Bad weight deform of a Automatic Weight character
Operating system: Linux-5.4.73-1-lts-x86_64-with-arch 64 Bits
Graphics card: GeForce RTX 2070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 455.38
Broken: version: 2.83.13, branch: master, commit date: 2021-03-09 07:21, hash: rBbb5004673085
The mesh and armature have a scale 1 and rotation 0
The shoulder bone named "Def_shoulder.L" has a huge weight deform on the object.
Normally shoulder should not deform the jaw because I have put a jaw bone.
Also It will not deform head, neck and arm !
Open
Select object "Bust" and shift select armature Ctrl + p > Automatic Weight
Uncheck Lock Object Modes
In pose mode select the shoulder bone "Def_shoulder.L" and shift select the object "Bust" and Ctrl tab > Weight paint to see the weight deform
Damien Monteillard (lastrodamo) renamed this task from Bad influence of a Automatic Weight character to Bad weight deform of a Automatic Weight character.Apr 10 2021, 12:23 PM
SOLVED !
The automatic weight is not magic but it doesn't really like the inverted normals in your file ...
I just flipped the normals and I get a more predictable result I hope it will help.
Happy Blending!
If I understand it right, the comments indicate that the problem was accidentally mistaken for a bug. Am I right?
So I'm closing the report.
