Texture Paint Brush not appearing on 3D viewport
Operating system: Darwin-18.7.0-x86_64-i386-64bit 64 Bits
Graphics card: Intel(R) Iris(TM) Plus Graphics 655 Intel Inc. 4.1 INTEL-12.10.25
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash: rB02948a2cab44
When under the Texture Paint tab, Texture Paint Brush does not appear on User Perspective viewport.
When I go to the texture paint screen, the texture paint brush appears only on the left hand side, not on the right hand side on the actual object in the user perspective viewport.
Angela (atosc002) created this task.
This comment was removed by Angela (atosc002).
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.May 19 2021, 9:33 AM
Does this happen in any scene?
If not, please share your particular example .blend file so there is a chance to reproduce.
Please also try with File → Defaults → Load Factory Settings to see if you still can reproduce this issue.
No it does not happen in any scene. I tried to reproduce it at several different points, I am not sure where it began particularly.
Philipp Oeser (lichtwerk) changed the task status from Needs Information from User to Needs Triage.May 21 2021, 10:32 PM
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.May 26 2021, 5:16 PM
You've got the Camera selected (the camera does not have a Texture Paint mode, so you'll be in object mode - which does not have the paint cursor).
If you actually select the Donut, you should be able to go to texture paint mode on it.
Or if you go back to the Layout workspace, select the donut and then go to the Texture Paint tab, you should be in texture paint mode as well.
Does this work for you?
Philipp Oeser (lichtwerk) closed this task as Archived.Jun 4 2021, 1:48 PM
