Operating system: Darwin-18.7.0-x86_64-i386-64bit 64 Bits
Graphics card: Intel Iris OpenGL Engine Intel Inc. 4.1 INTEL-12.10.16
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-02-23 23:15, hash: rBb2c7ea6d82c4
Worked: -
The Attribute Combine XYZ and Attribute Separate XYZ node have no affect on instanced geometry.
Open the provided .blend file and try setup 2 and 3.
Reproduce from startup file:
- Add a second mesh to the scene.
- Add a geometry nodes modifier to the default cube and instance geometry on it with the point separate node.
- Try accessing/modifying the position attributes of the instances with the Attribute Combine/Separate XYZ nodes.
