NO Drag Anykind of File into Blenbder 2.92
Graphics card: GeForce RTX 2070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.92
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash: rB02948a2cab44
With Blender 2.92 Now you cant drag any image, blender file or fbx, on de 3D View, Shader editor, image editgor orr any Panel, in the past version you always could do it.
Robert Guetzkow (rjg) changed the task status from Needs Triage to Needs Information from User.EditedMar 25 2021, 7:50 PM
To the best of my recollection Blender never supported drag and drop of files of other 3D file formats. What version are you referring to, what files were you able to drag and drop in that version and what are the exact steps that used to work in that older version?
from 2.80 to 2.91 versions
You can drag and drop texture files in the shader editor in these versions. This should continue to work in Blender 2.92 and 2.93.
Importing 3D files such as *.obj, *.fbx, *.dae, etc. required and still require to use the menu entry or call the operator through Python.
Please provide step by step instructions for a use case that used to work, but doesn't work in the current version.
In my tests all features that previously worked, continue to work in Blender 2.92. Those are:
  • Drag and drop of *.blend files in the 3D View
  • Drag and drop of texture files in the 3D view
  • Drag and drop of texture files in the Shader Editor
  • Drag and drop of texture files in the Image Editor
What doesn't work, in past and present versions, as it isn't supported:
  • Drag and drop of 3D file formats that aren't *.blend
@Deodato Pechir (deodatopr) Please provide the requested information so we can investigate this issue.
Robert Guetzkow (rjg) closed this task as Archived.Apr 11 2021, 4:18 PM
