Display Error in Material Properties Tab
Operating system: Darwin-17.7.0-x86_64-i386-64bit 64 Bits
Graphics card: ATI Radeon HD 5670 OpenGL Engine ATI Technologies Inc. 4.1 ATI-1.68.25
Broken: version: 2.92.0 Release Candidate, branch: master, commit date: 2021-02-19 18:02, hash: rBb1142858d4ca
Worked: pre–2.8
Preview window and thumbnails for material index display incorrectly in the material properties tab if the render engine is set to Eevee. This display issue does not occur if the render engine is set to Cycles and will appear as expected. Adjusting properties (base color, emission, etc) produce abnormal results.
[Initial appearance in Eevee]
[After adjusting base color to red]
[Appearance in Cycles]
From startup, navigate to the material properties tab. If render engine is set to Eevee, the preview window and thumbnails beside material indexes in the above menu will display incorrectly.
Thank you!
Thanks for the report,
I cannot reproduce this with either the latest stable or current development versions of Blender.
Please try the latest daily build: https://builder.blender.org/download/
Go to File β†’ Defaults β†’ Load Factory Settings and then load your file to see if you still can reproduce this issue.
Unfortunately this GPU is below the minimum requirements for Blender, so we no longer provide support for it. https://www.blender.org/download/requirements/
Radeon HD 5000 series has Terascale2 architecture that is before GNC (Minimum supported is "AMD: GCN 1st gen and newer").
As this GPU does not meet minimum requirement for Blender 2.9x, I feel have to close the report.
Community effort to fix the bug is welcome.
We won't stop users from running out program on unsupported hardware, but we do not handle bug reports of issues that happen when doing so.
