Crash in edit mode after adding sphere object mesh on middle mouse click
Graphics card: AMD Radeon(TM) RX 560 Series ATI Technologies Inc. 4.5.14757 Core Profile Context 20.12.1 27.20.14501.28009
Broken: version: 2.93.0 Beta, branch: master, commit date: 2021-04-28 18:30, hash: rBba755ea677b3
Crash in edit mode after adding a mesh
Adding a sphere object and then switching into edit mode to select vertices, as soon as I press down middle mouse to spin view, blender locks up and crashes. (also using geo nodes)
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.May 11 2021, 1:29 PM
Just to make sure:
Does this also happen without Animation Nodes?
Please try with File → Defaults → Load Factory Settings to see if you still can reproduce this issue.
Philipp Oeser (lichtwerk) closed this task as Archived.May 21 2021, 2:06 PM
