Operating system: Windows 10
Graphics card: MSI Nvidia 3090 Gaming Trio (using Optix)
Broken: 2.92.0
Can't enter viewport rendering with the default cube when feature set is set to experimental and device is set to GPU.
- Open Blender
- Set Render Engine to Cycles
- Set Feature Set to Experimental
- Set Device to GPU
- Enter viewport rendering
- An error appears:
Failed to create CUDA context (illegal address)
Another bug that might be relevant
I found another bug that might be a part of this bug, the second one prints a file and a line in code, but I can't reproduce it from a blank file since I can't get past this one. The second scene includes having an adaptive subdiv on a plane that covers most of the viewport and a bezier curve with geometry->bevel->any depth. When I hide the plane while viewport rendering is on I get an error:
CUDA__ERROR_ILLEGAL_ADDRESS in cuStreamSynchronize(cuda_stream[thread_index]) (device_optix.cpp:816)
When the plane is smaller the error doesn't appear. Should I create a separate report for the second one even tho I can't recreate the steps? I can send the file if you want to look into it. The file was created earlier using a 2.92 alpha version.
