Graphics card: GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.92
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-03-31 07:46, hash: rB645fc0c76794
Worked: Yesterday's build
Instancing an object and then using a transform node AFTERWARDS will transform the instances, not the whole object as a block.
Video shows transform only effecting the instanced brick scales, instead of scaling down the whole wall. (Translation appears to work but that would look the same regardless)
Add a cube, instance a cube on the corners. Add a transform node and try to rotate the entire instancer with instances. Only the instances will rotate about their positions.
Test file:
