Blender 2.93 git-build crashes
Blender 2.93 nightly git-build crashes before opening from terminal and/or desktop. This is on Mac Big Sur 11.2.3, 2019 Mac, 3.2 GHz 6-Core Intel, Memory: 16GB
Any help/suggestions much appreciated
Hans Goudey (HooglyBoogly) changed the task status from Needs Triage to Needs Information from User.Apr 30 2021, 6:53 PM
In order to investigate the report, we need more information:
  • Are you using the default startup file? Try --factory-startup to make sure.
  • What was the last version / build that worked?
Thank you for the prompt response! i have been dragging "../Users/geraldineerman/blender-git/build_darwin/bin/Blender.app" to terminal and/or right-clicking open from directory--on both attempts icon bounces up and immediately dies/ no error report or terminal message--I updated this build yesterday afternoon--probably last time was sometime a week or so ago (2.93) and it was cranky but functional? Don't have any other version info, sorry...i am not sure how to enter ( --factory-startup) as you suggest, sorry..
This should explain how to launch blender from a terminal window: https://docs.blender.org/manual/en/latest/advanced/command_line/launch/macos.html
You just add --factory-startup to the command to get the default startup file.
Thanks.
Robert Guetzkow (rjg) closed this task as Archived.Jul 4 2021, 4:51 PM
