Operating system: Linux-5.8.0-48-generic-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: GeForce GTX 1650 Ti with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.39
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash: rB02948a2cab44
Worked: (not sure)
As the issue title states, baking a tangent space normal map without using the Selected to Active option appears to ignore modifiers, producing wrong results. For example, this is the result of baking a normal map on a simple smooth-shaded cylinder with a bevel modifier applied:
Given this is a tangent space normal map with a completely uninteresting material, the normal map should be a solid color (and the cylinder in the 3D viewport should be completely black), but obviously it is not. If the bevel modifier is applied, the problem goes away.
Curiously, baking an object space normal map works fine:
This strongly suggests to me that this is, in fact, a bug, not just unexpected behavior.
- Start from the following .blend file:
- Select the normal map image texture node and press Bake. Note that the baked normals are incorrect.
- Apply the Bevel modifier on the cylinder, then press Bake again. Note that the baked normals are now correct.
