VSE: Color in Overlay does not fade
Closed, DuplicatePublic
Operating system: w10
Graphics card: nv3070
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen) 2.92
In VSE I added a Color Layer in overlay mode. I faded the opacity but it does not fade at all. It is either on or off.
Start VSE,
add image (in my case a .psd and also .exr),
add Adjustment layer: color,
set to overlay mode and pick color,
fade opacity
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Mar 8 2021, 6:03 PM
Not exactly sure if I understand correctly:
what do you mean?
Could you just share your .blend file?
Sorry,
I meant go to Add>Color and it seems to be an Effect Strip.
I cant upload the file cause it is 570MB plus appended scenes etc...
I added a screenshot for you.
Philipp Oeser (lichtwerk) changed the task status from Needs Information from User to Needs Triage.Mar 8 2021, 9:59 PM
Ah, OK, there is indeed an issue with some blend modes (Overlay being one of them)
There have been a couple of reports about this:
T76376
T74440
T79333
T85996
This is all handled now in T75844: Blend modes are broken, will merge these reports
