Blender randomly freezes or turns off.
Closed, DuplicatePublic
Operating system:
Graphics card:
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
It turns off more than 10 times in almost an hour, even if it's not heavy work. I can't find a pattern for this situation.
Blender is version 2.92, and even though I uninstalled and reinstalled the previous version, the symptom
I attach a report when it is turned off and my iMac specifications.
Omar Emara (OmarSquircleArt) changed the task status from Needs Triage to Needs Information from User.Mar 25 2022, 11:46 AM
This seems very similar to T80994, which is reportedly fixed in a later version. Can you try again with the latest version of Blender and confirm that it is fixed? https://builder.blender.org/
I'm assuming it's a duplicate of T80994: Blender 2.91 Alpha make crash guide still.
