Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.30
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-04-07 21:03, hash: rBb7b1b2325c1a
When an object is set to 'Disable selection' mode in outliner (triangular cursor icon is not filled), the 'Only Show Selected' switch in the graph view doesn't work when that same object is selected - the graph view doesn't show animations belonging to the selected object.
The behavior I expected is that the animation of the cube shows in the graph editor when the cube is selected. And that this is true whether or not the cube is set to 'Disable Selection' mode. (since 'Disable Selection', according to its tooltip means 'Disable selection in viewport' only).
- create new file, General 3d
- Add keyframe animation to the default cube's position.
- In the outliner set the cube to 'Disable Selection' mode (triangular cursor is hollow, unfilled) - use the filter button at the top of the outliner if necessary to expose the 'Disable Selection' toggle for objects in the scene.
- Open a graph editor and click the 'Only Show Selected' button. The animation of the default cube should show, but it doesn't (the animation does show when the 'Disable Selection' toggle for the cube is set back to it's default state)
