Select by Material node for the material pipeline
Closed, ResolvedPublicTO DO
This node creates a "boolean Face" attribute that is True for any face that has the material assigned to it. This mask can be used directly with the "Material Assign" node.
Note: It should work even if there is more than one slot with the same material.
Note: The node has been renamed from Material Mask to Select by Material.
Depends on: T86737: Working with materials in geometry nodes
Dalai Felinto (dfelinto) changed the task status from Needs Triage to Confirmed.May 5 2021, 2:56 PM
Dalai Felinto (dfelinto) created this task.
I think those nodes have similar look and functionality:
T88054 (Material Mask)
T86737 (Material Assign)
@Some User (someuser) There are actually opposite, and supposed to be able to work together (short of using the Material Replace node directly). I added a short description
Jacques Lucke (JacquesLucke) renamed this task from Material Mask node for the material pipeline to Select by Material node for the material pipeline.Jun 1 2021, 1:47 PM
Jacques Lucke (JacquesLucke) updated the task description. (Show Details)
Dalai Felinto (dfelinto) closed this task as Resolved.Jun 15 2021, 11:58 AM
