Evee rendering bug + RenderDoc capture
Operating system:Ubuntu 18.04.1 Linux 64 bit
Graphics card: Radeon r5 230
Broken: blender 2.81 and blender 2.93.0
Worked: Never
As shown in image, there is a triangle artifact in the slider menus
Also, Evee is not rendering correctly, as can be seen in the artifacts generated in the cube render.
I have attached a RenderDoc opengl capture, it may be useful
May be reproduced only in a linux machine with the same gpu hardware, so, I attached a RenderDoc capture file that can be opened with RenderDoc 1.12
Jeroen Bakker (jbakker) closed this task as Archived.Feb 15 2021, 9:58 AM
Hi @Oskar Osborn (wavedevice)
Check https://www.blender.org/download/requirements/
Since Blender 2.91, Terascale 2 architecture is fully deprecated, try using 2.90
Your GPU is based on TeraScale 2.
Understood. This GPU seems to had its support dropped long years ago, and the new amdgpu drivers don't support it.
My workaround was to use the internal gpu:
DRI_PRIME=1 ./blender
