5d4ff7  com.apple.AppleIDAuthSupport (1.0 - 1) <74F6CD9C-27A7-39C7-A7EB-47E60D2517EB> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff4c616000 -     0x7fff4c65eff7  com.apple.AppleJPEG (1.0 - 1) <6DE30A07-C627-319B-A0DE-EB7A832BEB88> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff4ca21000 -     0x7fff4ca47ffb  com.apple.aps.framework (4.0 - 4.0) <3ED300B6-43E3-31DC-B3C6-6A0FF41A2595> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff4ca48000 -     0x7fff4ca4cff7  com.apple.AppleSRP (5.0 - 1) <70C25EA9-F7A7-366C-97C6-EEE7845FFCC3> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff4ca4d000 -     0x7fff4ca6ffff  com.apple.applesauce (1.0 - 16.25) <68E0364C-AEA7-3654-A030-136BF3CD92F3> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff4cb2e000 -     0x7fff4cb31fff  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <67255151-F989-39F0-BC87-0C0BDAE70730> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff4cb32000 -     0x7fff4cb82ff7  com.apple.AppleVAFramework (6.1.2 - 6.1.2) <8E18983B-AF92-3853-8251-A6577A55AC15> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff4cbcb000 -     0x7fff4cbdaff9  com.apple.AssertionServices (1.0 - 223.140.2) <48AD21CA-B81D-380E-A04F-90C48FDA5203> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
0x7fff4d11d000 -     0x7fff4d518ff8  com.apple.audio.AudioResourceArbitration (1.0 - 1) <2BD68521-C19C-3D67-B5EB-DE3E9A4DAF0A> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
0x7fff4d657000 -     0x7fff4d6a8ff9  com.apple.audio.AudioSession (1.0 - 17) <AB93CA04-083D-3D80-9C33-28B30BA7A525> /System/Library/PrivateFrameworks/AudioSession.framework/Versions/A/AudioSession
0x7fff4d6a9000 -     0x7fff4d6d6ff7  libSessionUtility.dylib (17) <54A1C204-FCBA-3106-A896-28F22ECF144E> /System/Library/PrivateFrameworks/AudioSession.framework/libSessionUtility.dylib
0x7fff4d76e000 -     0x7fff4d9aefe8  com.apple.audio.AudioToolboxCore (1.0 - 1104.95) <9DB96FE2-AE60-32AE-B706-546E25BAE53F> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
0x7fff4d9b2000 -     0x7fff4dacefff  com.apple.AuthKit (1.0 - 1) <DC1A27C5-0172-3C72-9B24-06996D0B6207> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff4dc8b000 -     0x7fff4dc94ff7  com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <A6877DAD-8F47-363C-983A-DC8DDE83B7B5> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff4dc95000 -     0x7fff4dd36ff5  com.apple.backup.framework (1.11.7 - 1298.7.1) <C9DC35FA-E69F-3C64-9519-494126096337> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff4dd37000 -     0x7fff4ddc3ff6  com.apple.BaseBoard (466.3 - 466.3) <10D0F3BB-E8F3-365E-8528-6AC996A9B0E7> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
0x7fff4dec5000 -     0x7fff4df01ff7  com.apple.bom (14.0 - 219.2) <79CBE5E7-054F-377B-9566-A86A9F120CF1> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff4e01f000 -     0x7fff4e056ff5  com.apple.C2 (1.3 - 495) <4A7E2A63-E19A-3936-92F5-03F2FD602172> /System/Library/PrivateFrameworks/C2.framework/Versions/A/C2
0x7fff4ea81000 -     0x7fff4ead0fff  com.apple.ChunkingLibrary (307 - 307) <5B09C30D-FD2B-3E98-8B64-C5EF470FC13C> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff4ec2b000 -     0x7fff4ecb6ff8  com.apple.CloudDocs (1.0 - 698.17) <900567ED-DEA4-30D5-A1C0-78BD53C58CD6> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff4f97d000 -     0x7fff4f98dffb  com.apple.CommonAuth (4.0 - 2.0) <CF67FF34-4238-3ECA-B4A4-EA04F18A0D36> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff4f9a1000 -     0x7fff4f9b8fff  com.apple.commonutilities (8.0 - 900) <F4C97244-E5D8-3F7D-8D94-4B6841C5A4EC> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
0x7fff500bf000 -     0x7fff50494fc8  com.apple.CoreAUC (283.0.0 - 283.0.0) <4341271C-D270-3F9F-8464-31A20D15158D> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff50495000 -     0x7fff504c2ff7  com.apple.CoreAVCHD (6.1.0 - 6100.4.1) <C3CFDC68-C7D9-3C44-9E7C-801D45575C10> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff504e5000 -     0x7fff50506ff4  com.apple.analyticsd (1.0 - 1) <2162671C-D49D-3891-AB69-9EEB1FA47DD8> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
0x7fff5060f000 -     0x7fff50685ff7  com.apple.corebrightness (1.0 - 1) <8A07EEDB-E52B-3A2B-9B04-3566CE04B46F> /System/Library/PrivateFrameworks/CoreBrightness.framework/Versions/A/CoreBrightness
0x7fff50811000 -     0x7fff5081cff7  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <BB7D67B1-2102-3D71-9BB6-AEB8C6A6EBB2> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff5081d000 -     0x7fff50a28ff1  com.apple.CoreDuet (1.0 - 1) <F899F217-FC31-3140-A0EB-92EAD22EEF71> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
0x7fff50a29000 -     0x7fff50a76ff3  com.apple.coreduetcontext (1.0 - 1) <72341E86-6921-35FE-89CA-7B04725ECC0F> /System/Library/PrivateFrameworks/CoreDuetContext.framework/Versions/A/CoreDuetContext
0x7fff50a77000 -     0x7fff50a87ffe  com.apple.CoreDuetDaemonProtocol (1.0 - 1) <5E31B761-4B30-39A8-9084-97ECFD268B6F> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
0x7fff50a8a000 -     0x7fff50a8cfff  com.apple.CoreDuetDebugLogging (1.0 - 1) <6D0113DB-61D8-3A21-95CB-9E30D8F929F9> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
0x7fff50a9d000 -     0x7fff50aadff3  com.apple.CoreEmoji (1.0 - 107.1) <7C2B3259-083B-31B8-BCDB-1BA360529936> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff50c63000 -     0x7fff50db0fff  com.apple.CoreHandwriting (161 - 1.2) <21DAD964-51A7-3F38-9C91-EF46C0CFF12D> /System/Library/PrivateFrameworks/CoreHandwriting.framework/Versions/A/CoreHandwriting
0x7fff510ed000 -     0x7fff51157ff0  com.apple.CoreNLP (1.0 - 213) <E70E2505-8078-324E-BAE1-01A2DA980E2C> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff5141a000 -     0x7fff514a2ffe  com.apple.CorePDF (4.0 - 518.4.1) <8F94505C-96C2-3694-BEC7-F3B5581A7AB9> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff51585000 -     0x7fff5158dff8  com.apple.CorePhoneNumbers (1.0 - 1) <E4DAD514-0B3B-3E0B-8AEA-39B320FAAF03> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff51f7a000 -     0x7fff51f9dfff  com.apple.CoreSVG (1.0 - 129.3) <F38189F9-C8F9-3D62-9D5F-3F520FB81724> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
0x7fff51f9e000 -     0x7fff51fd1fff  com.apple.CoreServicesInternal (446.7 - 446.7) <65F53A22-6B61-382C-AAC2-B2C53F8FFB44> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff51fd2000 -     0x7fff52000ffd  com.apple.CSStore (1069.24 - 1069.24) <C2D67667-FA0B-3DB6-AA34-6999EE4346A0> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
0x7fff52525000 -     0x7fff525bbff7  com.apple.CoreSymbolication (11.4 - 64535.33.2) <0B3BF87A-7F95-3D79-B4F8-421D6FAC4A6C> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff52653000 -     0x7fff5277fff6  com.apple.coreui (2.1 - 609.4) <788818B7-7EBC-316D-9464-D12E365E3791> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff52780000 -     0x7fff52939ffa  com.apple.CoreUtils (6.2.4 - 624.7) <A74A1C65-6695-3F57-B703-0DEDE13E66C1> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff52a73000 -     0x7fff52a86ff1  com.apple.CrashReporterSupport (10.13 - 15016) <ADF138F0-0274-3BA2-A1D2-48B91577FE53> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff52b3f000 -     0x7fff52b51ff8  com.apple.framework.DFRFoundation (1.0 - 252.50.1) <8162057E-E856-3451-9160-04AEDDECFFA4> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff52b52000 -     0x7fff52b57fff  com.apple.DSExternalDisplay (3.1 - 380) <31ECB5FD-7660-33DB-BC5B-2B2A2AA7C686> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff52be1000 -     0x7fff52c5bff0  com.apple.datadetectorscore (8.0 - 659) <B1534796-1000-3520-A641-A97A4AC5D39B> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff52ca7000 -     0x7fff52ce4ff8  com.apple.DebugSymbols (194 - 194) <040AE30B-CF2C-3798-A289-0929B8CAB10D> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff52ce5000 -     0x7fff52e6dff6  com.apple.desktopservices (1.14.6 - 1281.6.1) <C2355E6B-C5F7-3E39-B778-B117BD4652C6> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff531e5000 -     0x7fff532b8ff1  com.apple.DiskManagement (13.0 - 1648.140.2) <640DBACE-B6EC-3C72-9F73-F484E891534E> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
0x7fff532b9000 -     0x7fff532bdff1  com.apple.DisplayServicesFW (3.1 - 380) <4D71ADB3-B29D-3D20-B6DE-9E94061F86AC> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff53317000 -     0x7fff5333bff7  com.apple.DuetActivityScheduler (1.0 - 1) <188C6793-A94C-3B49-A9F4-AF8A348C7E62> /System/Library/PrivateFrameworks/DuetActivityScheduler.framework/Versions/A/DuetActivityScheduler
0x7fff53365000 -     0x7fff5339aff7  com.apple.SystemConfiguration.EAP8021X (14.0.0 - 14.0) <D3F76E01-2F9F-33E1-B5C9-CAC6E01724C2> /System/Library/PrivateFrameworks/EAP8021X.framework/Versions/A/EAP8021X
0x7fff5339b000 -     0x7fff5339fff9  com.apple.EFILogin (2.0 - 2) <3BFE697B-469F-38F4-B380-4A4F4A37C836> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff53ee9000 -     0x7fff54553ff9  com.apple.vision.EspressoFramework (1.0 - 188.4) <70B1521B-1B24-3DA4-A41B-E727CF140F1F> /System/Library/PrivateFrameworks/Espresso.framework/Versions/A/Espresso
0x7fff5482e000 -     0x7fff54c49ff1  com.apple.vision.FaceCore (4.3.0 - 4.3.0) <5D32F65D-2CD7-3204-975C-F4C9256E505F> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff552a1000 -     0x7fff552a1fff  com.apple.FinderSyncPriv (1.0.7 - 1298.7.1) <5E08FCCF-B5AA-367F-BD08-DEFD32AB073F> /System/Library/PrivateFrameworks/FinderSyncPriv.framework/Versions/A/FinderSyncPriv
0x7fff552e8000 -     0x7fff5541fff4  libFontParser.dylib (277.2.6.3) <D93AD0C8-4657-3A3B-87EB-3DF3D522C70C> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
0x7fff55420000 -     0x7fff55454fff  libTrueTypeScaler.dylib (277.2.6.3) <93039A1A-4946-3166-88B6-82EDD1649C3D> /System/Library/PrivateFrameworks/FontServices.framework/libTrueTypeScaler.dylib
0x7fff554b8000 -     0x7fff554c8ff6  libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <C4B38245-337D-3553-9669-75E5D90071AE> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
0x7fff589a9000 -     0x7fff589aafff  libmetal_timestamp.dylib (902.14.11) <C29C7125-A894-3718-8E1D-249C53BCC0B8> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib
0x7fff5a058000 -     0x7fff5a063ff7  libGPUSupportMercury.dylib (17.10.22) <398D9635-B9CB-3BBB-A1E4-D1D1270D3F99> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff5a064000 -     0x7fff5a06afff  com.apple.GPUWrangler (5.2.7 - 5.2.7) <FA34760B-4E5C-3A18-A6C3-DBA68F9D1220> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff5a389000 -     0x7fff5a3afff1  com.apple.GenerationalStorage (2.0 - 314) <54483E50-20BB-3AF8-900F-992320C109B0> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff5a3c8000 -     0x7fff5b3b1ff1  com.apple.GeoServices (1.0 - 1624.26.4.26.9) <F735575F-7DEF-3202-9151-589BEB162596> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff5b4dd000 -     0x7fff5b4ebffb  com.apple.GraphVisualizer (1.0 - 100.1) <507D5812-9CB4-3C94-938C-59ED2B370818> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff5b554000 -     0x7fff5b561ff9  com.apple.HID (1.0 - 1) <70CFCF8B-4419-3309-B44D-E44259D6A892> /System/Library/PrivateFrameworks/HID.framework/Versions/A/HID
0x7fff5b68a000 -     0x7fff5b748ff4  com.apple.Heimdal (4.0 - 2.0) <B86FE9DB-71BB-3B6E-A4AE-2B0B44570A7F> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff5d8ca000 -     0x7fff5d8d3ffe  com.apple.IOAccelMemoryInfo (1.0 - 1) <50DDA9C2-BDDF-33D4-9BA9-A161E99F1EAD> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
0x7fff5d8d4000 -     0x7fff5d8dcff5  com.apple.IOAccelerator (438.7.3 - 438.7.3) <06E3E70B-C0D0-39A2-96B7-12ED6A0EBEE7> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff5d8e9000 -     0x7fff5d900fff  com.apple.IOPresentment (47.10 - 37) <32F1B3BC-4644-3982-AAB2-8EB5D5FF0161> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff5dc88000 -     0x7fff5dcd3ff1  com.apple.IconServices (438.3 - 438.3) <0DADB4C3-46FF-3FDB-8A86-51E2067FC7F4> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff5de70000 -     0x7fff5de7efff  com.apple.IntentsFoundation (1.0 - 1) <1BC7D355-E136-391A-8215-6982742645DD> /System/Library/PrivateFrameworks/IntentsFoundation.framework/Versions/A/IntentsFoundation
0x7fff5de91000 -     0x7fff5de98ff9  com.apple.InternationalSupport (1.0 - 45.4) <8D8D4A7D-FD35-36B8-A456-7C93030EDAB3> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff5e125000 -     0x7fff5e144ffd  com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <6F655A32-F963-3A7E-B475-E460F4AC7D99> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff5e279000 -     0x7fff5e347ffd  com.apple.LanguageModeling (1.0 - 215.1) <C456087D-5B3A-390E-A665-862FA284C59C> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff5e348000 -     0x7fff5e390fff  com.apple.Lexicon-framework (1.0 - 72) <41F208B9-8255-3EC7-9673-FE0925D071D3> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff5e397000 -     0x7fff5e39cff3  com.apple.LinguisticData (1.0 - 353.18) <3B92F249-4602-325F-984B-D2DE61EEE4E1> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff5e3c3000 -     0x7fff5e3e7ffe  com.apple.locationsupport (2394.0.22 - 2394.0.22) <CA6C86FD-051A-31BB-B3AF-3D02D6FD94B6> /System/Library/PrivateFrameworks/LocationSupport.framework/Versions/A/LocationSupport
0x7fff5ec35000 -     0x7fff5ec38fff  com.apple.Mangrove (1.0 - 25) <482F300F-9B70-351F-A4DF-B440EEF7368D> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff5edf6000 -     0x7fff5ee1cffc  com.apple.MarkupUI (1.0 - 325.9) <A596E8D7-6DBD-3F01-89AD-B296C9D3B61E> /System/Library/PrivateFrameworks/MarkupUI.framework/Versions/A/MarkupUI
0x7fff5eea1000 -     0x7fff5ef2bff8  com.apple.MediaExperience (1.0 - 1) <0203AF27-AB5E-32FA-B529-AB7F29EEB887> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
0x7fff5ef2c000 -     0x7fff5ef5ffff  com.apple.MediaKit (16 - 923) <09FEE738-41E4-3A9C-AF1E-1DD00C56339D> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff5f705000 -     0x7fff5f751fff  com.apple.spotlight.metadata.utilities (1.0 - 2076.7) <0237323B-EC78-3FBF-9FC7-5A1FE2B5CE25> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0x7fff5f752000 -     0x7fff5f823ffa  com.apple.gpusw.MetalTools (1.0 - 1) <99876E08-37D7-3828-8796-56D90C9AFBDB> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff5fa99000 -     0x7fff5fab7fff  com.apple.MobileKeyBag (2.0 - 1.0) <D5FA7041-297F-3ADC-8C7A-6EAAAB82EB68> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff5fb83000 -     0x7fff5fd19ffd  com.apple.Montreal (1.0 - 121.1) <E7881020-FCA6-3DFC-B0EB-9E539F80E821> /System/Library/PrivateFrameworks/Montreal.framework/Versions/A/Montreal
0x7fff5fd1a000 -     0x7fff5fd4aff7  com.apple.MultitouchSupport.framework (3440.1 - 3440.1) <6794E1C8-9627-33DF-84F4-FDD02C97F383> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff6024a000 -     0x7fff60254fff  com.apple.NetAuth (6.2 - 6.2) <B0C03C41-87A3-352B-B130-96E1A6F94B47> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff60c60000 -     0x7fff60cabffb  com.apple.OTSVG (1.0 - 643.1.5.2) <AD1D4601-05DE-37A7-AD7E-FCF46BF9981D> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
0x7fff61ec8000 -     0x7fff61ed3ff2  com.apple.PerformanceAnalysis (1.243.2 - 243.2) <B47C00E5-ECC2-313D-93D4-DBDF562C48EF> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff61ed4000 -     0x7fff61efcffb  com.apple.persistentconnection (1.0 - 1.0) <5B2D87A8-2641-3F6D-ACEA-96B00F85AAB5> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
0x7fff63977000 -     0x7fff639a7ff7  com.apple.pluginkit.framework (1.0 - 1) <EFBD7FE7-02CC-3E30-999D-B036F252F805> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
0x7fff639d2000 -     0x7fff639e5ffc  com.apple.PowerLog (1.0 - 1) <FAD6E2DC-8C9D-38A0-9CB1-75F48473A3E2> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
0x7fff64861000 -     0x7fff648bbff6  com.apple.ProtectedCloudStorage (1.0 - 1) <6F271388-3817-336D-9B96-08C7AAC4BA39> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff648bc000 -     0x7fff648d5ffb  com.apple.ProtocolBuffer (1 - 274.24.9.16.3) <5A020941-C43C-303E-8DE8-230FC6A84DBC> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff649e7000 -     0x7fff649eaff4  com.apple.QuickLookNonBaseSystem (1.0 - 1) <8563CD18-DCFE-3868-912F-053FC8C34B9C> /System/Library/PrivateFrameworks/QuickLookNonBaseSystem.framework/Versions/A/QuickLookNonBaseSystem
0x7fff649eb000 -     0x7fff64a0eff0  com.apple.quicklook.QuickLookSupport (1.0 - 1) <AFB0DFCC-6580-30E5-8984-831985F37A2C> /System/Library/PrivateFrameworks/QuickLookSupport.framework/Versions/A/QuickLookSupport
0x7fff64a55000 -     0x7fff64aceff3  com.apple.Rapport (1.9.5 - 195.2) <AF01D899-3BF9-3586-860A-D95A837101DF> /System/Library/PrivateFrameworks/Rapport.framework/Versions/A/Rapport
0x7fff64d35000 -     0x7fff64d5eff1  com.apple.RemoteViewServices (2.0 - 148) <D3AAC2BE-3423-3F18-9654-E35F1DD8DDB3> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff64ec3000 -     0x7fff64efeff0  com.apple.RunningBoardServices (1.0 - 223.140.2) <96BB04BD-D6E0-3D70-8F36-89B46DA1DA30> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
0x7fff667df000 -     0x7fff667e2ff5  com.apple.SecCodeWrapper (4.0 - 448.100.6) <C4BF691D-A09E-37E8-A6CC-1145B79B8722> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff66955000 -     0x7fff66a7cfff  com.apple.Sharing (1526.37 - 1526.37) <CBDA0ADD-F1E7-3B06-9118-C5E183F0D3D6> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff66af4000 -     0x7fff66b14ff5  com.apple.sidecar-core (1.0 - 209.40.4) <469E5222-A5C7-3B09-B617-EDB6E9E46B93> /System/Library/PrivateFrameworks/SidecarCore.framework/Versions/A/SidecarCore
0x7fff66b15000 -     0x7fff66b27ff0  com.apple.sidecar-ui (1.0 - 209.40.4) <5CA517E3-4B92-30B1-96EF-77A7A2FBBEE4> /System/Library/PrivateFrameworks/SidecarUI.framework/Versions/A/SidecarUI
0x7fff67e91000 -     0x7fff68187ff7  com.apple.SkyLight (1.600.0 - 451.4) <A24929C3-95E6-35A7-9654-46FF3F4D1E80> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff689d4000 -     0x7fff689e2ffb  com.apple.SpeechRecognitionCore (6.0.91.2 - 6.0.91.2) <4D6CAC2A-151B-3BBE-BDB7-E2BE72128691> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff68aa4000 -     0x7fff68d30ffe  com.apple.spotlight.index (10.7.0 - 2076.7) <932C7705-353B-395F-9A23-09D62EAFAD81> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
0x7fff69216000 -     0x7fff6921fff7  com.apple.SymptomDiagnosticReporter (1.0 - 1238.120.2) <C3D66901-7E31-3FDB-BD7A-441EB0520D1D> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
0x7fff694d6000 -     0x7fff694e6ff3  com.apple.TCC (1.0 - 1) <C9EB52E3-099B-3597-9623-067C403FA525> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff69a0b000 -     0x7fff69ad1ff0  com.apple.TextureIO (3.10.9 - 3.10.9) <EEDAB753-329A-396A-8119-5BEDF7DB5A56> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff69ca1000 -     0x7fff69ef9ff0  com.apple.UIFoundation (1.0 - 662) <EC55B9E5-7E62-380A-9AB1-FC7BEF663653> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff69f90000 -     0x7fff69f96ffe  com.apple.URLFormatting (119 - 119.18) <7F99D166-86DC-3F77-A34A-2DA7183D7160> /System/Library/PrivateFrameworks/URLFormatting.framework/Versions/A/URLFormatting
0x7fff6ab6f000 -     0x7fff6ab8fffc  com.apple.UserManagement (1.0 - 1) <9F00880E-6EA6-3684-B208-455E14EC07C8> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
0x7fff6b93b000 -     0x7fff6ba26ff2  com.apple.ViewBridge (467 - 467) <09E8FFB8-4DA1-3E80-8E19-927A2D987BF9> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff6bbcc000 -     0x7fff6bbcdfff  com.apple.WatchdogClient.framework (1.0 - 67.120.2) <FFA17DA1-F6DD-34D3-A708-1F73C8BA7EA7> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
0x7fff6c7fd000 -     0x7fff6c800ffa  com.apple.dt.XCTTargetBootstrap (1.0 - 16091) <D459D628-58C5-39A6-B7E8-B691CBEECEC1> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
0x7fff6c87a000 -     0x7fff6c888ff5  com.apple.audio.caulk (1.0 - 32.3) <06D695EA-E2BC-31E4-9816-9C12542BA744> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
0x7fff6cbca000 -     0x7fff6cbccff3  com.apple.loginsupport (1.0 - 1) <12F77885-27DC-3837-9CE9-A25EBA75F833> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff6cbcd000 -     0x7fff6cbe0ffd  com.apple.login (3.0 - 3.0) <C68367BA-2225-31DD-B2D8-16AC0A44421F> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
0x7fff6cc12000 -     0x7fff6cc1effd  com.apple.perfdata (1.0 - 51.100.6) <21760CFD-62FF-3466-B3AD-191D02411DA0> /System/Library/PrivateFrameworks/perfdata.framework/Versions/A/perfdata
0x7fff6f6a3000 -     0x7fff6f6afff9  libAudioStatistics.dylib (1104.95) <AE4C2A3B-A0F7-3E15-9B87-3845BE0550B2> /usr/lib/libAudioStatistics.dylib
0x7fff6f6b0000 -     0x7fff6f6e3ffa  libAudioToolboxUtility.dylib (1104.95) <E534364D-5E5F-37BA-9FB6-FFFF1416820C> /usr/lib/libAudioToolboxUtility.dylib
0x7fff6f6ea000 -     0x7fff6f71efff  libCRFSuite.dylib (48) <5E5DE3CB-30DD-34DC-AEF8-FE8536A85E96> /usr/lib/libCRFSuite.dylib
0x7fff6f721000 -     0x7fff6f72bfff  libChineseTokenizer.dylib (34) <7F0DA183-1796-315A-B44A-2C234C7C50BE> /usr/lib/libChineseTokenizer.dylib
0x7fff6f72c000 -     0x7fff6f7b4fff  libCoreStorage.dylib (551) <A457B0FE-D77F-30AA-99A4-70F6A98DFE59> /usr/lib/libCoreStorage.dylib
0x7fff6f7b7000 -     0x7fff6f7b9ff7  libDiagnosticMessagesClient.dylib (112) <C94F3B7B-1854-38EB-9778-834501C53B3F> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff6f7ff000 -     0x7fff6f9b6ffb  libFosl_dynamic.dylib (100.4) <737573B2-190A-3BA1-8220-807AD0A2CE5E> /usr/lib/libFosl_dynamic.dylib
0x7fff6f9dd000 -     0x7fff6f9e3ff3  libIOReport.dylib (54) <75D177C4-BAD7-3285-B8E1-3019F49B3178> /usr/lib/libIOReport.dylib
0x7fff6fac5000 -     0x7fff6faccfff  libMatch.1.dylib (36) <5C6F3971-9D9E-3630-BDB6-60BFC5A665E0> /usr/lib/libMatch.1.dylib
0x7fff6fafb000 -     0x7fff6fb1bff7  libMobileGestalt.dylib (826.140.5) <2BE94E6A-FA61-312F-84A1-F764D71B7E39> /usr/lib/libMobileGestalt.dylib
0x7fff6fb9b000 -     0x7fff6fc78ff7  libSMC.dylib (20) <5C9C17F2-1E6F-3A19-A440-86F74D82284F> /usr/lib/libSMC.dylib
0x7fff6fc8d000 -     0x7fff6fc8efff  libSystem.B.dylib (1281.100.1) <8E6AD412-91E7-36FC-A6FD-C13B06A4952A> /usr/lib/libSystem.B.dylib
0x7fff6fc8f000 -     0x7fff6fd1aff7  libTelephonyUtilDynamic.dylib (5017.1) <174030B2-E35F-3F17-A9EF-DF8631F30CCF> /usr/lib/libTelephonyUtilDynamic.dylib
0x7fff6fd1b000 -     0x7fff6fd1cfff  libThaiTokenizer.dylib (3) <4F4ADE99-0D09-3223-B7C0-C407AB6DE8DC> /usr/lib/libThaiTokenizer.dylib
0x7fff6fd34000 -     0x7fff6fd4afff  libapple_nghttp2.dylib (1.39.2) <07FEC48A-87CF-32A3-8194-FA70B361713A> /usr/lib/libapple_nghttp2.dylib
0x7fff6fd7f000 -     0x7fff6fdf1ff7  libarchive.2.dylib (72.140.2) <F9EA2883-5D5C-3FA6-B3F8-C5031BF88ABD> /usr/lib/libarchive.2.dylib
0x7fff6fdf2000 -     0x7fff6fe8bfe5  libate.dylib (3.0.1) <76EA60FB-748C-313F-8951-B076540BEA97> /usr/lib/libate.dylib
0x7fff6fe8f000 -     0x7fff6fe8fff3  libauto.dylib (187) <B6124448-7690-34AE-8939-ED84AAC630CE> /usr/lib/libauto.dylib
0x7fff6ff55000 -     0x7fff6ff65ffb  libbsm.0.dylib (60.100.1) <00BFFB9A-2FFE-3C24-896A-251BC61917FD> /usr/lib/libbsm.0.dylib
0x7fff6ff66000 -     0x7fff6ff72fff  libbz2.1.0.dylib (44) <14CC4988-B6D4-3879-AFC2-9A0DDC6388DE> /usr/lib/libbz2.1.0.dylib
0x7fff6ff73000 -     0x7fff6ffc5fff  libc++.1.dylib (902.1) <59A8239F-C28A-3B59-B8FA-11340DC85EDC> /usr/lib/libc++.1.dylib
0x7fff6ffc6000 -     0x7fff6ffdbffb  libc++abi.dylib (902) <E692F14F-C65E-303B-9921-BB7E97D77855> /usr/lib/libc++abi.dylib
0x7fff6ffdc000 -     0x7fff6ffdcfff  libcharset.1.dylib (59) <72447768-9244-39AB-8E79-2FA14EC0AD33> /usr/lib/libcharset.1.dylib
0x7fff6ffdd000 -     0x7fff6ffeefff  libcmph.dylib (8) <E72A20DB-2E86-378D-A237-EB9A1370F989> /usr/lib/libcmph.dylib
0x7fff6ffef000 -     0x7fff70006fd7  libcompression.dylib (87) <64C91066-586D-38C0-A2F3-3E60A940F859> /usr/lib/libcompression.dylib
0x7fff702e0000 -     0x7fff702f6ff7  libcoretls.dylib (167) <770A5B96-936E-34E3-B006-B1CEC299B5A5> /usr/lib/libcoretls.dylib
0x7fff702f7000 -     0x7fff702f8fff  libcoretls_cfhelpers.dylib (167) <940BF370-FD0C-30A8-AA05-FF48DA44FA4C> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff708a2000 -     0x7fff708adfff  libcsfde.dylib (551) <CEE22AEF-4E77-36B1-B007-00303819965F> /usr/lib/libcsfde.dylib
0x7fff708b5000 -     0x7fff70914ff7  libcups.2.dylib (483.7) <821ED293-B7B3-3B37-88C9-7B6CA91DA7FA> /usr/lib/libcups.2.dylib
0x7fff70a1e000 -     0x7fff70a1efff  libenergytrace.dylib (21) <162DFCC0-8F48-3DD0-914F-FA8653E27B26> /usr/lib/libenergytrace.dylib
0x7fff70a1f000 -     0x7fff70a37fff  libexpat.1.dylib (19.60.2) <FED7C38B-92D8-342D-AED7-871B12D1F7E7> /usr/lib/libexpat.1.dylib
0x7fff70a45000 -     0x7fff70a47fff  libfakelink.dylib (149.1) <36146CB2-E6A5-37BB-9EE8-1B4034D8F3AD> /usr/lib/libfakelink.dylib
0x7fff70a56000 -     0x7fff70a5bfff  libgermantok.dylib (24) <D2AE5AC0-EDCE-3216-B8C9-CF59292A545F> /usr/lib/libgermantok.dylib
0x7fff70a5c000 -     0x7fff70a65ff7  libheimdal-asn1.dylib (564.140.1) <0AC6FB62-2B0F-3E93-A931-E4DC4B1D757A> /usr/lib/libheimdal-asn1.dylib
0x7fff70a66000 -     0x7fff70b56fff  libiconv.2.dylib (59) <18311A67-E4EF-3CC7-95B3-C0EDEE3A282F> /usr/lib/libiconv.2.dylib
0x7fff70b57000 -     0x7fff70daefff  libicucore.A.dylib (64260.0.1) <8AC2CB07-E7E0-340D-A849-186FA1F27251> /usr/lib/libicucore.A.dylib
0x7fff70dc6000 -     0x7fff70dc7fff  liblangid.dylib (133) <30CFC08C-EF36-3CF5-8AEA-C1CB070306B7> /usr/lib/liblangid.dylib
0x7fff70dc8000 -     0x7fff70de0ff3  liblzma.5.dylib (16) <C131EF18-2CDD-3271-8A30-A8760D4FE166> /usr/lib/liblzma.5.dylib
0x7fff70df8000 -     0x7fff70e9fff7  libmecab.dylib (883.11) <0D5BFD01-D4A7-3C8D-AA69-C329C1A69792> /usr/lib/libmecab.dylib
0x7fff70ea0000 -     0x7fff71102ff1  libmecabra.dylib (883.11) <E31DE74D-1B88-377F-ACD3-D789D29C3AE7> /usr/lib/libmecabra.dylib
0x7fff7146f000 -     0x7fff7149efff  libncurses.5.4.dylib (57) <995DFEEA-40F3-377F-B73D-D02AC59D591F> /usr/lib/libncurses.5.4.dylib
0x7fff715ce000 -     0x7fff71a4aff5  libnetwork.dylib (1880.120.4) <BA294A54-F309-398D-B308-F97032AFF555> /usr/lib/libnetwork.dylib
0x7fff71a4b000 -     0x7fff71a62fff  libnetworkextension.dylib (1095.140.2) <D0E8454C-33A9-3F96-B3A0-EDB12C32283A> /usr/lib/libnetworkextension.dylib
0x7fff71aeb000 -     0x7fff71b1efde  libobjc.A.dylib (787.1) <6DF81160-5E7F-3E31-AA1E-C875E3B98AF6> /usr/lib/libobjc.A.dylib
0x7fff71b31000 -     0x7fff71b35fff  libpam.2.dylib (25.100.1) <0502F395-8EE6-3D2A-9239-06FD5622E19E> /usr/lib/libpam.2.dylib
0x7fff71b38000 -     0x7fff71b6eff7  libpcap.A.dylib (89.120.1) <A76EC076-A8EA-354C-B95F-7AB1EAFBCC65> /usr/lib/libpcap.A.dylib
0x7fff71bae000 -     0x7fff71bbcff9  libperfcheck.dylib (37.100.2) <9D9C4879-8A80-34C4-B0D2-BE341FD6D321> /usr/lib/libperfcheck.dylib
0x7fff71bf2000 -     0x7fff71c0afff  libresolv.9.dylib (67.40.1) <C57EDFEF-D36A-310B-8D14-8C68A625B1E8> /usr/lib/libresolv.9.dylib
0x7fff71c0c000 -     0x7fff71c50ff7  libsandbox.1.dylib (1217.141.2) <E8BA5E84-66AF-3995-8F8E-DDC93B0A88E1> /usr/lib/libsandbox.1.dylib
0x7fff71c64000 -     0x7fff71c65ff7  libspindump.dylib (281.3) <AE8C1AE9-5CBC-332F-BBE8-370A2A19FED6> /usr/lib/libspindump.dylib
0x7fff71c66000 -     0x7fff71e50ff7  libsqlite3.dylib (308.5) <35A2BD9F-4E33-30DE-A994-4AB585AC3AFE> /usr/lib/libsqlite3.dylib
0x7fff720a1000 -     0x7fff720a4ffb  libutil.dylib (57) <F01467F6-23A7-37EE-A170-33CE1577B41D> /usr/lib/libutil.dylib
0x7fff720a5000 -     0x7fff720b2ff7  libxar.1.dylib (425.2) <EE964412-9E25-30B3-BCC0-CCEFBCC8094B> /usr/lib/libxar.1.dylib
0x7fff720b8000 -     0x7fff7219afff  libxml2.2.dylib (33.7) <20567881-7204-3C11-9179-50FE34B3301B> /usr/lib/libxml2.2.dylib
0x7fff7219e000 -     0x7fff721c6fff  libxslt.1.dylib (16.9) <34A45627-DA5B-37D2-9609-65B425E0010A> /usr/lib/libxslt.1.dylib
0x7fff721c7000 -     0x7fff721d9ff3  libz.1.dylib (76) <793D9643-CD83-3AAC-8B96-88D548FAB620> /usr/lib/libz.1.dylib
0x7fff72a88000 -     0x7fff72a8dff3  libcache.dylib (83) <AF488D13-9E89-35E0-B078-BE37CC5B8586> /usr/lib/system/libcache.dylib
0x7fff72a8e000 -     0x7fff72a99fff  libcommonCrypto.dylib (60165.120.1) <C7912BE5-993E-3581-B2A0-6AABDC8C5562> /usr/lib/system/libcommonCrypto.dylib
0x7fff72a9a000 -     0x7fff72aa1fff  libcompiler_rt.dylib (101.2) <49B8F644-5705-3F16-BBE0-6FFF9B17C36E> /usr/lib/system/libcompiler_rt.dylib
0x7fff72aa2000 -     0x7fff72aabff7  libcopyfile.dylib (166.40.1) <3C481225-21E7-370A-A30E-0CCFDD64A92C> /usr/lib/system/libcopyfile.dylib
0x7fff72aac000 -     0x7fff72b3efdb  libcorecrypto.dylib (866.140.1) <60567BF8-80FA-359A-B2F3-A3BAEFB288FD> /usr/lib/system/libcorecrypto.dylib
0x7fff72c4b000 -     0x7fff72c8bff0  libdispatch.dylib (1173.100.2) <CD9C059C-91D9-30E8-8926-5B9CD0D5D4F5> /usr/lib/system/libdispatch.dylib
0x7fff72c8c000 -     0x7fff72cc2fff  libdyld.dylib (750.6) <789A18C2-8AC7-3C88-813D-CD674376585D> /usr/lib/system/libdyld.dylib
0x7fff72cc3000 -     0x7fff72cc3ffb  libkeymgr.dylib (30) <DB3337BE-01CA-3425-BD0C-87774FC0CDC0> /usr/lib/system/libkeymgr.dylib
0x7fff72cc4000 -     0x7fff72cd0ff3  libkxld.dylib (6153.141.10) <11EABEB3-CD17-3787-86BE-B8B21817E89B> /usr/lib/system/libkxld.dylib
0x7fff72cd1000 -     0x7fff72cd1ff7  liblaunch.dylib (1738.140.2) <7200E214-9B4D-3B22-9844-4C7892FC890B> /usr/lib/system/liblaunch.dylib
0x7fff72cd2000 -     0x7fff72cd7ff7  libmacho.dylib (959.0.1) <AA613A9C-961A-3B67-B696-4622FA59FC4E> /usr/lib/system/libmacho.dylib
0x7fff72cd8000 -     0x7fff72cdaff3  libquarantine.dylib (110.40.3) <F234E51D-FD0B-3EE4-B679-AE3EE9C536C3> /usr/lib/system/libquarantine.dylib
0x7fff72cdb000 -     0x7fff72cdcff7  libremovefile.dylib (48) <7C7EFC79-BD24-33EF-B073-06AED234593E> /usr/lib/system/libremovefile.dylib
0x7fff72cdd000 -     0x7fff72cf4ff3  libsystem_asl.dylib (377.60.2) <1563EE02-0657-3B78-99BE-A947C24122EF> /usr/lib/system/libsystem_asl.dylib
0x7fff72cf5000 -     0x7fff72cf5ff7  libsystem_blocks.dylib (74) <0D53847E-AF5F-3ACF-B51F-A15DEA4DEC58> /usr/lib/system/libsystem_blocks.dylib
0x7fff72cf6000 -     0x7fff72d7dfff  libsystem_c.dylib (1353.100.2) <BBDED5E6-A646-3EED-B33A-91E4331EA063> /usr/lib/system/libsystem_c.dylib
0x7fff72d7e000 -     0x7fff72d81ffb  libsystem_configuration.dylib (1061.141.1) <0EE84C33-64FD-372B-974A-AF7A136F2068> /usr/lib/system/libsystem_configuration.dylib
0x7fff72d82000 -     0x7fff72d85fff  libsystem_coreservices.dylib (114) <A199156E-058D-3ABB-BCE9-4B9F20DCED0F> /usr/lib/system/libsystem_coreservices.dylib
0x7fff72d86000 -     0x7fff72d8efff  libsystem_darwin.dylib (1353.100.2) <5B12B5DB-3F30-37C1-8ECC-49A66B1F2864> /usr/lib/system/libsystem_darwin.dylib
0x7fff72d8f000 -     0x7fff72d96fff  libsystem_dnssd.dylib (1096.100.3) <EBB4C2C2-E031-3094-B40A-E67BF261D295> /usr/lib/system/libsystem_dnssd.dylib
0x7fff72d97000 -     0x7fff72d98ffb  libsystem_featureflags.dylib (17) <29FD922A-EC2C-3F25-BCCC-B58D716E60EC> /usr/lib/system/libsystem_featureflags.dylib
0x7fff72d99000 -     0x7fff72de6ff7  libsystem_info.dylib (538) <8A321605-5480-330B-AF9E-64E65DE61747> /usr/lib/system/libsystem_info.dylib
0x7fff72de7000 -     0x7fff72e13ff7  libsystem_kernel.dylib (6153.141.10) <FF092EE8-5BEE-3B9A-8749-F0A067115C7E> /usr/lib/system/libsystem_kernel.dylib
0x7fff72e14000 -     0x7fff72e5bfff  libsystem_m.dylib (3178) <00F331F1-0D09-39B3-8736-1FE90E64E903> /usr/lib/system/libsystem_m.dylib
0x7fff72e5c000 -     0x7fff72e83fff  libsystem_malloc.dylib (283.100.6) <8549294E-4C53-36EB-99F3-584A7393D8D5> /usr/lib/system/libsystem_malloc.dylib
0x7fff72e84000 -     0x7fff72e91ffb  libsystem_networkextension.dylib (1095.140.2) <F06C65C5-2CBE-313C-96E1-A09240F9FE57> /usr/lib/system/libsystem_networkextension.dylib
0x7fff72e92000 -     0x7fff72e9bff7  libsystem_notify.dylib (241.100.2) <FA22F928-D91B-3AA5-96BB-3186AC0FB264> /usr/lib/system/libsystem_notify.dylib
0x7fff72e9c000 -     0x7fff72ea4fef  libsystem_platform.dylib (220.100.1) <009A7C1F-313A-318E-B9F2-30F4C06FEA5C> /usr/lib/system/libsystem_platform.dylib
0x7fff72ea5000 -     0x7fff72eaffff  libsystem_pthread.dylib (416.100.3) <62CB1A98-0B8F-31E7-A02B-A1139927F61D> /usr/lib/system/libsystem_pthread.dylib
0x7fff72eb0000 -     0x7fff72eb4ff3  libsystem_sandbox.dylib (1217.141.2) <051C4018-4345-3034-AC98-6DE42FB8273B> /usr/lib/system/libsystem_sandbox.dylib
0x7fff72eb5000 -     0x7fff72eb7fff  libsystem_secinit.dylib (62.100.2) <F80872AA-E1FD-3D7E-8729-467656EC6561> /usr/lib/system/libsystem_secinit.dylib
0x7fff72eb8000 -     0x7fff72ebfffb  libsystem_symptoms.dylib (1238.120.2) <702D0910-5C34-3D43-9631-8BD215DE4FE1> /usr/lib/system/libsystem_symptoms.dylib
0x7fff72ec0000 -     0x7fff72ed6ff2  libsystem_trace.dylib (1147.120.1) <BC141783-66D9-3137-A783-211B38E49ADB> /usr/lib/system/libsystem_trace.dylib
0x7fff72ed8000 -     0x7fff72eddff7  libunwind.dylib (35.4) <42B7B509-BAFE-365B-893A-72414C92F5BF> /usr/lib/system/libunwind.dylib
0x7fff72ede000 -     0x7fff72f13ffe  libxpc.dylib (1738.140.2) <54EEF402-42C7-3995-BADE-93C48EFC4452> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
  task_for_pid: 8
  thread_create: 0
  thread_set_state: 0
Calls made by this process:
  task_for_pid: 0
  thread_create: 0
  thread_set_state: 0
Calls made by all processes on this machine:
  task_for_pid: 101212910
  thread_create: 0
  thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=913.1M resident=0K(0%) swapped_out_or_unallocated=913.1M(100%)
Writable regions: Total=2.1G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=2.1G(100%)
VIRTUAL   REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 128K 1
Activity Tracing 256K 1
CG backing stores 1232K 2
CG image 88K 6
CoreAnimation 104K 9
CoreGraphics 8K 1
CoreImage 32K 4
CoreUI image data 876K 7
Foundation 4K 1
Kernel Alloc Once 8K 1
MALLOC 513.3M 94
MALLOC guard page 48K 10
MALLOC_MEDIUM (reserved) 1.1G 10 reserved VM address space (unallocated)
MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)
OpenGL GLSL 256K 3
STACK GUARD 160K 40
Stack 73.3M 41
VM_ALLOCATE 34.6M 203
VM_ALLOCATE (reserved) 32K 1 reserved VM address space (unallocated)
DATA 113.7M 386
DATA_CONST 416K 7
FONT_DATA 4K 1
GLSLBUILTINS 5176K 1
LINKEDIT 437.1M 16
OBJC_RO 32.3M 1
OBJC_RW 1908K 2
TEXT 476.1M 371
__UNICODE 564K 1
mapped file 73.0M 23
shared memory 636K 15
TOTAL 3.2G 1260
TOTAL, minus reserved VM space 1.7G 1260
Model: MacBookPro16,1, BootROM 1554.60.15.0.0 (iBridge: 18.16.13030.0.0,0), 8 processors, 8-Core Intel Core i9, 2.4 GHz, 64 GB, SMC
Graphics: kHW_IntelUHDGraphics630Item, Intel UHD Graphics 630, spdisplays_builtin
Graphics: kHW_AMDRadeonPro5500MItem, AMD Radeon Pro 5500M, spdisplays_pcie_device, 4 GB
Memory Module: BANK 0/ChannelA-DIMM0, 32 GB, DDR4, 2667 MHz, Micron, -
Memory Module: BANK 2/ChannelB-DIMM0, 32 GB, DDR4, 2667 MHz, Micron, -
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x7BF), wl0: Oct 28 2020 14:13:29 version 9.30.357.42.32.5.48 FWID 01-767f6cce
Bluetooth: Version 7.0.6f8, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB 3.1 Bus
USB Device: Apple T2 Bus
USB Device: Composite Device
USB Device: Touch Bar Backlight
USB Device: Touch Bar Display
USB Device: Apple Internal Keyboard / Trackpad
USB Device: Headset
USB Device: Ambient Light Sensor
USB Device: FaceTime HD Camera (Built-in)
USB Device: Apple T2 Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 55.3
Related Objects
Campbell Barton (campbellbarton) changed the task status from Needs Triage to Needs Information from User.Feb 11 2021, 4:03 AM
This report is missing:
  • Last version that worked.
  • Exact steps to redo the error.
  • A blend file (unless there are simple steps to redo this from the default startup).
  • I don't know the last version that worked. However I already noticed this twice on version 2.91.2. Before I was using 2.8* but I am not sure if it was happening and I just didn't notice that it was crashing for this reason.
  • To reproduce just go to the "wings2" scene
  • I uploaded the blender file at the top of the description. Sorry I missed this before.
Campbell Barton (campbellbarton) closed this task as Archived.EditedFeb 11 2021, 5:50 AM
Running this in the Python console shows that Cube.001 has corrupt geometry.
for mesh in bpy.data.meshes: print(mesh.name, mesh.validate(verbose=True))
To resolve this we would need to know how the mesh became corrupt.
Closing. Submit a new report if you have the steps to reproduce the corrupt file.
It has happened twice already today to me. Will definitely try to find a way to reproduce.
Stupid question: Is there a way in the python console to delete the mesh with the corrupt geometry so at least I can open the scene up again?
Thanks
IT FIXED IT!
running validate on said mesh fixed the mesh and it is no longer crashing!
Here is a screenshot. Literally all I did was run that command twice.
It is supposed to do that?
