Extreme Long Edges Not Selectable in 3D View
Operating system: Windows 8.1
Graphics card: GeForce GT 1030
Broken: 2.92.0
Worked: Not Sure
Long edges do not seem to be selectable if your 3D view is zoomed in from the ends of long singular edges. This seems pretty sporadic but I've noticed it a number of times here just recently, I installed over 2.91 so can't be sure. The view clip ends at 3280.84ft so I don't believe it's that or being too near due to clip start, either.
Delete All
Add Plane
enter Edit Mode in Edge Mode
move two of the parallel edges to around 300' along X and -X inversely.
also move one of the connecting edges between the prior 2 along -Y 300'
should have a 300' x 600' plane now
zoom view and attempt selecting the edge while its vertices are out of view
Unselectable edge highlighted
Edge Lengths
boaright (boaright) updated the task description. (Show Details)
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Needs Information from User.EditedMar 5 2021, 6:54 PM
I cannot reproduce the problem or maybe I have wrongly followed the steps to replicate it.
Could you provide a simple .blend file demonstrating the problem?
Germano Cavalcante (mano-wii) changed the task status from Needs Information from User to Needs Triage.Mar 15 2021, 1:28 AM
Thanks for the report. If the problem persists please open a new report with the required information.
