EEVEE SSR Refraction Depth regression
Linux Mint 20.1 Cinnamon 64-bit
3400G (iGPU)
Broken: 2.93.0 Alpha, d25ab68cf4b2, and 53b82efed66b
Worked: 2.92.0 Release, and 2.93.0 Alpha e4a55b46c406
Refraction Depth > 0 no longer seems possible, unless using high levels of roughness.
Refraction Depth = 0 still provides an almost identical result.
In case helpful, regression seems to have appeared in the last few days (recent EEVEE refactoring?).
Open the following .blend file in both 2.92.0 Release and recent 2.93.0 Alpha and compare results.
2.92.0
2.93.0
Forgot to say...
Thank you @Clément Foucault (fclem), Your coding skills are greatly admired and appreciated.
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Mar 10 2021, 9:27 AM
Philipp Oeser (lichtwerk) triaged this task as High priority.
I get something if I come closer
But starts to vanishes from further away
@Clément Foucault (fclem): this cant be right, right?
**System Information**
Operating system: Linux-5.10.19-200.fc33.x86_64-x86_64-with-glibc2.32 64 Bits
Graphics card: GeForce GTX 970M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 455.45.01
version: 2.93.0 Alpha, branch: master, commit date: 2021-03-10 04:47, hash: `rB70e73974b593`
2021-03-17 update:
Was fixed in 2.93 Alpha 1f8d27a191c9, regressed again in be51d671b500, and de06cb85593b
Try either the above .blend or the following...
As per @Philipp Oeser (lichtwerk) findings (thank you for your tests and feedback!), try zooming in and out using the mouse wheel. Changing camera focal length (FL) also highlights the issue.
Camera FL 25mm
Camera FL 50mm
Camera FL 75mm
Camera FL 150mm
Thank you.
Clément Foucault (fclem) reopened this task as Confirmed.Mar 17 2021, 3:28 PM
