Grease Pencil: Time offset modifier not rendering loops anymore
Closed, DuplicatePublic
Graphics card: GeForce GTX 970/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.89
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash: rB02948a2cab44
Worked: 2.91
Since 2.92, looped animations with a grease pencil modifier "Time offset" are not rendered. Although they are working correctly in the viewport.
  • Create a grease pencil object.
  • Create a set of frames to loop.
  • Add a "Time offset" modifier, check "custom range" and enter the first and last frame of the sequence that has to be looped.
  • Choose a random frame to render, picked outside of the sequence of initially interpolated frames.
As a result, the last frame of the sequence will be rendered, and looping will be ignored.
[Based on attached .blend file (as simple as possible)]
  • Place the temporal cursor on frame 15. Now, if you render this image, since it is a looped interpolation of 11 frames showing Suzanne moving from left to right, you would expect the rendered image to show Suzanne slightly to the left. But she will appear to the right for each frame after the sequence of keyframes, ignoring the "Time offset" modifier.
Thank you for your time.
Unknown Object (User) created this task.Mar 13 2021, 4:07 PM
Unknown Object (User) updated the task description. (Show Details)
Unknown Object (User) renamed this task from Time offset modifier not rendering loops anymore to Grease Pencil: Time offset modifier not rendering loops anymore.Mar 13 2021, 4:53 PM
This looks like T85745: Grease Pencil Modificador Time Offset Error and T86105: Grease Pencil Time Offset Modifier does not work in 2.92 corrected by https://developer.blender.org/rB0d94695cc458b1f7666104314b57b174f0ee93d1.
It should be fixed when a new release is made see T85958: Potential candidates for corrective releases.
In the meantime, please try the latest build from https://builder.blender.org/download/.
