Image Editor doesn't clear while rendering an animation
Closed, ResolvedPublicBUG
Graphics card: GeForce RTX 3070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.51
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash: rB02948a2cab44
Latest working version: 2.91.0
If you render an animation after each frame it doesn't clear everything in the Image Editor. It just renders and clears the area arround the current render tile. Everything in the attached .blend-File is just to slow down rendering so you can actually see what's going on. The problem also exists in the 2.23 Alpha from today
It's very simple: Just press Ctrl + F12 or do Render > Render Animation. Problem happens on every .blend-File where rendering isn't instant.
fastFox2 created this task.Apr 8 2021, 5:38 PM
fastFox2 updated the task description. (Show Details)Apr 8 2021, 5:55 PM
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Confirmed.Apr 9 2021, 6:13 PM
I can confirm in some frames:
For me it's in all frames, and with any other project too, but this one was one of the simplest I had with non-instant rendertimes.
This is antother example with different rendersettings from my current project:
Appears to be solved after the cycles-x merge.
