Operating system: Linux
Graphics card: Intel
Broken: 2.91, 2.92 (Possibly since https://developer.blender.org/D8825)
Worked: 2.90
Searching for properties used to match all available names that contained the search term.
For example, searching "head", "character", or "model" would match "SomeCharacterModelHead".
As of Blender 2.91, it longer does this.
Personally, I find the current behaviour much less predictable, and thus much less useful. I can notice typos and fix them if necessary, but I can't always recall the entirety of a multiple-part name if the fuzzy search doesn't return it right away.
The main advertised benefit of a fuzzy search is that it can search from misspellings and typos. But since the artist's the one who usually named the objects in the scene, and since they can easily correct typos anyway, this benefit is of questionable use.
And in order to try to accommodate easily correctable user errors, we now not only get a large number of false positives, but we've also broken searching for correct spellings that IMO totally should work.
This has actually been a pretty major usability regression for me, especially since the unique parts of my objects' names tend to be at the end or in the middle of their names, where fuzzy search nearly always fails. That means that I have to search from the start of the name, which is usually the most generic part and thus returns half of the objects in the entire scene as false positives, which in turn means that I end up having to remember the exact name of the object, thus completely negating the "fuzzy" part of "fuzzy search".
It's easier to fix a typo than it is to sort through a long list of false positives or remember the exact name of an object when fuzzy search inevitably fails for a simple substring search term.
2.90, searching "head" returns "SomeCharacterModelHead", as expected:
2.91 and 2.92, searching "head" does not return "SomeCharacterModelHead". "Character" and "model" don't either, which means that the only viable search terms are the ones beginning with "Some"— Which, even without the mess returned by fuzzy search, would already likely return the largest number of false positives:
IMO predictability is important to usability, and using an opaque algorithm hurts that. If we can't predict how the search algorithm is going to behave, and if it fails to behave as expected with simple and entirely reasonable search terms, then we cannot quickly derive search terms to find the property we want.
Search for nearly any substring of any property's name, or search for "head", "model", or "character" in .objects["Cube"].modifiers["SearchHere"].object in the attached file:
