VSE: Crash When Trying to add Image Sequence
Graphics card: GeForce 840M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 376.67
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash: rB02948a2cab44
Crash When Trying to Add Image Sequence
Open blank blender file
Save file to desired location
set output folder to //vcache\
change output file format to AVI JPEG
Go to Video Editing tab at top
Click add menu, then image sequence
It then crashes and closes
default startup file
I cannot reproduce this with either the latest stable or current development versions of Blender:
Operating system: Windows-10-10.0.18941 64 Bits
Graphics card: Radeon (TM) RX 480 Graphics ATI Technologies Inc. 4.5.13596 Core Profile Context 20.10 27.20.1034.6
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Apr 9 2021, 10:28 AM
There were a couple of reports in relation of the filebrowser used in the VSE, e.g. T85911: Adding video or audio to VSE Sequencer crashes Blender
Not exactly sure where the roots are, but since Factory setting resolved in T85911, please try that as well:
Please try with File → Defaults → Load Factory Settings to see if you still can reproduce this issue.
Philipp Oeser (lichtwerk) renamed this task from Crash When Trying to Make Video from Image Sequence to VSE: Crash When Trying to add Image Sequence.Apr 9 2021, 10:43 AM
Philipp Oeser (lichtwerk) closed this task as Archived.May 3 2021, 6:09 PM
