Node Editors "Select Box" ignores the select modes Extend and Subtract from Active Tool settings
Closed, ResolvedPublicBUG
Operating system: Linux-5.3.0-51-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 450.102.04
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash: rB02948a2cab44
Worked: Not sure, I just checked 2.83 LTS which shows the same behavior as 2.92.0
In Node Editors the "Select Box" tool ignores the select modes "extend" and "subtract" from the Active Tool settings (N panel). Instead, the current selection is removed on mousedown, which is the expected behavior of the first mode "Set a new selection". However, it works just fine for the Lasso and Circle select tools.
  • Add two nodes
  • Use the Select Box tool to box select one of them
  • Set the select mode to "Extend existing selection"
  • Box select the second node
This will automatically deselect the first one.
Thanks for looking into this. :-)
EDIT:
Added a test file.
Falk David (filedescriptor) changed the task status from Needs Triage to Confirmed.Mar 24 2021, 10:33 AM
I can confirm this issue on the latest 2.93.0 Alpha, branch: master, commit date: 2021-03-24 08:34, hash: rB865025c343ac.
Now that was scarily fast!
Philipp Oeser (lichtwerk) changed the subtype of this task from "Report" to "Bug".Mar 25 2021, 1:31 PM
