Graphics card: NVIDIA GeForce GTX 1060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 465.89
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash: rB02948a2cab44
I dont know if this is a bug or is a better feature to user interaction, but when you try to deform like in Maya with Bend deformer you just put or rotate de deformer in the axis that you need. but in blender the only way to get a correct deform is when you put de Bend deformer ONLY in Z axis, then add a object to change the reference of the rotation and could rotate in the axis that you supposedly need it in the first intance.
If the deformer has X, Y, Z Axis shold work as the standar as Bend deformer like Maya/Max/Houdini, I dont know if I can ask this as a feature or a bug?
X (Doen't work deformer):
Y (Doen't work deformer):
Z: (Works Only in this axis):
Z + Object Refernce: (Works only if you add a object to change the reference of the rotation only if is from Z Axis to deform for X or Y axiz).
