Node - The active node of the active modifier of the active object.
Implementation:
Implementation:
Instead of the active node It would be better to have a specific "monitor" marker for a node that is NOT based on selection. Otherwise the spreadsheet will keep jumping while you tweak values all around the tree, even if you want to monitor a specific fixed point
@Daniel Salazar (zanqdo) I thought about this potential issue. However you don't need to select a node in order to tweak its values.
@Dalai Felinto (dfelinto) Alright that sounds fair. Let's see how it does in practice
@Daniel Salazar (zanqdo) just for the records the implemented solution is more aligned to what you were suggesting.
