Crash picking colors in geometry nodesockets
Closed, ResolvedPublicBUG
Graphics card: GeForce GTX 1660 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.40
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-03-05 06:10, hash: rBb5d154f400e4
I was following this tutorial: https://www.youtube.com/watch?v=g7EGSCo1YBI
when i was reproducing the steps at 18:50 adding an atribute fill node and change the type to color, when i click the square to change the color value, blender crashes to desktop.
with blender open, add geometry nodes to the default cube;
split screen and change to geometry node editor;
add atribute fill node, change attribute fill node type from float to color;
click on the rounded square by the value to change the color. it made my blender crash.
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Mar 8 2021, 11:40 AM
Can confirm, will check
Philipp Oeser (lichtwerk) triaged this task as High priority.Mar 8 2021, 1:41 PM
Will set to high prio since you cannot pick colors in a couple of nodes now
Philipp Oeser (lichtwerk) renamed this task from Crash using attribute fill node to Crash picking colors in geometry nodesockets.Mar 8 2021, 1:41 PM
