Eevee clamping color values when viewport rendering and using viewport HDRI
Confirmed, NormalPublic
Graphics card: NVIDIA GeForce GTX 970/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.11
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-05-14 11:45, hash: rBa4f0780acfde
Worked: (never)
When doing a viewport render, color values are being clamped. In 2.92 a workaround for this was introduced - if you disable overlays, color is being processed as it should.
However, if you use a viewport HDRI, even with the overlays turned off, values are still clamped.
As these two are often used together to get some quick snaps, it is a little inconvenient
  1. Open file
  2. Switch to rendered view
  3. Viewport render image
Colors are clamped even though overlays are disabled
Richard Antalik (ISS) changed the task status from Needs Triage to Confirmed.May 25 2021, 9:26 AM
Richard Antalik (ISS) updated the task description. (Show Details)
I found video quite confusing, so I have removed it from description and I will provide it here:
@Jeroen Bakker (jbakker) This is essentially duplicate of T77909, but I wasn't sure if this wasn't covered by rBed809866b172 due to technical limitations or this could be part of workaround.
