Operating system: macOS Big Sur
Graphics card: Apple M1
Broken: (example: 2.93alpha, 8936550269333297f6c083c92c90f11660b22e33, Sun Mar 14 15:10:18 2021 +0100 "EEVEE: Specular Occlusion: Avoid overdarkening on smooth surfaces") until current version
Worked: The versions before
Switching the default defaultcube scene to the matrial view immediately shows the defaultcube in camo pattern of dark shapes.
- Use an Apple M1, it is an error that probably doesn't show up on other machines but it is no driver error.
- Create new default scene
- Switch on material view
- Watch camo pattern of dark shapes.
- Switch on ambient occlusion
- Watch defaultcube in it's usual correct shape.
Long description of error
- In the function specular_occlusion (in ambient_occlusion_lib.glsl) visibility_error is defined but not initialized.
- occlusion_eval is called and when int(aoSettings) & USE_AO is false (ambient occlusion is off) the function returns leaving visibility_error undefined.
- Back in specular_occlusion "visibility *= mix(safe_rcp(visibility_error), 1.0, roughness);" visibility_error contains now a wide range of undefined values.
Proposed fix (which works for me): Set visibility_error to zero in the early exit case of occlusion_eval:
diff --git a/source/blender/draw/engines/eevee/shaders/ambient_occlusion_lib.glsl b/source/blender/draw/engines/eevee/shaders/ambient_occlusion_lib.glsl index dc5c048422b..9836aa49cd0 100644 --- a/source/blender/draw/engines/eevee/shaders/ambient_occlusion_lib.glsl +++ b/source/blender/draw/engines/eevee/shaders/ambient_occlusion_lib.glsl @@ -200,6 +200,7 @@ void occlusion_eval(OcclusionData data, { if ((int(aoSettings) & USE_AO) == 0) { visibility = data.custom_occlusion; + visibility_error = 0.0; bent_normal = N; return; }
