Graph Editor: pressed ALT+o effects "smooth keys" continuously
Operating system: Linux-5.4.0-67-generic-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.39
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash: rB02948a2cab44
Worked: 2.83.13
In the Graph Editor, pressed ALT+o does NOT effects "smooth keys" continuously. Only one single time. If I want to smooth the keys 100 times, I have to press this 100 times.
In version 2.83.13 it worked continuously.
  • In the Graph Editor, pressed ALT+o
It does NOT effects "smooth keys" continuously. Only one single time. If i want to smooth the keys 100 times, I have to press this 100 times.
Dennis (DenEy) changed the task status from Needs Triage to Confirmed.Mar 20 2021, 2:32 PM
Dennis (DenEy) changed the task status from Confirmed to Needs Triage.Mar 24 2021, 7:57 PM
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Needs Information from User.Mar 26 2021, 8:14 PM
Thanks for the report, but looking at the code, "Smooth Keys" is not a modal operator, so it was not made to work the way you describe it.
I tested it at 2.83.13 and the result is the same (are you sure you referred to the same operator?)
I fear this can't be confirmed as a bug, but a request for modified/improved behavior. So should be closed as this bug tracker is only for bugs and errors.
For user requests and feedback, please use other channels: https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests
For more information on why this isn't considered a bug, visit: https://wiki.blender.org/wiki/Reference/Not_a_bug
Dennis (DenEy) added a comment.EditedMar 26 2021, 9:40 PM
Hello,
thank you for your feedback!
Please look at this Youtube Video. Yes, I am shure, that I referred to the same operator.
Still seems that it isn't a bug?
Kind regards
Deney
Dennis (DenEy) changed the task status from Needs Information from User to Needs Triage.Mar 29 2021, 10:32 AM
Going back to Blender 2.83.2 (The only version of 2.83 I have on my computer), I can confirm that holding ALT+O continually smooths the key frames, same for 2.91, while 2.92 and 2.93 does not.
So the behavior has changed, just not sure if it was intentional or not.
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Needs Information from Developers.Mar 29 2021, 4:01 PM
It is quite possible that behavior has changed with rBf5080c82dd91: Keymap: disable 'repeat' by default for keymap items
You can enable the "Repeat" option on the keyitem.
Personally, I don't see holding this shortcut as an advantage.
Depending on the curve, after smoothing 4 or 5 times, the next few times hardly makes any difference.
This also adds many undo steps without the user noticing, so Ctrl Z will not reach the nearest relevant undo steps.
Thank you very much!
Dennis (DenEy) closed this task as Resolved.Apr 7 2021, 9:40 AM
